Question about V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series
Engine will start but only run at choke or half choke and low throttle sputteres and or dies if you try to increase to full throttle and dies if you take off choke
  • highcharger Oct 19, 2010
    I took the carb off and cleaned it already it wouldn't even start on its own before noticed one oring in the carb is worn don't know how significant it is also the cylinder piece that goes thru the carb. does it need to any certain way?? thanks for your input
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
Sounds like fuel starvation. Check for plugged fuel filter or sediment or dirt in the fuel tank. Failing that, examine the carburetor for dirt/sedment plugging it. Good luck!
Posted on Oct 19, 2010
Why won't my FeatherLite FL-20C weed eater will not stay running when I put it in full choke. What could be wrong?
It should run ok after warming up. After starting it, let it run for a minute or so and then try gradually opening the choke. You might try increasing the throttle setting at the same time. After the motor is hot, if you have to have the throttle setting increased in order to keep it running it means the idle setting needs to be increased, usually by turning a screw to keep the fuel valve from closing so much, or that there is a problem with the fuel flow......like a clogged jet or fuel passage in the carb.
Jul 07, 2014 | Weed Eater Featherlite Fl20 Lawn Edgers
Ryobi CS30 Trimmer starts and runs in full choke and half choke but stumbles and stalls on run. Not up to full rpms when in full choke and half choke....
You probably need a slight carburetor adjustment. Try to turn the L mixture screw (the one near the bottom of the carburetor on the air filter side, closest to the engine) 1/8 to 1/4 of a turn counterclockwise. These mixture adjustment screws ( L and H) have odd heads on them and conventional tools won't turn them. I use an automotive type plastic wire connector (around 22 gauge) with a ring terminal end which I can hold. Tap the plastic end of the wire terminal connector onto the head of the screw with a small hammer and this will enable you to adjust the L screw. This adjustment will increase you high speed side and possibly allow it to run off choke in a regular manner.
May 21, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Check fuel pump delivery for adequate flow. If when choke enrichment is applied and it runs, then dies when choke is off, fuel flow is inadequate and needs choke enrichment to compensate. Also, if engine dies or chokes when increasing rpms, this will be a symptom of too little fuel. Check fuel flow at pump, then, if flow is good, check for carb blockage, unscrew the jet and inspect, check the operation of the solenoid at the bottom of the bowl, it has a wire attached to it. Trace that wire to where it plugs in, unplug it and touch it to the positive pole of the battery, it should retract. If not you need a new solenoid that has the job of metering in gas to the inner bowl below the jet assembly.
Feb 10, 2011 | V-Twin Horizontal OHV Engine with Electric...
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Will not operate with choke full open
It sounds more like the high speed jet needs to be opened. No engine will run with the choke on. Open it up, find the little screw labeled high or fast, you have 2, one low or slow, If opening it up doesn't work, try closing it, turn it a very little bit at a time to see what it does. Hope this helps.
May 12, 2010 | Garden
3.5 Briggs with not run at full throttle
same problem, was told it was the jets, are your symptoms as follows
runs at low throttle, will only run at full throttle if fully choked
dies if choke is relieved
Apr 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Is there a choke setting and throttle setting for best results in getting the MTD yarde amchine started?
Most of the small outdoor power equipment that I have used takes the following to start:
1. Prime 6-8 times, or whatever the manual calls for.
2. Choke the carb to full choke.
3. Pull starter rope. It may sputter and die.
4. After it sputters and dies, put the choke on 1/2. Pull a time or 2 more and should start. Run like that 10 seconds or so, then take choke all the way off.
Oct 30, 2009 | Mtd Garden
Need carb h/l ajustemts and idle controle ajustment
This does take a little time to get it just right. Start at one full turn for the h and l. Work on the high first and after you get the H running work on the Low. They have to work together. So if you get it to idle and run at full throttle but it hesitates when you pull the trigger just adjust the low a little higher.
May 02, 2009 | Poulan Pro Chain Saw 46cc 20"
Blower wont run at full throttle
Start with the spark plug it is the easiest.
But sounds like the carbourator is dirty, Probably fouled with old gas varnish. When it is idling give it a little throttle, flip the choke on and then full throttle. If it goes full throttle and doesn't conk out, it is a fuel issue.
Good Luck
Dec 07, 2008 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Sputters & quits at proper RPM for engaging trans or mowing deck
If the choke has an adjustment point, then adjust the choke to a good overall working powerband. If it still doesn't act correctly, look for vacuum leaks. If it is an option, you may want to install a manually operated choke lever.
Nov 23, 2008 | Garden
V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series Logo
979 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
rlev_7
Level 1 Expert
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
