Question about Toro Lawn Mower With Toro Power Tools
My toro lx460 lawn mower will not turn right, but it does turn left..
SOURCE: Toro Lawn Mower Won't Start
this is a very common problem with these toro mowers. the needle valve in the bowl of the carb. is plugged up with dirt or varnish from the fuel. just under the primer bulb there is the carb bowl. it has a nut under it that holds it on remove the bowl and make sure fuel flows constantly while the bowl is off. push up on the float to stop the gas flow. this could be messy and dangerous. careful with the gas. its flammable. best solution is to remove the carb and soak it overnight in a parts cleaner like gunk. caution small parts inside. this happins every year on mine no matter what i do. seems like the orifice is so small it clogs easily. good luck
Posted on Nov 15, 2008
  • 109 Answers
SOURCE: Cannot pull the cord more than 6 inches to start Toro lawn mower.
Hi Patti, If you can not pull the cord more that what you said, try removing the spark plug and see if that makes a difference, if not, leave the spark plug out to prevent accidental starting, raise up the front of the mower and see if you can turn the blade if not...it only gets worse from there. If you can't turn the blade from under the mower, the engine is more that likely seized up, sorry
Posted on Apr 26, 2009
  • 33 Answers
SOURCE: Toro lawn mower sputters and stops working after running
fuel delivery probblem might be vapor lock(to much heat getting to fuel lines and carb) may also have dirt in fuel bowl on carb and in tank ,gas tank lid may not be venting . it will be one of these three things
Posted on May 02, 2009
  • 32 Answers
SOURCE: Toro Lawn Mower model 20016
it isn't the spark plug if it wont turn over. maybe your battery is dead.
Posted on Jun 12, 2009
SOURCE: Toro 22in Lawn mower. Loud gear noise when try to engage drive.
Problem is in the rear pinion gears on rear axle and the design of the axle itself. I have a 2005 model 20041 had the same problem. I found a Toro dealer that had the fix.The problem is creadted by the fact that there is too much "play" in the rear axle. You have to limit that play by installing shims, or washers First, but the 2 new rear pinion gears for the rear axle. While you're at it, you may as well buy 2 new rear wheels because the "grinding" has worn the sprockets on the reas r wheels.Next, get 2 "fender washers", 1/2" ID and about 1" OD. I found it easier to turn the mower over and set it on saw horses to work on it.( drain the gas and oil first). Remove both rear wheels, pinion gears and all the washers etc. (caution - keep all parts from one side together - do not pile all parts together - keep them seperated by wheel - the reason is I believe there is one more washer/shim on the right side than on the left). Now to put everything back together, find a spot on the axle where the washer will fit in between the standard stuff.Install new pinion gears and replace the rest of the washers/shims just as they came off. INstall new wheels and you'll be good as new!
Posted on Aug 02, 2009
What is the size of drive belt for toro riding mover lx460
Refer your inquiry directly to Toro or a local Toro dealer.
Jul 27, 2014 | Toro Garden
Toro z420
you have to adjust your tracking. Your manual tells you how to do this
Jul 23, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
How to tighten belt on aToro LX460 V twin
it may have stretched and needs a new belt there is a spring tensioner that can only go so far
Apr 20, 2012 | Toro LX466 22HP Lawn Tractor 13RT61RH244
How do you hold the blades on a toro LX460 while breaking the nut loose to change them
Use a piece of 2x4 and a clamp. Clamp the wood to the inside of the deck using the clamp. When the blade comes around and bumps against the wood it should act as a stop. Or you could rig something with a Vise-Grip plier. Lock onto the blade with the Vise-Grip, run a piece of rope from the pliers to a point on the mower where it will stop the blade from turning.
May 23, 2010 | Toro Lawn Mower With Toro Power Tools
My toro 20016 self propel is only turning the right wheel
Remove the left wheel and check the gears inside the wheel and the drive sheft. They might be worn or sheared and need renewing or maybe they just need oiling. Spray them with WD 40.
May 20, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Toro Lawn Tractor won't start, engine turns
best guess , blocked main jet or water in the carby
an overhaul would be in order
Oct 24, 2017 | Toro Lawn Mower With Toro Power Tools
What length is a deck belt on a toro lx460
1/2" x 90" ; Toro P/N 112-5834
Try:
http://www.tractorsupply.com/outdoor-power-equipment/mowers-attachments-accessories-parts/mower-parts/mower-belts/huskee-v-belt-1-2-x-90-in-4461290
for $19.49 if you have a Tractor Supply Company nearby.
Or:
http://www.texasmowerparts.com/catalog/products.asp?ds=DETAILED&category_id=47&group_id=184&section_id=585
# Replaces Toro 112-5834 # 1/2" X 90"
for $14.17 + $5.95 shipping
Danotex
Jul 14, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
65 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
