Question about Crane Hello Kitty Humidifier
My Crane Hello Kitty humidifier doesn't work...The power does not get on when I plug it. I think it is an electrical problem. I would like to dismantle it but I can't find the way to separate the bottom part of it. No screws... Could you tell me how to do to access the electrical circuits... Thanks for helping.
5 Suggested Answers
  • 123 Answers
SOURCE: crane penguin humidifier
This is the link to your manual:
http://www.crane-usa.com/manuals/HumidifierManual2008.pdf
Hopefully the manual helps you getting it to work. If not come back and give more info about the problem.
Good Luck.
Posted on Apr 21, 2008
  • 15 Answers
SOURCE: On/Off function
the kitty will turn off if you rotate the dail all the way to off (straight up). Look at the pink arrow on the dial. You will feel that the knob does not want to go any further when you are at "on" which is the lowest setting and no steam comes out. But you have to go all the way to off.
The elephant and frog models have actual on/off switches but this one its just the dail.
Posted on Dec 22, 2009
  • 23 Answers
SOURCE: anyone know where i can
I have an elephant humidifier with a broken fan. I just posted the problem, but I doubt there is a solution. I'm sure the tanks are interchangeable from looking at the manual, if you don't mind an elephant (I don't know if the lid is interchangeable). I would hate to throw it out and have one more thing in the landfill. Maybe I could send it to you?
Posted on Jan 09, 2011
  • 23 Answers
SOURCE: the red ligt on with water inside
FROM TROUBLESHOOTING SECTION OF MANUAL:
Humidifier power light is staying red and not turning green Humidifier is working than stops: ? Ensure that water level sensor is assembled properly. ? Clean water float ? Call service center and request replacement water float
Hello kitty humidefier has started making a loud noise and sometimes it goes off but more often noise stays on longer. Almost sounds like a loud fan. What do I do?
This sounds like the electric motor bushings are worn which will cause vibration throughout the unit. If it is relatively new I recommend checking the warranty information and returning it to the retailer for a replacement. If you have gotten your money out of it but cannot tolerate the noise, then a replacement is in order as well. The cost of replacing the motor and installing it will most likely exceed the cost of a new humidifer.
Dec 08, 2010 | Crane Hello Kitty Humidifier
My humidifier all of a sudden just stopped working. Can you tell me of any common issues and their remedies for this humidifier ?
From the troubleshooting section of the manual (http://www.crane-usa.com/manuals/HumidifierManual2008.pdf):
Problem Humidifier power light is staying red and not turning green Humidifier is working than stops: ? Solution Ensure that water level sensor is assembled properly. ? Clean water float ? Call service center and request replacement water float ? If humidifier does not work at all: ? Ensure it is properly plugged into a power outlet. ? Check that the switch is in the ON position. ? If Power On indicator light does not come on, bring to authorized service station.
Nov 01, 2010 | Crane Frog EE-3191 1 Gallon Humidifier
Making loud sound when running. It is on a flat hard suface. Sounds like the fan is struggling to work. How to remove the fan to see if this is the problem. Appears to be a sealed unit
The unit is not sealed. You'll find barely visible white covers over the holes where there are screws you can remove. Then the mid cover comes off and you can access the entire electronic configuration underneath including the fan. Looks almost like a PC fan but it is 18V. I am not sure where to find a replacement...:(
Aug 09, 2010 | Crane Hello Kitty Humidifier
I have had my Hello Kitty Humidifier about a year and a half. I have been very pleased, but yesterday it stopped working. It puts out steam, but not enough to make it out the top. It kind of bubbles down...
sounds like the fan in the bottom does not have enough space. make sure the humidifer is on a flat hard surface. If its on carpet or other soft surface the fan can't push air out and the vapor won't come out.
Dec 02, 2009 | Crane Hello Kitty Humidifier
The red ligt on with water inside
Jan 23, 2009 | Crane Frog EE-3191 1 Gallon Humidifier
On/Off function
Apr 21, 2008 | Crane Hello Kitty Humidifier
Very little water left/ fills up and leaks
**With the unit unplugged**
the float sensor is probably getting sticky with residue and buildup (lime, grime, etc). Try cleaning the little float and that area. It should move easily when clean.
Mar 30, 2008 | Crane Hello Kitty Humidifier
Crane Hello Kitty Humidifier Logo
81 people viewed this question
Top Crane Humidifiers Experts
Danny Kuhlmann
solver2010
Tom Chichester
Are you a Crane Humidifier Expert? Answer questions, earn points and help others
