Question about Lexmark E342n Laser Printer
31 missing or defective cart.
The above error is appearing on the printer and it won't print. I tried changing the cartridge, turning on and off, unpluggin but the error message will not go away . . . HELP!
  • 2 more comments
  • Anonymous Jun 29, 2008
    31missing or defective cart
  • Anonymous Jan 13, 2009
    31 missing or defective cart. message. I have tried the on/off and unplug thing. I also have tried replacing the reset chip and also the toner cart.
  • gebe Jan 21, 2009
    I got exactly the same problem on my Lexmark e120n. I replaced the "old" (approx 5 months) cartridge with a brand new but the result is the same! Invariably the printer detects error 31 when powered on/off.
  • bryan_ccc Feb 09, 2009
    I have the same problem ><, but the 2 solution provided i dont understand, please provide more details, thanks...
  • 300 Answers
Try changing the photoconductor kit
Posted on Jun 02, 2008
  • fjosephg Dec 22, 2010
    Instead of changing the Photoconductor kit I removed mine, wiped off the contacts, and put it back in. I also wiped off the toner cartridge contacts inside the printer with toner cartridge removed. After replacing the toner cartridge it was working again! This was for an IBM Infoprint 1612.
I am getting this error message 920 service fuser error
Posted on Aug 18, 2009
Try removing the orange plastic piece attached to the toner, worked for me ;)
Posted on Sep 08, 2008
Lexmark 352dn 31 missing or defective cart
The 31 error message means that the printer is detecting the toner cartridge is either faulty or not installed properly. You might need to replace your toner cartridge.
Nov 12, 2012 | Lexmark E352dn Laser Printer
Black Cartriddge missing
Try taking out both cartridges from your printer. Re-brick your printer by pulling out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds. When the printer turns on, re-insert your color cartridge then close the cover. If no error appears, re-insert your black cartridge. If error still appears, then it could be a faulty cartridge. It would be best to replace it with a new cartridge, preferably a genuine one. Lexmark products work best when original supplies are used.
Dec 02, 2011 | Lexmark X4270 All-In-One InkJet Printer
31.05 missing or defective cart
31.05 Missing or invalid print cartridge
Check connection J14
Connector name and description SC (smart chip)
The cartridge toner chip no work, change it.
Jul 08, 2011 | Lexmark X340n All-In-One Laser Printer
Dell Photo 926 printer keeps saying that it cant align and wont print after installing new cartridges. Says tape is still on there but it isnt.
1. cancel the alignment .
2. try one cart at a time and only make a copy of a test document ...(press "select" if u get cart missing error ) ...only of the carts is causing the error
3. possible u have defect cart ..or the internal sensor could have gone bad (rare scenario )
4. get a replacement carts...
Oct 25, 2009 | Dell 962 Photo All-In-One InkJet Printer
Lexmark X5470 software rejects generic ink cartridges
Yes this may be the trick for it.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Jul 21, 2009 | Lexmark X5150 All-In-One InkJet Printer
Error 31 lexmark e350d
Possible causes here are;
Most likely, the contacts in the printer not touching the chip properly (hence why it works in another printer). A simple gentle 'tweak' would work in this case.
The other possibility is the firmware version of the (offendig) printer being incompatible with the version of the after-market chip you are using. No solution here, other than trying a DIFFERENT MAKE of chip.
Mar 18, 2009 | Lexmark E350d Laser Printer
Error #12 Shows on my lexmark x4270 all in one how do i clear it
Hello there,
In my experience I've never come across an error #12 on a X4270. I've seen an error 1200 & error 1203 a couple of times. Did you get this error after installing a new cartridge? then there are chances that the new cartridge that you installed is defective. The best way to figure if out is to take both the cartridge out and power recycle the printer with the cartridge out. Check out if the operator panel says "cartridge missing" when it is powered back on. If it doesn't say "cartridge missing" then the printer hardware is defective. You would need to get it serviced. If the printer comes up with "cartridge missing" message, then either one of the two carts that you have is defective. I would suggest you to insert one cart first and close the cover and check if it says "cartridge missing" If it does come up with that message then insert the other cart too.. If you get Error 1203 on after inserting a cart, then that cart is defective and needs to be replaced.
Merry Christmas!
Dec 21, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark c510 error message ;83 photodeve cart missing
See User Reference
http://www.lexmark.com/publications/pdfs/c510/eng/userref.pdf
Understanding printer messages
pages 184 and 185
"Message:
83 Photodev Cart Exhausted
What this message means:
The photodeveloper cartridge is completely used.
What you can do:
Replace the photodeveloper cartridge.
See also: Replacing the photodeveloper cartridge [page 73]
Continuing below
Message:
83 Photodev Cart Life Warning
The photodeveloper cartridge is nearing the end of its life.
What you can do:
• Press Go to clear the message and continue printing.
• Replace the photodeveloper cartridge.
Continuing below
Message:
83 Photodev Cart Missing
The photodeveloper cartridge is either missing or incorrectly
installed.
What you can do:
Correctly install the photodeveloper cartridge to clear the message and continue printing.
See also: Replacing the photodeveloper cartridge [page 73] "
Nov 26, 2008 | Lexmark C510 Laser Printer
Eror 31 in lexmark e350d
Error code 31 is displayed when the top front cover is closed and a defective print cartridge is detected. It may take the printer 10-20 seconds to determine if the print cartridge is defective.
Replace and reinstall the defective toner cartridge.
Oct 28, 2008 | Lexmark E350d Laser Printer
Missing Toner Cartridge
Try first removing all paper from paper trays and then reinserting cartridge, etc.
Sep 23, 2008 | HP LaserJet 3050 All-In-One Printer
Lexmark E342n Laser Printer Logo
6,709 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
