Question about Acer P191WBD LCD Monitor
Screen pretty dark and flickering - Acer P191WBD LCD Monitor
  • 11,361 Answers
Look for bad DC filter caps first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 15, 2010
Dark screen and flickering on the laptop computer model pcg 61611L
I would check the GPU by connecting an external monitor before booting it, that will allow the external drive to automatically work.
Jan 02, 2014 | Sony VAIO Computers & Internet
42" LG plasma dark and flickering screen
Check and replace its main power regulator IC. Check the set voltage to screen [Va & Vs] voltages. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 17, 2013 | Televison & Video
Screen has been flickering, does not go black but gets really dark. Sometimes if I tap it or move it is stops. Is my screen going bad?
sounds like a loose connection somewhere. find a local computer repair shop. Often those guys can diagnose a common problem just by glancing at the symptoms. GeekSquad is great but costs lots.
Jan 21, 2013 | HP Pavilion Computers & Internet
Screen is dark on one side
its inside the screen its pretty much not gonna work right ever again and i wouldnt waste too much time on it
Jun 12, 2010 | Averatec D1002UHCE-1 All-In-One Intel...
The screen flickers, is dark, and makes sound
clear the dust inside the monitor...
Mar 13, 2010 | Computers & Internet
Tv went grayscreen, flickering. turned off, then
When you had gray screen and flickering you had only one problem - color wheel. After "putting everything together" you have totally different problem, caused by multiple possibilities like: forgotten connectors, cut/jammed cables/wires, lamp not being inserted properly, lamp door not being set properly, disconnected color wheel, etc. Try to open rear cover and redo what you have done. Remove optical block, check everything visually and slowly put everything back. If still no luck - then only skilled TV repairman may (or may not) help.
Mar 10, 2010 | Samsung Televison & Video
Dell Latitude D510 Screen Failed
The 14.1" inch screen is compatible with Latitude models D500, D505, D510, D600, D610 and Inspiron models 500m, 510m, 600m.
You may also need a screen inverter - in fact that is often the reason a screen is considered to be failing. The lcd inverter can be one of the most common items to become defective in a laptop computer. You may need a lcd inverter replacement if your screen is dim, dark, colored oddly, blinking, flickering or has dark stripes. Just something to keep in mind.
Hope this helps,
Chris
Mar 20, 2009 | Dell Latitude D600 Notebook
Toshiba Plasma 42
plasma42 color flickers in and out and now its just snow,now its black screen. still have sound.please help me.. what board should i replace??
Dec 29, 2008 | Toshiba Televison & Video
Acer P191WBD LCD Monitor Logo
131 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
