Question about Gateway MX6920 Notebook
Printer problem Dialog window pops up while desktop screen appears, before wireless connection is completed "Printer Card Transfer Monitor" need to shut down. No help or options to repair, yes , no, cancel, or o.k. just "X" or "close"
    Sergeant:
  • 458 Answers
You have asked this same question under a different name several times or you are copying someones question. Please do not do this and clarify your question. Asking a question several times by a different name is only going to clog the FIXYA system.
You have not given enough information for this to be solved. What O.S. is this? Have you tried to install the drivers again and have you updated the drivers? What kind of printer is this? Make and model number.
Posted on Jun 04, 2008
Not printing from a mac
Use one of the following methods to print, depending on how the printer is connected to the computer. hpweb_1-2_minus.gif Method one: Printing from a USB printer
  1. Make sure your printer is turned on and connected.
  2. Open a document to print, and then choose File > Print .
    NOTE: You can also go directly to System Preferences > Print & Fax .
  3. From the Printer pop-up menu, choose your printer. If you do not see your printer listed, choose Add Printer , and then click More Printers .
  4. In the Name column, select your printer, and then click Add .
hpweb_1-2_minus.gif Method two: Printing from a network printer You can connect to HP printers on your local network (wireless and Ethernet) using Bonjour or IP, as well as shared printers connected to an Apple Airport base station.
NOTE: Apple does not support AppleTalk in Mac OS X 10.6.
  1. Choose File > Print .
  2. From the Printer pop-up menu, choose your printer. A dialog appears, listing any Bonjour printers on your local network. It may take a minute or two for your printer to appear.
    NOTE: Your printer may also be listed in the Nearby Printers submenu.
  3. If your printer does not appear, choose Add Printer from the Printer pop-up menu. Printers that are turned on and connected to the local network (wireless and Ethernet) should appear as Bonjour devices.
  4. Select your device from the list, and then click Add to create the HP printer queue for your HP Photosmart, Officejet, or Deskjet All-in-One printer.
Your computer can usually detect whether a printer has special accessories installed, such as additional paper trays or a duplex unit. If it cannot, a dialog appears that lets you specify them. To enable full functionality, make sure the settings in that dialog accurately reflect the installed options.
The latest HP Utility is included in Mac OS X 10.6.
Method one: Open the HP Utility from System Preferences
  2. From the Apple menu, choose System Preferences .
  3. Click Print & Fax .
  4. In the list of printers on the left side of the dialog, select the HP All-in-One to view the options in the Print & Fax window.
  5. Click Options and Supplies .
  6. Click the Utility tab at the top of the window, and then click Open Printer Utility . The HP Utility opens. Features and options may vary depending on your printer model.
Method two: Alternative The HP Utility can also be launched from the printer icon in the dock to open the Printer Browser window.
  1. Double-click the printer icon. The Printer Browser window opens.
  2. Click Printer Setup in the toolbar.
  3. Click the Utility tab.
  4. Click Open Printer Utility . The HP Utility opens. Features and options may vary depending on your printer model.
Jan 18, 2011 | HP Officejet 6310 All-In-One InkJet...
Printer card transfer monitor has a problem When I try to print, the page feeds into the printer and then stops. The computer pops up a message 'printer card transfer monitor has encountered a problem and...
Did you make sure the Software supports the operating sytem you are using?I mean if your operating system is vista the software will not work if it supports only xp.
Jul 30, 2008 | Computers & Internet
Tip
How to Configure a Wireless Printer Wireless printers typically come with a...
Wireless printers typically come with a transmitter that a laptop, with a wireless adapter, can connect to and print from any location in a home. In order to configure a wireless printer you will need to install the drivers and software from the installation CD that came with the printer. You will be able to run the configuration for the printer driver, for the laptop, at the end of the software installation.
  1. Insert the installation disc for your wireless printer into the drive on your laptop computer.
  2. Wait for the Installation Wizard to appear.
  3. Click the "Next" button to continue and go through each screen to install the software for the printer.
  4. Select the option to "Configure printer driver now" on the last screen of the Installation Wizard.
  5. Click the "OK" button when the Information dialog box appears.
  6. Select the printer port for your printer when the Printer Port Setup dialog box appears.
  7. Click the "OK" button when the "addport" dialog box appears.
  8. Click the "Next" button to continue.
  9. Select your wireless printer from the list of installed printers when the Add Printer Wizard window appears.
  10. Click the "Next" button to continue.
  11. Click the "Connect" button when the Configure Printer Port dialog box appears.
  12. Wait for a connection to be made with the wireless printer and then click the "Finish" button to exit the Add Printer Wizard dialog box.
  13. Repeat this process on each computer that you want to connect to the wireless printer.
on Apr 02, 2010 | Computers & Internet
Printer is not scan but some problem she has. Error in scannor Turn off scannor and follow instructions ni manual. Scannor drive will closed. Code : 61,213,0 I want to new setup Canon PIXMA MP160...
  1. Select 'Program' (for Windows 2000/Me/98), or 'All Programs' (for Windows XP) from the Start menu.
  2. Select the name of the printer model to remove and select 'Uninstall.'
  3. When the MP Drivers Uninstaller window is displayed, click 'Perform.'
  4. When the confirmation window is displayed, click 'Yes.'
  5. When the Uninstallation Complete window is displayed, click 'Complete.'
  6. Reinstall the drivers.
Reinstall the Drivers
Note:
  • The MP drivers can be installed using Easy Install or Custom Install.
    Easy Install automatically installs the software which is in the CD-ROM.
    This method is recommended for first-time users.
    Custom Install allows you to select the software programs from MP Drivers, Application Software, and On-screen Manual.
