Spin cycle not working.. what would cause this or what do i need to change???
    Sergeant:
    Champion:
  • 351 Answers
Hi check lid switch jim
Posted on Oct 15, 2010
Kenmore model 11020722990
The circuit board may be defective and need replacing. When a cycle skips or hangs up, generally the progression of events are interrupted. In some cases the level of a machine can effect the spin and other features, so check that also. If a Lid bounces during a cycle, this too can cause a change in cycles.
Replacement is easy if your are able to do it yourself. Just go to the replacement parts dept. of Sears and order the part and take out the old one; put in the new one. Always Disconnect the POWER before working on the appliance.
Dec 18, 2013 | Kenmore Washing Machines
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
The spin cycle doesn't work and ushing the top
You need to replace the motor coupling, take front off and it's behind the motor
Feb 26, 2010 | Kenmore 24902 Top Load Washer
Doesn't change cycles, first spin and rince cycle doesn't work at all
Sounds like you have a bad timer Does it spin on final cycle? (Spin Cycle)
May 11, 2009 | Washing Machines
Our Maytag Neptune MAH3000 does not advance through the rinse and spin cycles. The problem is sporadic. Sometimes it advances through one or two spin cycles and then stops, sometimes it stops on the first...
Have you cleaned the large drive belt, if it slips it could cause this sort of fault. Motor will stop if it doesn't get a signal from the drum. Just try wiping the drive belt with a damp soapy cloth and then wiping again with a damp non soapy cloth. You will need to remove the back, unplug it from the power before starting any work.
Apr 30, 2017 | Maytag Washing Machines
Barrel will not spin, sounds like motor is running.
check the p-trap for stuck loose items---change,rocks,etc.. I had the same problem and the technician said the placement of the p-trap causes lots of loose items to get stuck, which causes the washer not to go thru its cycles & won't spin.
Apr 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Hoover 2305 washine machine wont spin
Your problem could be caused the interlock but it could also be that the machine is failing to drain in the time alllowed and therefore the machine will not spin, before buying a lock check the sump hose and pump area for blockages.
Dec 29, 2007 | Washing Machines
Washer Does Not Spin!
You either need a new pump or the pump is blocked, the washer will not spin whilst there is water in the drum.
Oct 23, 2007 | Washing Machines
Washer only works on spin cycle
Sounds like u need a new control panel
Mar 18, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
