Question about Casio DW9052-1V Wrist Watch
Looking fo ra parts break down for the DW-9052 Casio. Was replacing the battery and the spring and a little metal tab fell out. trying to find out where they go.
    Scholar:
  • 101 Answers
If its a tiny little spring then those springs you will need to put them in a little hole on top of the movement so they press up against the back of the case when y ou put it on . I am not sure what metal tab you are referring to , but I am pretty sure it is the tab that goes on top of the battery and holds it down.
Posted on Oct 15, 2010
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    Changed battery .A square piece of metal the size of match head fell out. No alarm or light, casio forester FT200
    mcdevito75 here, Of couse without the watch and piece of metal that fell out it"s very hard to say. Most likely it was part of the lock-down tab to keep the battery in place, in any event don"t lose that piece of metal. If your casio is working ok don"t worry about it, just don"t lose that piece of metal that fell out.
    Jul 05, 2010 | Casio Forester PAS400B-5V Wrist Watch
    Where can we buy replacement watch bands for this watch Casio DW-9052
    You can buy genuine Casio watch bands from www.tiktox.com
    Check out there website first.You can order online,or give them a call.
    Make sure you have measured the shoulder correctly when ordering a new watch band.Your watch model number will help in the search on their website.
    Apr 07, 2010 | Casio DW9052-1V Wrist Watch
    Casio PRO TREK error 'OP EN' Display frozen with the above msg. None of the buttons - except the light - works. Whats wrong .. battery charge shows FULL
    The problems is very simple: On the back cover (inside) is a little Cu metal Part. This part is glued to back cover using a poor glue (rubbered glue) and, in time, is moving from original position. You must put back this parts to original positin ( a little hole inside of back cover) and glue using a good glue. When the back cover is mounted , this part must have a ferm contact with two springs from mechanism (sensor for back cover open). If beatwin this springs isn't a electric short (using Cu metal parts) the internal mechanism of watch "see" the back cover is open and show "OPEN" on screen!
    Mar 22, 2010 | Casio Watches
    Casio g shock dw-9052 how to change from military time to standard time
    You can get instructions from the Casio web site which will tell you how to set your watch..
    Go to the casio web site "casio.com".
    Select "support" and the "manuals", watches;
    Accept terms
    Select "watch manual archive"
    Read the number of the back of your watch and enter it into the search box
    Feb 22, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
    Does the g-shock illuminator dw-9052 have the option to light up if you flick your wrist fast...instead of pushing the button ?
    I don't think your watch has this sort of option. You can find out yourself by finding CASIO watch manual link in my tips.
    Feb 02, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
    I had the battery in my Casio G Shock DW 6800 replaced. Since then none of the beeps or alarms have worked. Is there a reset button he didn't press?
    There is a reset button inside your watch, but I don't think that is the problem. Most likely, there is a spring that makes contact to the watch and the back of your watch case, and it fell out by the person replacing your battery. I would definitely go back to the place where you had the battery installed, and have them take care of the problem buy ordering you a new spring or have them pay for you to send it to Casio.
    Apr 24, 2008 | Casio G-Shock GW500A-1V Wrist Watch
    Casio Databank 150
    If your databank is like mine (DB-35H), there is a TINY spring in a really unusual spot that you probably didn't notice that fell out. Laying the watch face down and with the back off, there is a little tiny hole in the back towards one of the corners. (sorry, already put my watch back together and didn't notice which corner.) There is a tiny (1/16" x 1/4") spring that sits upright in that hole. It must make a contact with the metal cover. I replaced my battery and when I did, a spring fell out. I looked all over the internet, then wrote Casio, who said they didn't have access to the information about where the spring went. (Doh!) I got a used DB-35H from my brother and was going to swap the innards when I noticed the spring on his. Put my spring back and it beeps! If you've lost the spring, don't know if you can fake it with tinfoil or not, but it really is a TINY spring. Good luck.
    Mar 26, 2008 | Casio DBC1501 Wrist Watch
    Casio DW9052-1V Wrist Watch Logo
    196 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
