Question about Philips 51PP9303H Rear Projection Television
There is A greenish double slightly lower than the picture. How do I adjust the lrnses without A remote?
  • Philips Master
  • 3,459 Answers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
To get fixed either call in a local TV repair company or goto sites such as www.TvRepairKits.com to get a repair kit with instructions.
Posted on Oct 15, 2010
Panasonic pt 53wx53g
No--you will NOT get anywhere this way. You need a remote.
Apr 01, 2014 | Televison & Video
How do I adjust the convergence
In some cases you will need the original remote to adjust convergence. Check that first. You can also find more detailed guides on www.TvRepairKits.com - there is a tips page with service mode codes, etc, also.
Jan 29, 2013 | Philips 60PP9202 60" Rear Projection...
I fix the red doubling by adjusting the red screen screw now the people are greenish. can someone help me. pt-56wx53g
turning the red Screen down even slightly will make the other two CRTs dominate over red. You may be able to turn the Green and the Blue down slightly to balance them back to what red is at. Turning the screens down too low will cause them to shut off if they get lower than the cut off point.
Sep 15, 2011 | Panasonic PT-56WX53 53" Rear Projection...
Watching espn hd, the picture cuts off on one side. How do I adjust this? The ESPN bug is well within the border in the right hand lower corner, but a chart that comes on perodically during play...
There's a resolution/aspect ratio you can adjust in the picture menu, or straight from the remote. Choose the size you want on ESPN that best fits the picture while watching it.
Jun 16, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Picture is greenish hue and cannot be changed from menu bar
The greenish hue cannot be adjusted from the menu. One has to do it from inside.First confirm by turning the color settings to zero using the remote. You should get a clean black and white image with no traces of any color ( inc: green ). If your TV is greenish , the green drive on the base of the picture tube has to be trimmed.
All you need is a screwdriver. There are dangerous voltages inside a TV, some as high as 27,000 volts !!!. Where the color adjustment has to be done there are voltages as high as 110 volts and 8000 volts.If you still want to make the adjustments yourself revert back for instructions
Apr 11, 2011 | Sony KV-36FS12 36" TV
Suddenly a curved line appeared in the upper left and lower right corner ....and words like "muting" and lower right words are doubled with a red virtual image....the main picture in the center is pretty...
Convergence problem---set uses two of the STK-392-560 convergence chips.
Both will have to be replaced and set adjusted with remote.
Total parts cost on EBAY under 25 dollars.
I can tell you what is involved.
see attached photo of typical convergence problem and typical convergence chip.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 03, 2010 | Sony KP-51WS500 51" Rear Projection...
Pink and greenish lines creating a double picture
with your remote go to your menu and find convergence. Follow the instructions to auto set convergence. if that don't fix it the problem convergence panel if bad.
Mar 15, 2009 | Philips 55PW9363 55" Rear Projection...
Greenish picture when i play my Compaq Ipaq MP3800 projector
The greenish image is due just by one sof the terminals of the cable. You just need to replace it. Or try anothr RGB cable and look what happen.
Nov 18, 2008 | Televison & Video
Sony KV-32FV27 Picture Discoloration
It appears that the greenish discolored area could be cause by the Yoke or it could also be some magnetization on the screen as well.
If it's the yoke that moved slightly out of position, it can be adjusted, but i would suggest to let a repair tech do it due a high voltage around the area.
Try unplugging the TV for some time and plug it back in and hopefully the demagnetizer circuitry might be able to clear the greenish spot.
Let me know if you need further assistance.
Jul 01, 2008 | Sony KV-32FV27 32" TV
Televison & Video Logo
26 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
