Question about Cobra HH 38 WX 40-Channels Handheld CB Radio
My cobra radio won't work unless it is on the charging stand. The batt. indicator says fully charged
  • 35 Answers
Usualy when you have that type of problem it is because the battery is shot. As you indicated the charge light shows good but the minute you draw or try to draw current ( power ) by activating the radio the battery does not have enough life left in it.
Posted on Oct 22, 2010
What mode do cobra micro talk walkie talkies charge on
the ones I have charge on their own charging stand, they are great radios for the $$ as compared to others I have
Dec 27, 2014 | Cobra LI6050-2WXEVP microTALK 22 Channel...
Charge time cobra 235 recharge batteries
Hi! I've got a different cobra model and I find it ridiculous, but there is no indication when the batteries are fully charged... Either use external charger for your batteries or just leave it plugged in overnight- that would ensure full charge (it does in my case, I've checked batteries with multimeter)
Sep 23, 2014 | Cobra Radio Communications
Cobra Mirco Talk CXT 195
pls check usb cable , replace with new gud quality short length usb cable n try to connect the same in back side USB port not front side ..
Jan 15, 2014 | Cobra Radio Communications
My blueant s4 won't charge
It must be a battery problem as the battery indicator level says full when you remove it from the charger and the phone doesnt work.
Mar 19, 2013 | Blueant Ant S4 Handsfree Voice Controlled...
How do i charge my cobra hand held radio
According to Cobra's website, if you are charging the batteries (or battery pack) that came with the radio, charging should take about 15-hours.
If your model came with the desktop charging stand, they state that it is safe to leave them in the stand without fear of over-charging. If your model uses a power cord that you plug into the radio, then they state that you should not leave it connected to the charger for more than 24-hours.
If you follow the link below, it will take you to the Cobra website, where you should be able to download a copy of the manual for your radio. Find your model in the list, then select the "Details" button for that model. A new page will open then select the "Product Specifications" tab, and you will find a link to download the manual.
Cobra Two-Way Radio Page
Hope that helps you out.
Nov 30, 2011 | Cobra 18-Mile, 22-Channel FRS/GMRS 2-Way...
Cobra pr 3850wx bought new NiMh 800mAh 1.2v rechargable batteries now the base charger lights won't come on when i put the radios in it
  • A Cobra 3850wx Radio requires 4x600mAh NiMH 1.2V AAA Part # GA-3ANH rechargeable batteries.
  • Not just any AAA rechargeable battery will charge in the unit.
  • All will work in the radio but not all will charge inside the radio. It has to be a specific battery.
  • This is an example of what you need. GA-3ANH batteries which will charge inside your radio. http://www.tomsawyer2wayradios.com/catalog/item/3823249/5076887.htm
Regards, Tony
May 22, 2011 | Cobra Microtalk 100 FRS Walkie Talkie...
I HAVE PURCHASE THE TWO WAY RADIO CXT175 THEY WANT CHARGE I NEED HELP
There is no charging indicator on your radios, but after the charger is connected and plugged into a wall outlet for approximately 15 hours, the battery status indicator should show a full charge. If this is not happening you may have a defective charger or charging circuit, and you should contact Cobra via their Customer Service number, 773-889-3087, or through their web site, www.cobra.com.
Jan 13, 2011 | Cobra Electronics CXT85 Two Way Radio
My walkie talkies will not charge wheni place them on my charger, whywont it work
If neither of them work, then that would suggest something common to both... the Charger? Are you sure it is OK? Is it making good connection, give them a clean/scrape. Otherwise it could be dicky batteries, they go faulty all the time & for no apparent good reason.
Feb 09, 2010 | Cobra Electronics CXT85 Two Way Radio
Charging batteries
the cobras are meant to work with alkaline cells. You bought nicads which are a lower voltage per cell (1.2 to 1.38). Alkalines are about 1.55-1.58
That is why your rechargeables only show a quarter charge, because their terminal voltage is lower and the radio thinks they are not fully-charged.
May 28, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Cobra PR3850WX will not recharge batteries
There is a contact in the upper left hand corner of the batt compartment.This has to touch the metal of the last batt.If your batts have paper around them scrape it off where it contacts that contact point.
Nov 10, 2007 | Radio Communications
Cobra HH 38 WX 40-Channels Handheld CB Radio Logo
93 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
