Question about Singer 3116 Simple
My bobbin thread keeps getting knotted up when I sew. What is wrong?
    Genius:
  • 1,788 Answers
Your top threading is not right. Rethread, check your tension on your thread by pulling on the thread with the presser foot up, it should be smooth. Now, lower the presser foot and try to pull it, it should barely move. If, either is not happening, you are not threaded right, it depends on having the right tension.
Posted on Oct 15, 2010
Testimonial: "Thank you so much! I tried this and it worked perfectly!!"
Brother CS-8060. The thread keeps knotting up on the back. Looks okay on front. Tried adjusting tension. Nothing changes
if the thread is knotting on the under side it my be your bobbin is in the wrong way when putting your bobbin into its holder it should be the shape of a 9 not a p its surprising how this affects your machine your tension on top i usually between 4.5 and 5 there is tension on the bobbin also usually this never needs to be touched but if you have to be very careful and very slowly turn the screw testing each time to see how it sews
Jan 06, 2018 | Brother Sewing Machines
Can't set the tension on needle or bobbin to match
1. make sure your machine is threaded right.2. set the tension between 3 and 4 and play with the tension as you need it to adjust it.3. make sure the bobbin is threaded right.make sure to visit the site below; it has solutions to multiple problems and instructions how to thread the needle or bobbin. Good luck.htt://Fix Looping/Knotting Thread Fix Knotting/Bunching Thread Looping Bunching & Knotting Thread
Aug 03, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
Bobbin thread keeps knotting
1. Do you mean that there are knots in the bobbin thread?
2. Is the bottom thread in your stitching looping and knotting.
If yes to 1. you need to rewind your bobbin fresh, and keep slight tension on the thread reel that you are winding it from. Put the handle of your scissors into the top of the reel to apply a gentle pressure while winding. Keep your eye on the bobbin as it winds and give it a nudge with a finger tip to ensure it winds the bobbin evenly top, middle and bottom.
If yes to 2, then you need to check your bobbin threading, is the thread even under tension. Is the bobbin tension set correctly. Break out your manual and revisit this to ensure it is set correctly.
Feb 27, 2011 | Brother XL-5340 Mechanical Sewing Machine
When the needle descends it gets stuck as it enters the bobbin case area. It will only release if I move the bobbin. The thread from the needle gets knotted up and pulls the fabric down into the bobbin...
Could be a few things. Absolutely minutely check that the top thread is threaded properly. Otherwise, it could be: Old thread. incorrect thread for the material. wrong size or blunt needle. or incorrect tension on needle I had this problem and I was missing a part of threading even though I have been sewing for years. :)
Oct 08, 2017 | Brother LS30 Mechanical Sewing Machine
Bobbin Thread is "birdnesting"
Get out the manual and refer to the maintenance section for cleaning the machine.
Especially the bobbin area. You want to make sure the area around the bobbin case is free of lint and thread.
Use a new bobbin and re-thread the machine, with the presser foot UP.
Install a new needle, again according to the directions in the manual. Installed incorrectly can lead to mis-stitching.
If the problem persits, the timing may need adjusting.
This should be done by the sewing machine tech for Kenmore.
Sewusa.com has a guide for this in the repair section, but you could end up with more problems.
Apr 29, 2010 | Kenmore 15202 Mechanical Sewing Machine
Thread knotting
Ensure you have cotton thread on the bobbin and that the bobbin is placed with the thread counterclockwise. It may also be the needle.
Apr 06, 2010 | Euro-Pro Dressmaker 998B
Cotton keeps getting knotted from the bobbin
upper tension is wrong or upper threading is wrong (problem is always on the other side of the bunched thread)
Jul 07, 2009 | Janome Sewing Machines
The thread knots up under the feed dog on about the second stitch
hi! well, you can try to set up your thread accurately followed this
53de094.jpg fig.bobbins se up of thread.the thread should be clockwise rotation coming out to bobbins casing,insert thread on slot to acquired bobbins tension.after setting up you insert your bobbins on shuttle
casing.next set up your upper thread tension.on fig is just a sample.9cbc7d3.jpg follow the red thread set, try this on single straight sewing with dial stich set up to # 8 range to #17,Dial tension to # 3. use cotton/polyester foe sample sewing. try on hand maual sewing first several time before applying foot pedal to avoid needle breakage,
Mar 17, 2009 | New Home L-373 Mechanical Sewing Machine
Upper thread knots up with bobbin thread when sewing a stich
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Thread knotting on the bobbin can be a lot of things but here's some guidance:
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Jamming bobbin case:
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes.
Mar 16, 2009 | Sewing Machines
Singer 3116 Simple Logo
764 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
