Question about Kenmore Oasis HE 27082 Top Load Washer
Oasis washer f 51 and not draining all the water out of the clothes
  • 4 Answers
HI; Had the similar problem with machine not draining. Ran diagnostics and when it reach C7 step it just did nothing. took motor apart and found nothing, was taking the drain pump apart and then noticed a wire to the pump broken. It was a clean break. who knows how it happned. repaired wire and ran another test and everything worked fine. Ran the machine with no wash load and it performed aok.
So maybe you have a broken wire that has not fell apart yet and just rubbing together a little, that is the 2 small red wire going to the pump.
Posted on Jan 09, 2009
Lumpy816 is right, however to make the fix permanent, get some "Stabilant" and wipe the contacts once they are cleaned with the sandpaper.
Posted on Jun 21, 2008
I had this same problem. The repairman replaced the computer element on the bottom of the machine. It ran for two washes. The repairman came back - the solution - new computer element for the bottom and a new computer circuit board. I know - Problems all the time. Good luck.
Posted on Jun 17, 2008
  • 246 Answers
F51 error code is beacause the computer board did not receive input from the motor on the bottom. Unplug the washer, pull the machine forward and tilt the machine back. On the bottom you will see a large white wheel with a silver allen screw in the middle I think it is a 6mm allen wrech that takes it off. Once you remove the screw and drop the white wheel, there will be a large coil of wires with 4 5/16 screws holding it on, remove these scres and drop the coils. On the right hand side you will see a connector with three wires , unplug it. Use sand paper or a scraping tool to clean all 3 male sides of the connectors. Reverse process to re-assemble.
Posted on Jun 15, 2008
Kenmore oasis hf 2706 2603 has not cleaned since new 6yrs old seems not enough water, is the amount adjustable?
Possible that the inlet is clogged and needs to be flushed out. Also the drain could be choked and allow to drain the water after a cycle.
If this was not done for a long period the performance would drop.The water level is set according to the clothes quantity and is adjustable. If not the water pressure sensor can be faulty.
Oct 02, 2013 | Kenmore Oasis HE 27082 Top Load Washer
The washer won't start and is making a humming noise and displaying Ld
LD IS FOR LONG DRAIN. , If it takes to long to drain the computer will shut in down. Either some clothing has gotten under the basket and is restricting the water flow to the drain pump,or the drain pump its self is damaged. when the senses all the water has not been pumped out it will let the washer start
Sep 17, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Top load washer is powerless and locked
use a wet dry shop vac attahc it to the end os the drain hose to remove the water that is in the tub then plug it back in and this should allow you to get your clothes out.
If the unit is not draining then you need to cjeck the drain pump and hoses for any thing that may be restricting or blocking the flow of water
Jun 09, 2010 | Kenmore Oasis HE 27082 Top Load Washer
If the washer machine kenmore elite oasis he is draining water is it a water pump or draining pump?
The drain pump evacuates the water from the tub and down the drain pipe. There is only a solenoid valve assembly to let water into the washer.
Feb 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis top load model 580 error F51
There is no reason or condition that will requir having to doing that for correct operation. That indicates the board as being defective. Just asking if your water is draining correctly? When you start cycle, after it finnishes loading the water, can you get it to drain at all. If you can, the board is the problem.
Sep 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Machine went dead with clothes and water in it
with putty knife press in along front edge between top and front about 2-3 ins from outer edges on release clips top will lift up suspect bad lock assembly
Jul 04, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Refer to manual; your filter could be blocked, or something could be clogged in the drain pipes. Plug off the wall & check the pipes, filter first.
Jun 06, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
76 people viewed this question
Sal De
 Brian Main
Brian Main
