Question about Magic Chef CMV1000B Microwave Oven
A loud buzzing noise when turned on, and is not heating up
  • Magic Chef Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Posted on Feb 22, 2011
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
GE JES738WJ02 not heating it runs but with loud buzzing noise, turntable turns, light is on -no heat
could be the door switch or any number of other things . take it in for repairs or buy a new one
Jul 12, 2015 | GE Microwave Ovens
GE Microwave (JVM1860CD001) control board buzzes.
see this causes and fix it. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 10, 2012 | GE Microwave Ovens
Sharp R-7A82, buzzing/no heat
buzzinsg / humming / loud or louder than normal .is probably the mag / it has failed and the trans is making that noise . if older than 5 yrs I would replace ans the mag is 100.00 + and w / labor you have paid for a new on but have the old one .**** ..
Dec 23, 2009 | Sharp R-630D Microwave Oven
Loud buzzing noise with Whirpool microwave oven when it comes on. All lights, heating and fan seems to work but not sure why loud buzzing. What is the problem?
The loud buzzing you hear is the sound of the magnatron tube.That is what emits the microwave radiation and buzzing should be normal. The mag tube may be nearing its end at witch time you will hear no buzzing and hence no heating of foods. Replacement can be costly depending on the model so most people just opt for a new one. Hope this helps
Jul 30, 2009 | Microwave Ovens
Ge spacemaker xl 1800 - no heat
HI, the loud popping noise was the Magnetron tube. this is the main heating device. the noise filter is also damaged and, should be replaced as well.
In conclusion, replacing the Magnetron tube and noise filter will fix this unit.
Jun 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Makes a loud buzzing noise and does not get hot
Have seen this many times.
Sounds like a bad CAP since a bad diode would blow the fuse and a bad mag would likely do the same thing.
Since yours is making the loud 60hz buzz you need to replace the capacator that will likely fix the problem. A $10 fix
Jan 06, 2009 | Kenmore 62622 Microwave Oven
Ge microwave - making noise
I have a GE counter top microwave oven. When the oven starts cooking (the magnetron turns on) the oven makes a harsh buzzing noise. What is wrong and what should be done?
Mar 07, 2008 | Microwave Ovens
Mwave made loud buzzing noise then didn't heat up anymore
When there's a loud buzz like that, it does not heat, and does not blow the fuse, it is usually a defective magnetron. Did it sound something like someone making a "gurgling" sound into a coffee cup? I think this has a a one-year warranty, with n five-year warranty covering the magnetron. You can find a local Amana-authorized servicer here: http://amana.com/amana/jsp/portalhttp.do?cs=0&BV_UseBVCookie=Yes&NextPage=7
Mar 03, 2007 | Amana AMV1162 Microwave Oven
Magic Chef CMV1000B Microwave Oven Logo
150 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
charles
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
