Question about Car Audio & Video
Place cd inn cd player and it reads error - Car Audio & Video
  • c c Oct 15, 2010
    DID NOT WORK!
  • 13,433 Answers
Hello, and thanks for using FixYa.
Pretty common problem, most likely the laser optics are wearing out, or the laser lens could be dirty, have dust on it, clean the lens with a q-tip and 70% rubbing alcohol. Use only a small amount on the tip of the Qtip. Or you can use Laser Cleaning Disc CD.
If the problem still remains, there might be a faulty capacitor on the board of the drive / unit that is preventing it from reading the disc properly. or the laser is too weak to read the disc anymore and the laser reader would need to be replaced entirely.
Posted on Oct 14, 2010
  • Ekse Oct 15, 2010
    The cd players laser reader needs to be replaced in that case. if you have checked what I've told you. It is very much easier for you to replace the whole cd player in that case if you can't obtain a new lens assembly for the drive.
    But If you have taken apart the cd player to check for faulty capacitors, and if you have access to the drive and you can see the lens, it may have adjustment screws on the reader that you can use to calibrate the laser. It might help but first check that the laser assembly is clean - dust free, use compressed air to clean it - To calibrate the laser find the screws that adjust the lens and screw the screws in as much as they go and test a cd, if you still get the error adjust / open the screws a little bit and then test another disc. Repeat this until the cd reads, if they do not read after you no longer can adjust the screws then the whole laser assembly needs to be replaced to get the player working again. At that point it is easier to replace the whole player.
After reading toc of my Marant zcd5003 the display is "error" seeking help to find out the cause
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
follow the steps and fix it.
God bless you
May 27, 2013 | Marantz CD5003 CD Player
Just bought a 2002 exlorer. can't load cd's into cd player. reads cd error
I have found that any "burned" discs will not be read on older cd/radio combinations. The newer sets will tell you on the box what formats can be read...I also found this to be true on dvd players
Jul 29, 2012 | 2002 Ford Explorer
U70 error message on cd player
U70 error message on cd player - Fixya
www.fixya.com/support/t12308553-u70_error_message_cd_player
Apr 5, 2012 - U70 error message on cd player Cd player doesn't work at all. Displays 0 track, 0:00 (min,sec). The play - Technics CD Players question.
Technics error code f 70 CD Players Questions & Answers ...
www.fixya.com > Forum > Tags > error code f 70 > CD Players
Technics cd players error code f 70 related questions and answers. ... won't play cds changer turns on ok, reads error message I have the same problem.
Apr 05, 2012 | Technics Audio Players & Recorders
My son has a Pirates of the Caribbean dead man's chest CD player an error message comes up and it reads "Er" and it will not work
The laser lens is out of place. Try using a q tip and gently pressing on the lens to see if it moves back in place.
Mar 19, 2011 | Disney Pirates of the Caribbean Portable...
I have 2006 chevy impala What does it means I try to put my cd in to play its say error
It means that your CD player is not reading the CD , try a different CD and preferably original CD and see if it reads it then. If the CD player works ok then, you had bad CD and if it should read error again then the CD player it self is defective.
Jan 22, 2011 | 2006 Chevrolet Impala
I hav a clarion auto cd/stereo displaying err 6 please explain, thank you
Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
For error code 6:
Try an original purchased cd with no scratches and see if the cd player reads it. If yes then lens is dirty or tired so try using a cleaning cd(has little brushes on it). If it doesn't read with the original cd try using the cleaning cd and if no go then look at purchasing a new cd player!
Nov 01, 2010 | Car Audio & Video
Whenever sign inn to read mails,there is always
Hi there, You can try using alternative browsers. Netscape navigator, mozilla firefox, internet explorer, google chrome, etc. am sure it will work better.
Cheers
Nov 09, 2009 | Yahoo Computers & Internet
Cd will not paly car but will inn computer
The CD is in a format which can only be played on Audio players.check the file extention of the audio files on the computer.It should be played on the computer if they are .mp3 files.
Jul 18, 2009 | Computers & Internet
Boot error! please format unit
It might be cause by a corrupt firmware. You need to have a utility that restore the mp3 player to its original setting. i had exactly the same problem with my ipod shuffle 1st generation 2 years ago. Good thing Apple has that utility for me to download and until no it is still working. Try to visit and upgrade the firmware using this link for you mp3 player http://support.rcaaudiovideo.com/downloads.aspx?product=192
Please Rate Appropriately Thanks!
Jan 14, 2008 | RCA OPAL M4001 MP3 Player
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
