Question about Sony VAIO VGC-LS21N PC Desktop
My Sony VAIO VGC-LS21N PC Desktop or pcg 252L computer won't start, i get 3 beep sounds and the screen doesn't want to turn on.
  • 707 Answers
Check to see if your RAM Module(s) are seated properly
Posted on Oct 15, 2010
How to connect xbox 360 to Vaio pcg 252l
I couldn't find out if the Vaio pcg 252l was either a monitor or laptop, but if it is a laptop, I have to dissapoint you because there is not possible to do, because the laptop isn't made to be used as a monitor, but if the Vaio is a monitor(basicly a screen), then all you have to do is to either connect a HDMI cable from the xbox to the monitor, or you can use a SCART cable, all depending on which are available on the monitor/xbox.
HDMI have better quality, in case you could use both cables.
Oct 13, 2012 | Sony Used Vaio Pcg-252l Vgc-ls25e All In...
When i start the machine up it starts up... then the image gets staticky,,, then all u can see is white lines and no image, im not sure if it is the video card thats causing the problem. Need to fix t
If you are able to connect an external monitor, do so. (If you can make it a newer lcd type) Sounds like your monitor's display is set to the wrong setting (refresh and pixel) With an newer lcd, you should be able to see your screen and reset the display to the lowest setting. Reconnect your Sony monitor. (if the external work and you are able to reset the settings, you do not need to power off your pc, just switch the monitor cable from the external to the regular monitor.
Good Luck
C2Solutioins
Feb 14, 2012 | Sony VAIO VGC-LS21N PC Desktop
I checked the ram modules and the thing is when i press to start the computer the led on the screen doesn't turn green , i get either one long beep or 3 beeps, and the screen remains black and it doesn't...
One long beep + 3 short beeps denotes a video problem for Sony Vaio. Unfortunately it doesn't get more specific. If you have a video card, try re-seating the card. Try using a different monitor. Try upgrading the drivers (probably here: http://www.driverboost.com/lp/drivers/update/ati-video-drivers.php ) of course you will have to go to a different PC to download them onto a CD/dvd and try to run them. You might consider trying to boot into safe mode and doing a system restore. It could be many things. Without more information I can't really be of much more help. Hope one of these works for you.
Good luck
Oct 15, 2010 | Sony VAIO VGC-LS21N PC Desktop
I have a Sony Vaio VGC-LS25E All-in-one PC. When I power it on, nothing happens, the display is blank and there are no normal boot up sounds. Yesterday, it beeped 3-4 times when turned on, but it is not...
Amazing. I have the same computer and the same thing just happened to me. The computer works and if I press the sleep button I can see the screen for about 4 seconds.
Aug 30, 2010 | Sony VAIO® VGC-LS25E All-in-one Desktop PC...
Can anyone tell me where i can find out how to remove the Back or Front panel to get to the HDD fon a VAIO VGC-LS21N PC Desktop. Thank you in advance.
at the back of the tower you can find the screw you need to remove that and slide that cover then you can find the HDD
May 19, 2010 | Sony VAIO VGC-LS21N PC Desktop
I'm trying to open the case on my Sony Vaio VGC-LS21N integrated desktop computer, to replace the hard drive. Any ideas how to get it open and/or where the HDD is located inside the case?
Hi! You may download the Manual HERE and see how you can take out the hard drive out from the tower. Please be cautious while taking out the harddrive to avoid any incident.
May 12, 2010 | Sony VAIO VGC-LS21N PC Desktop
I have the same problem!
Your sony computer has a bad LCD backlight or LCD backlight inverter. Need a service repair by qualified tech.
Jul 27, 2009 | Sony VAIO VGC-LS21N PC Desktop
Sony VAIO  VGC-LS21N PC Desktop Logo
834 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
