When i put in in the laptop it doesn't charge
    Genius:
  • 1,325 Answers
Pleas eb ealot more specific as to what issue you have -- i need S/N and model of computer
Posted on Oct 15, 2010
My MSI GT680 Notebook charging system doesnt work. when I plug my charger into the wall the green light indicator comes on, then when I put the plug into the laptop the light turns off and it doesn
Hello! It seems that you have a problem with the laptop charger connector. It maybe in short circuit. You can try to look for some electronic workshop that works with reballing, BGA solder, etc., that might change it. In Portugal we have some, so I think in other countries you can find them to.
Apr 03, 2013 | MSI Microstar GT680R-008US 15.6" Notebook...
New battery charging very slowly?
Power off your Laptop, unplug the power cable from the laptop as well, take the battery out and wait for about 5 minutes. Put the battery back in, make sure it is seated properly. Plug the laptop back in and power it on an see if that charges the battery quicker. If it doesn't you may have a bad battery, and I would contact the place you bought it and ask for an exchange.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/brandon_f3a03ecb14f80b8d
Oct 16, 2012 | Compaq Presario CQ61-310US Laptop
Laptop wont start.
Remove the battery and unplug the power cord for 5 minutes, put in the either the battery or the powercord and power on.
if it doesn't power on, make sure the charging light is lit on the front of the laptop when the power adapter is inserted and plugged in properly.
light blinking when you power on means battery low / no power.
If the problem doesn't go away you need to contact acer for warranty service if you are outside warranty contact a local repairer.
Jul 20, 2012 | Acer Extensa 5420-5687 Notebook
Hi I have a Toshiba laptop model no.psl2xu-ookoof and it doesn't charge anymore so what do I do
If the laptop works only off the Power Cord and the battery is not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let the latop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in and remove the power cord. If it won't boot or shuts down then the battery is dead and needs to be replaced if the power cord is ok.
Mar 26, 2012 | Toshiba Computers & Internet
Power light flashes put unit doesn't power on
Laptop is having a power problem. Problem is either from the Adapter or battery (optional). Or the power part on the mother board has a shot.
Jan 26, 2012 | Gateway M465-E Notebook
My laptop is completely dead, fine yesterday. Today no lights, sounds nothing. I tried removing the battery , unplugging no response. Thanks,
Remove the battery for at least 3 minutes... Then put it back and then plug in the charger and switch on the charger. If the battery is completely drained, it would take a while for the charging to initiate. Please have patience and leave it on charging even though without the charging indication for at least an hour. After that still if the charging indicator doesn't lit, then its definitely your charger or laptop. You will need to take it to a service centre in that case.
Nov 03, 2011 | Compaq Presario 2170US Notebook
I have put the charger in my laptop and the charger light is not coming on
Please check the voltage on the output of the adapter and if this is absent then the adapter is faulty. check the link below for tips:
http://www.fixya.com/support/r5164850-laptop_power_supply
However if there is voltage on the pins then check the voltage on the battery terminal pins in the laptop. If absent then the motherboard is faulty.
you need to use a multimeter to check and track the path of the voltage/current to confirm the area of fault in the charging section.
Aug 16, 2011 | Computers & Internet
Battery power indicator light has suddenly stopped coming on. Can I still use my laptop?
If it works, yes you can. It maybe that the battery went dead.
Try removing the battery for 10 minutes and put it back and see if the laptop powers on. If it doesn't, connect the power cord and see if it is charging. If not, then most likely battery is dead.
You can buy batteries from stores like ebay.
May 03, 2011 | Medion MD-41017 Notebook
Put in a branbd new battery. Power adapter is OK.
Your motherboard does not need replacing provided the problem is the power socket on the motherboard.
If the power adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Nov 15, 2009 | Compaq Presario 3045US Notebook
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