  • Login as a user with Administrator privileges to install on WindowsXP/2000.
  • Close any antivirus software that may be running prior to installing the drivers.
  1. Turn off the printer and disconnect the cable connecting the computer and the printer.
  2. Insert CD-ROM in the computer. (The CD-ROM will start automatically and the following window will be displayed on the screen.)
    1. If setup does not start automatically, click 'Start' and then 'Run'.
    2. At the Run window, type x:\msetup4.exe (where x is your computer's CD drive) in Open box and then click 'OK'.
  3. At the main installation window, click 'Easy Install' or 'Custom Install'.
    When selecting Easy Install:
    (A) Click 'Easy Install'.
    (B) Click 'Install' in the following window.
    * Display varies according to the printer model.
    When selecting Custom Install:
    (A) Click 'Custom Install'.
    (B) When the following window is displayed, click 'MP Drivers' and the application software to be installed, and then click 'Next'.
  4. When the License Agreement window is displayed, read the content carefully and click 'Yes'.
  5. The installation will start.
    Messages may be displayed during the installation of the application software.
    Follow the instructions on the window and continue the installation.
  6. When the Printer Connection window appears, connect the printer to the computer and power on the printer.
    Note: If the installation cannot proceed even after 2 minutes, stop the installation by following the procedures below and start from the beginning again.
    1) Click 'Cancel' at the Printer Connection window then click 'Start Over' at the Installation Failure window.
    2) At the window to install the driver / applications appears, click 'Back' then click 'Exit'.
    3) Restart the computer.
    4) Install the printer driver again.
  7. For Windows XP, at the Welcome to the Found New Hardware Wizard dialog box, confirm Install the software automatically (Recommended) is selected, then click 'Next'.
    Note: The Welcome to the Found New Hardware Wizard dialog box may be behind the Printer Connection window.
    In this case, click 'Found New Hardware Wizard' button on the task bar to display the window.
  8. After the files are copied automatically and the dialog box Completing Found New Hardware Wizard window appears, click 'Finish'.
  9. If the Welcome to the Found New Hardware Wizard dialog box appears again, click 'Finish' again.
  10. At the Print Head Alignment window, click 'Execute'.
    Note:
    * The Execute button may not appear for all models. In that case, skip to step 13.
    * The Print Head Alignment can also be done after the installation of the printer driver.
  11. When the Start Print Head Alignment window appears, load one sheet of A4 or letter size plain paper in the sheet feeder and click 'Print Head Alignment'.
  12. At the Do not start another operation until current one has finished dialog box, click 'OK'.
  13. When the pattern is printed, click 'Next' at the Print Head Alignment dialog box.
  14. At the Installation Results dialog box, check the content then click 'Next'.
  15. At the Installation completed successfully dialog box, click 'Exit'.
    Note: When the Restart button appears, confirm that Restart the system now (recommended) is checked then click 'Restart'.
Dec 04, 2010 | Canon PIXMA MP160 All-In-One InkJet...
HOW DO I RESTART MY ACER LAPTOP
  • 1
    Connect the host computer (the computer that will be connected via wire to the printer) to the printer using the provided USB cable. Insert the printer software CD into the disc drive and click the "Install" button when it appears on-screen. Click "Continue" at the bottom of the next window.
  • 2
    Click "Yes" when asked whether the host computer will be sharing the printer. Give both the host computer and the printer a network name that will be used to connect to the other computers when prompted to do so. Continue to follow the on-screen instructions until the installation process is complete.
  • 3
    Go to a different computer on the network and insert the printer software CD into the disc drive. Click the "Install" button when it appears on screen. Select the "Network" option on the screen marked "Connect Your Printer."
  • 4
    Enter in network names of both the host computer and the printer into the dialog boxes in the next window. Continue to follow the on-screen instructions that will prompt you to begin the installation process. The installation process should take less than five minutes to complete. Click "Finish" once the software downloaded from the CD is complete. The printer will now be available to both computers on the network. Repeat these steps to enable another computer to work through the same network.
  • Read more: How to Put a Lexmark X8350 on the Network ' eHow.com http://www.ehow.com/how_6462353_put-lexmark-x8350-network.html#ixzz1251Jrln3
    Oct 11, 2010 | Computers & Internet
    Failed Wireless Setup/could not create new port
    Check this link for wireless setup:
    http://downloads.canon.com/MP620/Intro_to_MP620_Setup_Guide.htm
    There are Vista 64 drivers on the CD that came with the printer, but if you want to download, you should download the network drivers if you are installing the printer to work on a wireless local area network (LAN).
    Jun 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
    Error message on boot up
    I do not understand your question. You did not even give me the kind of printer that this was. Try reloading your printer drivers and clear anything that you have tried to print from the printer.
    I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future.
    May 25, 2008 | Gateway MX6920 Notebook
    Error message after start up of Gateway Laptop
    Neither of you have given the Printer Make and Model number. We can not help without this. This seems to be going around in circles on the board and asked different ways by different people. I have seen this at least 3 times now.
    Apr 26, 2008 | Gateway MX6920 Notebook
    I start the computer get an error ,says Printer card transfer monitor has encounters a problem and needs to close???
    Apr 17, 2008 | Computers & Internet
    Failure to Communicate
    try re installing the drivers for this printer check all cable connections once again. did the printer work well at ur frens place? and wat os did he use??
    Aug 29, 2007 | Canon MultiPASS F60 All-In-One InkJet...
    Gateway MX6920 Notebook Logo
    80 people viewed this question
    Top Gateway Computers & Internet Experts
    Brian Sullivan
    Brian Sullivan
    Prashant M
    Prashant M
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
