Question about Kodak Carousel 4600 Slide Projector
Slides will not advamce when you push lever. It is 50 yrs old.
    President:
  • Kodak Master
  • 412 Answers
The KODAK Carousel 4600 was manufactured from 1981 to 2004. If the tray won't advance with the push button on the projector, but will reverse, then it is a contact problem under the handle. If it doesn't cycle in forward OR reverse, but the "SELECT" feature does work, then there is a problem with the cycle (orange) wiring or the slide-change mechanism requires an adjustment. If forward, reverse and select ALL don't work, chances are the low-voltage side of the power motor is no longer providing the required voltage. An authorized repair dealer can help you sort this out.
Posted on Nov 03, 2010
Kirby g10d, I shampooded the carpet then put it back together and it wont start 4/12 yrs old used approximately 50 times. Any ideas?
Make sure the emptor at the. Bottom of the bag assembly is turned all the way clockwise. It pushes in on lever on the switch. It won't run if the lever is not pushed all the way.
Jan 31, 2015 | Kirby G10 Sentria Vacuum Cleaner...
Kenmore fridge model 596 - 79213014 2 yrs old accumulates ice at the bottom freezer. The fridge has built it ice maker but we did not opt for that option. Can anyone pls advise how tofix the problem?
IS THERE A CONTAINER FOR THE ICE TO COLLECT IN UNDER THE ICEMAKER??? IF NOT YOU WILL NEED TO GET OR ORDER ONE..
NEXT THERE IS A WIRE LEVER ON THE RIGHT SIDE OF THE ICE MAKER. WHEN THE ICE PUSHED THAT LEVER UP IT WILL QUIT MAKING ICE. WITH YOUR HAND GENTLY LIFT THE LEVER UP UNTIL IT STAYS LOCKED IN THE UP POSITION... ONCE IT IS IN THE UP POSITION ... IT WILL NOT PRODUCE ANY ICE.
Dec 29, 2014 | Kenmore Refrigerators
Value Winchester 94 over 50 yrs old
Value of a pre-64 Winchester M94 depends entirely on condition. Check gunsamerica or gunsinternational dot coms for current prices.
There is a BIG difference between '63 and '64. Look for the screw in the center front of the lever plate. Pre-64 has it, post doesn't.
Oct 30, 2014 | Winchester Model 94 Sporter 30-30
Replace headlight
Follow the process below to replace your headlight:
  • Prop open your hood and locate the release lever for the headlight assembly, the lever is approximately 2 inches under the two upper mounting bolts that hold the fender in place.
  • Press down on the release lever and then push it back up. Pull the headlight assembly forward and slide it out of your Beetle.
  • Unplug the electrical connector from the backside of the assembly. Look toward the top part of the backside of the assembly for a black plastic tab. Push down on the tab and pull the headlight cover up and out.
  • Pull the retaining clip off of the old bulb and remove the old bulb from the assembly by pulling it straight out. Align the bulb correctly with the headlight assembly by matching the marked tabs on the bulb with the raised notches on the assembly. Set the bulb inside the assembly, pushing it down carefully.
  • Push the ends of the retaining clip into the small holes on either side of the new bulb and snap the headlight cover on to secure it.
Take care and good luck
Dec 02, 2010 | 2001 Volkswagen Beetle
I bought a used kodak 650 carousel slide projector and i can't get the slide tray to load. Is it because it came with a 140 slide tray instead of an 80 slide tray?
The KODAK Carousel 650 was manufactured approximately between 1964 and 1971.
Try removing the tray and pressing the cycle button(s) on the side of the projector. Watch the levers in the cut-out on the top of the projector. The lever closest to the rear of the projector should move back & forth (as you actuate the cycle buttons). The lever toward the front of the projector should extend and push forward (front of the projector) when you push the "forward" button, & extend and push toward the rear in reverse. If you are not seeing these levers move as described, then the chances of your projector needing a repair are likely. The good news: parts are still available. The bad news: You will have to find a factory-trained repair dealer to make the repairs for you.
Aug 10, 2010 | Office Equipment & Supplies
How do you change the headlight on a 1987 Dodge Ram 50
Hi
Thanks for using FixYa. There is a lever under the hood on the headlight casing which is fragile. Now pull the lever up or down. Push the entire headlight casing out toward the front of the car. The casing will hang over on the bumper and pull out the headlight and plug the new one in. Push the casing back in and lock the casing in with the lever. There might be some sticky adhesive holding the light in, so you may have to push/pull hard to get it to slide out and replace it.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 28, 2009 | 1985 Dodge Ram 50
How do i replace the toner?
Open the white door
pull bypass door towards you
move the blue lever towards you
slide lever to the side ,lift out the old cartridge
pull tape on new toner
snap in new toner firmly
push blue lever forward
close doors
Oct 27, 2009 | Kyocera Copystar CS-1820 Black and White...
Soap dispenser door came off
First, look at the spring from sliding dispenser cover - it has 2 ends with loops - one end has a little "curve" in it; other end is "straight", no curve.
Sliding cover and lever of dispenser have little knobs for attaching the spring.
The loop of "curved" end has to be pushed and attached to sliding cover,
the loop of "straight" end has to be pushed and attached to lever of dispenser (the lever is blue color, other parts are gray).
After spring is attached to both - sliding cover and lever, push the cover first at upper groove, then at lower groove - It should slide easily.
May 26, 2009 | Gaggenau GI936-760 Dishwasher
Daimler V12 6litre.
I recently purchased a 95 Jag XJ12, April 12.
I could not find the right manuals for self-repairs.
I have the OEM Jag DVD Manuals but they lack diagram details in some areas but are a good source of info.
Recently, bought website help at, $50 5 yrs,
http://www.alldatadiy.com/contact/index.html
It has more detail diagrams.
I would like to keep in touch to share info.
victorhdz@ivisionis.com
Jun 01, 2008 | 1995 Jaguar XJ12
Kodak Carousel 4600 Slide Projector Logo
331 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
