Question about Suunto D9 w/transmitter [SuuntoWatches.com]
My screen went blank after i held the mode button for about 5 seconds. i can no longer see data on the screen
    New Friend:
Just experienced same problem with D9. Did you find solution?
Posted on Nov 07, 2013
The watch just turned off?
I wish someone would have answered this for you as the same thing just happened to my watch.
Oct 07, 2016 | Ripcurl Rip Curl Trestles Oceansearch Tide...
My watch is 3 hours and 5 minutes off its a shp8948
1. Since all of the settings seem to go through the start/stop button, hold it down for three seconds to put it in "set the watch mode" (when the seconds at the bottom start blinking).
2. Do a quick press of the start/stop button to move from seconds to minutes to hours to years to months to days. The mode button subtracts & the reset button adds.
3. Setting alarms & so on require putting it alarm mode via the mode button. Use the reset button to move to the selected alarm (1-5).
4. Hold the start/stop button for three seconds to "set the alarm mode."
5. Quickly press the start/stop button to between things to set (kind of alarm, hours, minutes).
6. Again, the mode button subtracts & the reset button adds.
7. A three-second press of the start/stop button exits the setup mode.
Feb 27, 2015 | Watches
I have 1 sonata super fibre watch analog+digital i dont know how to set time in it
If its a super fibre 3 series with 4 butons ( set, adj, mode, light)
Just keep the set button pressed for about 5 seconds, then use mode to select next( date, time, year etc) and adj to change the respective data. Then press Set once and its done.
Cheers
Nov 18, 2012 | Watches
My Tissot T-Touch Altimeter does not function.
Mine did the same thing; I read in other blogs that this could happen due to humidity. I heat up my watch with my wife's blower for about 5 minutes on high. After 5 min I couldn't even touch it! The screen went blank. After a few minutes when it cooled down the screen came back up and to my amazement all the function came back. it is risky but So far... it works well.
Sep 26, 2012 | Tissot T-Touch T33759851
I have a Nixon LowDown Tide Watch and the screen is staying blank, almost as though it is in a battery saver mode unitl i press any button and its display turns on for 3 seconds or so then goes back to...
Hey, this just happened to my nixon watch (I have the nixon housing - same setup as the lowdown) and what you have to do is simply hold in the light display button for about 3 seconds and the display won't disappear after the light times out.
hope this helps :)
Apr 09, 2011 | Nixon Lodown Tide watch
I am not able to set the day on my times iron man 100 lap triathlon watch
By the buttons there should be words like "adjust" or "mode", try pressing one of these dowan and holding for 4-5 seconds (no less) because sometimes it takes longer for the setting process to start. Once you get it to stat blinking press another button, one should be for moving the mode from seconds to minutes and another should be for the actuaul setting of the watch. When you find all that out , and set your watch just push the button you started with (the one that made it blink) and you should be good to go. PLEASE, if you still have problems, let me know. I will be glad to go over it with you on-line.Good Luck!!
Aug 11, 2008 | Timex Watches
Casio wave ceptor wvq 202hdu ibver
I don't have wvq 202hdu but I have a waveceptor that had the same problem. After not being able to find a solution online, I went back and started playing with it and I figured it out on my wva-430a. Hopefully my instruction helps:
The problem is that the daylight saving time is set to ON (or maybe OFF) whereas it has to be set on Automatic (A). To change that on my wva-430a, I held the "Adjust/Display" button for three seconds. It showed "US 60" for me. Then I used the "Mode/Select" button to go to the next screen which shows CHI for Chicago (Central Time). Here you have to choose the city that corresponds to your time zone. Again by pressing "Mode/Select" it took me to the next screen which was the daylight saving option. The choices were ON/OF/A that could be cycled by pressing "Receiving/Set+" button. Set it to "A" for automatic. Then press Adjust/Display to see the last option for 12H/24H setting. Press Adjust/Display one more time to go out of the settings menu. Your watch should adjust itself immediately.
Oct 29, 2007 | Casio W752V3AV men's watch
Screen goes blank
I put a new CR2025 battery in my T5e671 Timex and it solved the problem.
The screen no longer goes blank at any time.
PS:Timex manual says "remove battery strap" to replace the battery.
But it doesn't say HOW.-& I couldn't google an answer to that.
Here is how:
The metal strap goes across the middle of the battery and then goes over the edge of it on both sides.
At both edges the metal strap goes over a nylon tab.
One of those nylon tabs is notched, if you put the end of a paperclip in the notch, you can release the metal strap edge that runs under it.
Oct 14, 2007 | Timex Ironman Triathlon 51931 wristwatch
Synchronizing the manual and digital clocks
Push the middle button then touch the centre screen selecting the "nits" mode(24 C m), then push the middle button again for 5 seconds."Synchro" will appear on the display. By using pushers + and -, bring the two hands pre-cisely to 12 o'clock Incrementation of the minute hand(3 steps=1 minute) Incrementattion of the hour hand(3 steps=1 minute) Press the middle button to validate the setting.
Jul 06, 2007 | Tissot T-Touch T33759851
Suunto D9 w/transmitter [SuuntoWatches.com] Logo
122 people viewed this question
Top Suunto Watches Experts
Ansel Alberto
Ansel Alberto
Andrew Taylor
Andrew Taylor
Are you a Suunto Watch Expert? Answer questions, earn points and help others
