Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
I have the Xony Vega KDF-60XS955. It turns off about every 30 seconds. Stays off for about 30 seconds then comes back on. When it goes off the green power indicator light flashes continuous (no pauses) until it comes back on. Any thoughts?
  • 1,557 Answers
It seems to have an internal intermitent fault have it looked at
Posted on Oct 15, 2010
  • gerardwendy Oct 15, 2010
    I looked at it a bit more. When you turn it off then back on the red indicator light is flashing 5 times. The lamp is about 6 years old and never been replaced. Does it make sense to replace that and see if it fixes the problem before calling a service person?
  • sonic boom electronics
    sonic boom electronics Oct 18, 2010
    no if it was a lamp problem on screen would say replace lamp a blown lamp wont stop the tv from turning on it really needs a pro to look at it its not an easy fix sir
    kind regards
    sonicboomelectronics@hotmail.com
Blinking green light
It is likely that the power supply is failing. It tries to start and powers up briefly then shuts down.
Oct 28, 2013 | Sony Grand WEGA KDF-60XS955 60" Rear...
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Picture is good but it stays on for about 30 seconds then goes off for about 30 seconds or so ,the lamp is coming on then going off ,what is the problem, I have replaced the lamp one time before.
Pull the lamp out and have a look at it. If you don't know what you are looking for in regards to damage, have a look at my Tips & Tricks. I have a tutorial on projection lamps. It will show you where to look when inspecting a lamp. I hope this was helpful, best wishes.
Apr 02, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
The picture goes off, the power/standby light
Sony KDF-60XS955 picture goes and power/standby light light flashes
Most likely you have bulb failure. First step in troubleshooting is "Change the Lamp or Bulb". Lightning, power line bumps and collisions with vacuum cleaners can all shorten lamp life. Rough handling in shipment can also happen without your knowledge.
+90% of all Sony LCD Rear Projector "No Picture or Intermittent Picture" faults are related to bulb failure.
If new lamp does not improve the situation, then hands-on troubleshooting by someone that has parts and knows how the unit works is the only practical remedy.
easyab
Mar 14, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony KDF-60XS 955 Video & audio goes out, comes back on
If the lamp fails to fire yes you will loose audio as well.
Aug 31, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand Wega KDF-60XS955 Picture comes on and then goes off.
You have a bad lamp. Sometimes when the lamp gets old, it doesn't fail and open like they usually do. Instead, the reflector gets cloudy, and instead of reflecting the light, it converts it into heat. As the lamp heats up, it draws more power, eventually to the point where the TV senses it drawing too much power and shuts down, going into a reset cycle. replace the lamp and use an original Sony lamp, as the aftermarket lamps are known trouble makers. Be sure to rate this solution. Thanks!
Dec 13, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Goes off and on
I replaced the lamp today in my KDF-60XS955 and it has worked perfectly since then. I purchased the lamp from sony, costs more but I got the correct part. Might be your problem since I had similar symtoms. 30 green flashes and picture/sound cycled off and on about every thirty seconds. Good luck. Chrismickey
Sep 12, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
101 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
