Question about Frigidaire Washing Machines
Sounds like it is out of balance. really noisy.
  • 19 Answers
If overloaded or heavy items being washed it will spin out of balance.Try a lighter load to make sure its not just a one off fault. If no good its probably the drum bearings unfortunately.(needs engineer call out).
Posted on Jun 02, 2008
The fan the circulates the warm exhaust air out the front of the unit is making a lot of noise.
and this is really a Frigidaire stove? Or is it a fridge?
Stove, check the circulation fan, which is usually at the back surrounded by the element. You can check if the fan has slipped on the spindle, but they often need replacing as they work in such a hostile atmosphere.
Fridge. you can check the fan which is at the rear at the bottom. Again, the fan may have moved, but the problem there is often the fibre board shield around the fan. If it is the compressor itself, it is beyond economical repair, you need a new fridge.
With both fans, they are made of aluminium and a blade can snap off. That makes them run out of balance and are noisy.
Dec 26, 2015 | Frigidaire FPDS3085KF Stainless Steel Dual...
Noisy motor front end vn v6 commodore, bad rattle sound??????????
It sounds like your timing chain may be worn, A bit of a pain to change but do-able if you have the tools and some time. The harmonic balancer makes more of a knock than a rattle.
Mar 04, 2012 | Cars & Trucks
Very noisy on spin cycle, not out of balance
Hi, check leveling of machine, machine should be proper leveled on all side, use spirit level to adjust legs, there should be no rocking motion, in any direction after leveling, put hands on top of machine and try to rock it sids to side, there should be no movements, also check for overloading, be careful when washing things like bath towels, etc, they absorb lots of water, eg. one regular bath towel are equivalent, to six pants, six tops. or possible springs or bushings broken, you need open machine and check.
Aug 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I've had balance problems on other cars and I'm 99.9% sure it's not a balance problem. It's not acting the same. It's too noisy - relative to the shifting of the engine. Any other suggestions, please keep...
Turn off your A/C. Compressors can sound like stone crushers. Have you checked the trans fluid? With motor off, grab fan clutch and water pump pully, really all pullies should be checked for looseness.
Have you checked the lugnuts?
Jul 05, 2009 | 2009 Honda Pilot
Kenmore front load washer that's noisy when it spins
on most kenmore front loader after some time the bearing start to wear and the washer will get louder and louder,it is a big repair job!-mike
Mar 23, 2009 | Kenmore HE2 Plus Front Load Washer
Audio on videos terribly noisy and hissy
Low-res audio and AVI video is probably the best you're going to get. It is a still camera first, after all.
Feb 03, 2009 | Vivitar ViviCam 4345 Digital Camera
Hi,my hotpoint wf541 washing machine has become noisy on its spin cycle,any ideas as to what is wrong with it,or can you recomend a repairer for me in Lincoln,uk?
Try spinning the drum by hand ,if it feels or sounds noisy, then the main bearings have gone, if no obvious niose, then it could be m/c not level, overloading,-loose balance weight)(s)-suspension spring broken or unhooked--there are other causes, but these are the usual things to look for.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint BWM12 Front Load Washer
Noisy engine
sounds like you may have a rod going out on the truck...
Jul 25, 2008 | 2001 Jeep Cherokee
At least once a day my whirlpool 3 door freezer on bottom, 1 month old, gets very noisy like a bearing or fan out of balance
sounds like a fan motor in the freezer issue, it is under waranty, call whirlpool for factory service on the machine
May 09, 2008 | Refrigerators
High rpm
These machines are noisy to begin with, but will become worse if anything is allowed to enter the fan area of the motor. I have seen debris clog the front fan and put the motor out of balance so it will really scream when it runs. This work is best left to a competent professional
Jan 11, 2008 | Hoover Portapower C2094 Bagged Canister...
Washing Machines Logo
62 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
