Question about PfaFF Sewing Machines
I have the upgraded 2140. I am doing satin stitching. I was having tension issues and finally got it working for me. I changed thread color and now the top thread is not connecting with the bobbin. It sews a few stitches then stops with the error message and a ball of thread on the under side of the fabric. I have tried different settings and switched to a straight stitch and still have the same problem. This machine is new to me so I am still learning how to use it. Any help will be appreciated.
    New Friend:
  • 194 Answers
It sounds like the problem is actually with the needle thread, remove the spool from the machine, raise the preser foot to the up postiton and the rethread the machine.
Good Luck!
Doug
Posted on Oct 15, 2010
Singer 4423, brand new, bobbin thread coming to the top and top thread to bottom?
Possibly a threading issue.
Remove the top thread completely from the machine.
ALWAYS RAISE the presser foot and rethread the top from the beginning.
Verify that you have followed the thread path exactly.
Check the bobbin to see that it is turning the correct direction in the bobbin case.
Set the top tension to the midway point on the dial.
If bobbin thread appears on the top of the fabric, loosen the top tension. If top thread appears under the fabric, tighten the top tension. FWIW, using two colors will highlight tension issues that would not be apparent when using the same color thread. It is generally recommended, when stitching, to use the same color when sewing to avoid making the stitches more obvious.
If you are using thick or thin thread, there will be a difference in the tension results of stitching. Also, fabric will affect the tension results.
Apr 30, 2018 | Singer Sewing Machines
How do I do a basic satin stitch ? My machine only has patterned satin stitches
A satin stitch is a combination of a wide zig-zag and a short stitch length. Set the stitch width to the maximum. Then while stitching, shorten the stitch length until the threads lay next to each other so no fabric shows between the threads but the threads do not overlap. It would help if you have a satin stitch foot so there is space under the presser foot for the extra threads.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Satin Stitch or Zig Zag Machine Applique stitch
Machine Appliqu Basics 1 Turning right angle corners with satin stitch
Mar 23, 2018 | Sewing Machines
I have a Bernina 145 S activa and I can't get my satin stitch to work , it brings the bobbin thread to the top , what can I do ?
Do you use stabilizer when you are satin stitching? I had a teacher who also hooped the fabric with a spring-loaded embroidery hoop (turned upside-down under the presser foot so the fabric is flat against the needle plate) that would keep the fabric taut.
It is not uncommon for bobbin thread to rise to the top when doing embroidery, satin stitch, etc., especially if you are using lighter-weight thread than usual. You would normally loosen the upper tension so the upper thread will sink into the fabric. However, if loosened upper tension is not doing enough, you may need to adjust bobbin tension when doing embroidery, applique... You might try tightening the bobbin tension just a smidgen to get the bobbin thread to stay below the fabric. Be sure to mark the bobbin case before making any adjustments so you can return it to the original setting when finished with the satin stitch. (If you do a lot of satin stitch or applique, etc., you may want to invest in a separate bobbin case that is set up only for doing that kind of work--saves having to alter the bobbin tension frequently.)
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwiRr76k0sbLAhXBKGMKHei6AfIQFggqMAI&url=http%3A%2F%2Fmachinequilting.mqumag.com%2Fwp-content%2Fuploads%2F2014%2F12%2FSatin-Stitch-Techniques-Part-1.pdf&usg=AFQjCNFXYKp2C-RJEAAUMWwApqZlU895uQ&cad=rja
Mar 16, 2016 | Bernina Sewing Machines
I have a brand new Juki MO-50e and the threads are loose on the back of the fabric, how do I fix this?
  1. . re-thread your machine with a rainbow of colors. (important that you remove the existing threads if you are not sure it is threaded properly.) make sure you are lifting the presser foot while rethreading.
  2. Sew a good 6 inches.
  3. Look to see which threads are the offenders and tighten the co-responding tension knobs a little.
  4. Sew another 6 inches. Examine the result. Adjust tension again if needed.
  5. Work this way until you have the stitch balanced.
  6. Finally when your stitches are perfect. clip the threads at the spools in back. And tie on the coordinating colored thread for your fabric.
Get used to this procedure since it is common to have to adjust tensions when you change fabric. Good luck!
Oct 23, 2014 | Juki MO-644D Mechanical Sewing Machine
Upper thread keeps breaking
Symptoms like this are typically tension or threading problems.
Grab some dental floss (unwaxed) completely remove the top thread. Lift the foot. Run your floss between any tension discs.
Get out your manual and make sure you thread it properly. Have the proper retention disc on the thread spindle if your machine has one. Make sure the thread is unspooling the correct way. Thread the machine with the foot up always. ...
Test sew on scrap. still breaking? Change the needle (make sure it's the right needle for the project.) Test sew. Finally check your tension and stitch length. Thicker materials typically need longer stitches. Loosen the tension a little at a time. testing between changes.
If none of those things work... check your needle throat plate and foot. There could be a burr causing the problem.
