Question about Garden
I have a northern star log splitter, model #1170d. it has a Briggs stratton 5 hp engine on it. All of a sudden when you try to use it, it will only run 3or 4 minutes and die. The exhaust will get red hot in this shor of time. please help
  • 45 Answers
SOURCE: My Briggs & Stratton 5 HP engine stops running when it gets hot.
ok,let's assume that you have a good set of points and condenser.and that the air gap is set correctly.i believe it's .20 thousands. when they are subjected to heat.magnets can lose their magnetic field strength.so i would look at my coil and then flywheel. hope this helps
Posted on Apr 30, 2009
  • 10865 Answers
SOURCE: White Smoke comming out of Briggs and Stratton 21 HP V2 engine.
The white smoke may have been caused by having water in the fuel, or fuel tank [due to condensation or exposure to rain and snow]. It may have been that the mower got tipped for cleaning purposes, blade inspection, etc. and oil from the low lying oil pan got into the piston.
Either way, I recommend installing a brand new spark plug and new gasoline [you can purchase a little gas siphoning hose for a dollar or so at any auto parts store] If you have gasoline left over in a can from last year it is safe to use it in your car as it mixes with lots of new gas, but not in your small mower tank as it is basically outdated fuel.
Posted on May 19, 2009
  • 95 Answers
SOURCE: 5 hp briggs and stratton mower is hard starting
Most times the briggs engines start hard when hot because the exhaust valve is leaking at the seat.If you hear a hissing noise from the muffler when you are trying to start instead of a good crisp pop it that is a good indication the valve is burnt.To be sure you would have to have a compression or leak down test done on engine.A valve job is not an easy job if you don't have the right tools.
Posted on Aug 01, 2009
Dustybobcat
  • 39 Answers
SOURCE: briggs and stratton platinum 5.5 hp ohv i/c engine
The carby probably has a block either in the idle, jet or float valve. These are both internal to the carby. To fix this, you will need to pull the carby off the engine and get it serviced by a tradesman. If you feel keen, split the carby apart, then run a very small drill bit (.38-.7mm) through the Jets by hand. Also spray carby cleaner in there and blow out with air blower.
Posted on Mar 14, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Replaced camshaft in a Briggs and Stratton engine,
Hi and welcome to FixYa. I am Kelly.
First I will list your engine parts manual here:
http://www.briggsandstratton.com/maint_repair/manual_and_more/docmanualdetails.aspx?showpdf=MS5449_LO.pdf
Now lets get your engine going correctly.
This is how to clean the fuel passages in the carb.
Here is what you need to do:
1. Fuel selector off
2. Remove float bowl mounting screws and nut
3. Remove the BRASS Jet / Orifice in the very bottom of the venturi tube inside the pickup tube. (Flat blade screwdriver) Hold the Orifice up to the light. You should see a pinhole. If it is not clear clean the orifice but do not force anything through the hole.
4. Underneath the Orifice there is yet another BRASS tube that you need to remove. (Flat blade screwdriver) Make sure all of the holes in the tube are clear. The tube will be over 2 inches long. Clean it and reinstall it.
5. Reinstall the Orifice.
6. Using a catch fuel container turn on the fuel selector. Fuel should flow at a good rate. GENTLY lift the float assy level and make sure fuel flow shuts off. When you drop the float again fuel should flow.
If you do not have fuel flow at this point the needle and seat will need to be inspected. Fuel selector OFF.
(The following procedure is to be done only if there is no fuel flow with fuel selector on.)
a. Remove the silver float pivot pin retaining screw
b. Drop the Float down (The needle will come off with the float. NOTE the position)
c. Inspect the tapered rubber of the needle If should be pointed. If it is not pointed then the rubber tip is stuck inside the seat.
d. Clean the seat hole ONLY if obstructed. (Easily damaged)
e. FUEL Selector on then off fuel should rapidly flow through the needle seat.
f. Renistall Float and needle making sure to get the pivot / hinge pin installed correctly and reinstall the silver retaining screw.
g. Fuel selector ON. Raise and lower float checking for free movement and fuel flow.
7. If there still is no fuel flow at this point remove the fuel hose from the carb and check fuel flow. If no flow check that gas tank exit hole, fuel filter (if installed) and the selector valve assy for obstructions. Reassemble connections.
FUEL FLOW IS GOOD
8. BEFORE you install the float bowl inspect the bowl nut. There are 2 holes in the side of the nut where it screws in to the bottom of the carb that must be clear.
9. Install Float bowl mounting screws and nut. Check for leaks.
10. Test engine.
That should do it. (carb cleaning 101)
Thanks for using FixYa.
Kelly
Posted on Apr 10, 2010
I HAVE NO SPARK ON MY BRIGGS AND STRATON MOTOR
Try this locate your coil / magneto and disconnect the kill "shut off wire " and try to start if it starts your switch may be bad or wire broken..if still no spark using a rubber handled pliers ...Pull your plug wire and place a screwdriver or similar metal piece and in the plug wire now bring the screw driver close to the engine block or Frame if spark it is your plug..if not your coil needs replaced...not a hard job just use a business card to set clearance on your coil..good luck
Jan 18, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
I need a replacement foam air filter element for the Briggs and Stratton engine on a Didier log splitter Model 130202
you need briggs part number 27987
and assume this is a horizontal shaft engine
your local small engine shop should have one
cheers pauly46
Jan 17, 2011 | Garden
Engine turns over but doesn't fire.
check it for spark then check if it is getting fuel cuz that might be the problem
Jun 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Have a Yard Machine riding mower with 21hp Briggs Stratton engine OHV/IC V-Twin. when I turn on key nothing happens. How many switches control the start motor from the ignition and where are they located....
It depends on the model but most riders have the following;
1. Seat switch
2. Brake pedal switch
3. PTO switch
4. Neutral switch (if its a shift model)
All need to be closed in order to start engine.
Jun 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
What type of oil is used in an Intek 6.5 engine? Powers a log splitter, cold weather application.
30 weight, should hold about 2 qts. Use a synthetic oil, will flow a little better when cold than conventional.
Jan 12, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
146 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
