Question about Akai LCT3285TA 32 in. LCD Television
I need a manual for the lct3285ta was given the tv but can't get to channel 3 for the cable also where can i get a remote
    President:
  • 1,140 Answers
Please rate this solution if you find it helpful. Thanks.
You can download the manual (free) from here:
http://www.retrevo.com/support/Akai-LCT3285TA-TVs-manual/id/741bh147/t/2/
You don't need to enter your email address on the next page to download. Just leave it blank and enter the security code. I will also upload this manual to FixYa shortly.
I will post another message about the remote when I can find one. It would be helpful to know your location so I can search for local suppliers.
Posted on Oct 15, 2010
I don't have a remote control for my RCA TV and it's on channel 2. It needs to be on channel 3 so that It's compatible with my cable box. How do I change the channel without a remote to channel 3. It
U should have a menu button on your tv.If so try to find the channel setup option if you find this you should b able to manually go through your channels to add & delete the channels you want.If not you will have to go out a buy a universal remote.Make sure that it is compatibl to your tv.They should be a list on the back of the remotes pack stating all the brands that the remote is compatible with.I think you should be able to get one for unde 5 dollars.in the pack it should have an instruction manual.some tvs u can set up very easily & some you might have to keep putting in different codes until it works.Hole this could be some help to you.Good luck.
Apr 19, 2013 | Televison & Video
Sony KV-20S40 stuck on channel fix
I have just got a kv-20s43 and your best bet is to try to restore settings, here, To reset TV to factory settings, turn the TV on, Then, while pressing the reset button on the remote control, press POWER on the TV. The TV will turn itself off, then back on, the original settings wiill be restored... definition: ch. fix- 2-6: Select when you want to control all channel selection through a cable box. Select the appropriate channel(usually 3 or 4) and use the cable box's remote control for channel selection. VIDEO: select from available inputs when you have connected video equipment and you want your TV fixed to it.
Feb 01, 2010 | Sony KV-20S20 20" TV
Can't change channels. don't have remote. need to get channel 3 for cable
Use the buttons located on the TV to switch the channel to 3 or buy a universal remote from any local supermarket/drugstore. Or if it's not a rush, get the original from Ebay based on yor TV model
May 21, 2009 | Samsung TV Remote Control
Im trying to program my remote for Cable...
Target sells a GE Universal Remote Control, 5 Device with learning feature. Its code for the Akai LCT3285TA is 1139.
Other remotes may use different codes, or have none that will control this TV.
Jan 05, 2009 | Akai LCT3285TA 32 in. LCD Television
Akai LCT3285TA-need stand-remotes and 1 component input dont work
Check it out, is that remote you need for your Akai TV?
HERE is another remote but I'm not sure.
Dec 18, 2008 | Akai LCT3285TA 32 in. LCD Television
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
MANUAL BUTTONS
Check the manual page at the link below for instructions on how to use the on screen menu to add channel 3 to the "active channels" list.
http://www.fixya.com/support/p197903-apex_digital_at3208s_32_tv/manual-18780/page-10
Dec 02, 2007 | Apex Digital AT3208S 32" TV
Tv want show
Look at the back of your TV.  Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs.  Wait one second between pushes.  You want to stop just before the source that displays "AV" on TV screen.  It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4.  If you use no cable box, try changing channels on TV to find an active one.  If no luck, make sure your cable service is active (subscription active).  Cable companies disconnect it between residents of an apartment/house.
Oct 19, 2007 | Akai LCT3285TA 32 in. LCD Television
Channel selection
What you need to do is take the remote, go into the menu, find channel scan and do a channel scan to find all the available stations available on this system. Make sure the TV set is in the cable mode and not antenna mode or you wont get any stations above channel 13.
Sep 18, 2006 | RCA F27628 27" TV
Akai LCT3285TA 32 in. LCD Television Logo
137 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
