Question about Zanussi ZWF1420W Front Load Washer
I've got a zanussi aquacycle zwf 1421w and it has started stopping mid cycle. The drum seems to fill with water and runs for a short while before emptying and indicating that the cycle is finished. The clothes are still soaking wet and don't appear to be washing all that well. Also, when indicating that the cycle is finished, the door has stopped opening and will only do so once the washer has been switched to '0'. About a week ago I noticed a slight smell coming from the washing machine, however assumed it was because the door had been kept closed (I usually leave it slightly open). Any advice?
  • 1462 Answers
SOURCE: the Washing Machine fills and then empties with not running a wash cycle
possible a pressure stat fault. some pressure stats have a too high water detector which turns on pump
Posted on Mar 27, 2007
  • 1462 Answers
SOURCE: Drum filling with water when machine switched off
what you refer to as the overflow cap is the cover to the filter which you should remove regularly and check. however nothing to do with your problem. the water could be coming from two sources: first, if the drain is plumbed in under the sink, water can flow into the machine every time you empty the sink. the cure is to put the drain hose up as far as possible in a swan neck. secondly, the intake water valves could be leaking and the only cure then is to replace them
Posted on May 04, 2007
SOURCE: Zanussi aquacycle 1200 smells.
1. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it run for a minute or two, then stop the cycle, open the lid and slowly add the gallon of hot tap water. Don't overfill — you just want to raise the water level so that it is able to reach and clean the inside top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle. In a couple of minutes, stop it again and just let it sit for at least 30 minutes. Afterward, let the cycle finish, and open the lid to air out the inside.
I got it from this link: http://answers.yahoo.com/question/index?qid=20060827101905AANuYg4
and here:
http://deseretnews.com/dn/view/0,1249,600124768,00.html
Posted on Aug 13, 2008
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
barkencoa
  • 3463 Answers
SOURCE: Zanussi Aquacycle 1050. My washing machine seemed to stop spinnin
Locate the filter at the botton front right of washer, behind a drop down cover.
Unscrew anti- clockwise to remove and clean.
If still no go, then you need to check the brushes in the motor.
Hope this helps.
Posted on Dec 31, 2009
Why did my washer stop mid cycle and now won't work at all?
Hope your warranty is still in effect. It sounds like your control board has an electronic problem that will require replacement; typically around $135 for the part and $110 for the service visit.
Aug 21, 2014 | Zanussi Washing Machines
Zanussi aquacycle 400
all washers have water level sensors and most of them are fitted with water level via filling a tube with water the switch is activated telling the machine to turn off the water
most of the time the tube gets clogged up with soaps etc.,
clean the tube and check the operational of the switch .
Nov 24, 2017 | Washing Machines
Drum fills withe water when machine is not in use
Can you turn off water to machine? The water seleniod needs to be replaced this lets water in the switch sounds like it's stuck open.
Jul 26, 2010 | Zanussi ZWF1420W Front Load Washer
Zanussi zwf 1020w drum not revolving
The drum will not rotate until the draining process is satisfied, there is either something in the pump or pump is broken
Oct 20, 2008 | Zanussi FJD1666W Front Load Washer
Zanussi aquacycle 1200 smells coming from between the drum and casing.Suspect it is caused by a build up of slime etc.
and here:
Jul 02, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi aquacycle 1000 washing machine spin problem
this is possible due to a bearing collapse or bearing spider broken. this causes drum pulley to be out of line and the belt comes off
May 29, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWF 1421W power failure
most likely caquse is door interlock. only way for you to test is to substitute
May 08, 2007 | Zanussi ZWF1420W Front Load Washer
Zanussi ZWF1420W Front Load Washer Logo
89 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