Jul 05, 2012 | Bernina Sewing Machines
Distorted embroidery with Designer SE
have you tried changing the needle
try rethreading the machine top & bottom
also clean under needle plate area & bobbin area for loose threads & lint
Jan 27, 2012 | Husqvarna Designer I
How do you adjust the tension on a Bernina 180
There are two tension adjustments, which should be done with a proper set of weight gauges - top and bottom thread tension should be carefully balanced to get the best stitch formation. It is best that you assume the top tension is correct and adjust the bobbin tension to match. Load the bobbin with thread of one colour and put a spool of the same thread but a different colour on the top. Thread-up the machine, load the bobbin and sew-off a satin-stitch on max width zig-zag. In this configuration, there should be a very small 'bead' of the top thread showing along each side of the satin-stitch on the underside of the material. If there's excessive top showing, the bobbin tension is too high and if none, the bobbin tension is too low. To adjust the tension, remove the bobbin case and you will see a spring around the edge with two screws through it. One of the screws holds the spring in place and the other adjusts the tension - this is furthest from the edge of the spring and is in a small 'cup' in the spring itself. To reduce tension, turn the screw VERY SLIGHTLY anticlockwise and to increase it turn it clockwise. Make very slight adjustments and re-check sewing-off the satin-stitch every time until you get the required thin line of top showing down each side of the stitch on the underside. Ideally this should be done with Mettler Metrosene thread, but as we're just balancing against the top tension, it shouldn't matter too much provided you use a good thread top and bottom.
Jan 27, 2012 | Bernina Artista 180
I have a Huskystar C10. I cannot adjust the tension properly since having a sewing jam-up while I was satin stitching. The top thread leaves loops on the bottom on the fabric and the bobbin (which is a...
There is one way out. Give the sewing m/c a thorough servicing job, Clear all the pieces of cloth/fabric/threads, etc Remove the bobbin and load afresh. Clear out the toothed sliders which pulls the cloth while stitching. the thread being used for stitching passes a sort of loop, the tension being controlled by how much the pressure the spring can exert such that depending on the material being stitched. Specially after stitching satin, which is tricky material to stitch in a sewing m/c since the cloth is slippery. Also clear sewing jam and the metal teeth like rack which pushes the cloth for the next stitch to start. This area if cleaned up properly and a little bit of oiling on the spring loader and the spindle assembly which moves up & down...............................sudeep
Aug 07, 2009 | Sewing Machines
When appliqueing in stitch 11 the thread kees looping...
I believe stitch 11 is a zig zag so you are probably decreasing the length to get a satin stitch. You will get a better satin stitch if you select it directly. I think that it is about 29. The machine forms the satin stitch differently than the zig zag and it should look better. If you still get loops on top, you may need to have a qualified technician check the needle to hook clearance. If this distance is too great, the machine skips stitches and you will form loops. Several other adjustments may be needed to get a perfect stitch and a qualified Husqvarna technician should be able to take care of this problem for you.
Nov 23, 2008 | Husqvarna Viking 1
Bobbin tension
Bobbin Tension Adjustment:
1. Do you have a genuine Bernina bobbin casing and not an Oriental copy? If yes, proceed as follows:
2. To set the bobbin tension, wind a genuine Bernina bobbin with Metrosene thread, type 1161 white thread as your "gaging thread". Load the bobbin case so that the bobbin turns CW. Attach the bobbin case to the hook body from the machine. Wind a couple of revolutions of thread around your index finger with the assembled bobbin case and hook body dangling about 6" to 12" below your finger. Gently and rapidly move your finger back and forth in a "sideways" motion about 1/4" to create a gentle vibration on the bobbin assembly. (Do not shake the bobbin assembly up and down). When the tension is right, the bobbin assembly should fall slowly and as you stop the movement, the assembly should stop.
The adjustment is found on the small screw, holding the flat tension spring against the bobbin case. If the tension is too tight, one must loosen the screw (past) the desired location and always make the adjustment by tightening to the correct position.
There are other checks for tension imbalance and associated problems on the bobbin case that I won't go into here. For further information I can help you later on.
Top Tension Adjustment:
1. The top tension rarely changes and can be depended on throughout the life of that machine providing that tension assembly is maintained occasionally. This can be done by blowing out the tension disks with the presser bar lever in the up position. One can also drag or pull a piece of sized percale or muslin through the disks with the presser bar lever in a down position. Perhaps both methods can be employed.
2. Load the top of the machine with Metrosene 1161 thread in a dissimilar color. I prefer to use a pastel color so as not to create an optical illusion of imbalanced tension.
3. Sew a satin stitch (.25 on the Nova 900) in sized cotton muslin with a thin piece of paper between two plys of fabric. The width should not exceed 4.5mm (standard width on the 900 Nova), however the newer machines have wider stitch widths so one must adjust as specified. The result will be a slight amount of top thread in symmetric lines on both the right and left sides of the satin stitch.
Typically, the top tension will not need adjusting. If the Nova 900 needs adjustment, please ask for additional help.
Sep 11, 2008 | Bernina 1008
Sewing Machines Logo
70 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
