Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
It keeps beeping and shows code FC in the window
    Sergeant:
    Champion:
  • 351 Answers
Hi FC is communication error between boards what that means is wiring harness or power relay board(prb)
Posted on Oct 15, 2010
Jenn air gas electric grill range with convection oven making beeping sound showing -FC- code
FC is a communication error caused by poor connections with the wiring between the logic and relay boards in the unit... Disconnecting and re-connecting the wires and looking for / reflowing the solder joints behind the header connectors will fix your issue
Jul 19, 2016 | Jenn Air Kitchen Ranges
Trying to change master code on 6150 vista 20
Either you are locked out of installer programming or you do not have a Vista 20...this sounds more like a larger panel such as a Vista 40, 50, or some other 4140 based system...verify the model number by opening the main cabinet. The inside cover should have a diagram of the system and the model number. However, since the boards are easily replaced, the cover label is not always accurate. Look at any labels on the printed circuit board to help you properly id the model. By the way, FC indicates Failure to Communicate, meaning the unit tried to call the monitoring center but could not get through (usually 10 attempts) and is unrelated to the "master code". Hope this helps.
Jan 31, 2015 | Honeywell Ademco Alarm Vista 20p 6150...
Beeping and FC code
check to see if you have a fuse blown to your stove and replace it
Oct 03, 2012 | Jenn-Air Ovens
Mthr brd FC-GB/ 7VM333M-RZ not working ???
you want to take an format cd an insert it and format the full system and install an windows xp pro as ur operating system and put an 1 gb ram in it
Mar 30, 2012 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Honeywell vista 20p FC error code no monitor service beeping every 30 sec. need help how to stop beeping
If the keypad displays FC, that means that it is programmed to send alarms to a central station and a phone line isn't connected to the control panel. If you do not subscribe to monitoring services, it will have to be re-programmed. I can do that for you over the telephone if needed.
Thanx Mark Garrett
Aug 21, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
Error code -fc- beeping will not stop?
From JENN AIR FAULT CODES...
FC - Communication error between boards - Wiring harness or power relay board (PRB)
Hope helps.
Mar 24, 2011 | Jenn-Air Electric Double Oven
Jenn air range model SCE30600B error code FC blinks with beeping noise. After resetting the temp down to 350 to keep from burning a pizza error code FC started blinking along with continual beeping. I have...
replace the entire range: Jennair does not know how to design, make, or program electronics. It makes steel boxes that provide heat but electronics - that's not within their ability. Buy a Kenmore or a GE and your beeping problem will go away.
Feb 03, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Beeping noise - letters appear fc
Christina, FC means there is a communication error between your main power board and keyboard. There is a J2 harness that runs between them. You might try to reseat this harness. If that doesn't work the main board will have to be replaced. Catriver..post back.
Sep 14, 2006 | Jenn-Air SVE47100 Slide-In Electric...
Since Jenn-Airs codes are F1-F9, the cicuit board may be on the way out since the code resets after you turn it off for a while.
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
284 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
