Question about Keurig B50 Coffee Maker
Keurig coffee maker only drips water real slow, I cleaned it with white vinager with no success. I think there is something blocking the tube or pump inside the machine. Is there a manual telling how to disassemble the machine so I can get a look at the pump etc.?
    Champion:
  • 248 Answers
Try web search-keurig b50 repair manual
Posted on Oct 15, 2010
My Keurig will only drip water when brewing. I've descaled, changed the filter, machine is only year and a half old.
#1. Use the paper clip trick on both top and bottom punchers. The holes are in the side of the punchers. (lots of video in youtube) #2. Descale it again with vinegar and leave it for 15-24 hrs before brew rinsing, (instead of 4 hours as mentioned on the manual) #3 some said, turning it upside down and giving it a shake, #4. visibly check the screen on the the water reservoir tank entrance clean if there's any visible clog. #5 Still having a problem, then, for the last resort, before deciding on replacing the diaphragm pump, open the bottom metal part (5 screws), inspect for any visible drip of water (accumulation of white hard water stains, or discoloration on the metal) visualize where it's coming from. Mine is on 2 areas--from the diaphragm pump (where there's 3 black screws) and where the connection of the main pump to the reservoir. This is good news, it means nothing wrong with the pumps. it's just been leaking a little bit of water on the connection (must be air tight, any leak will decrease the pressure). The common sense FIX: depress the metal clamp and pull the plastic tube out, clean the inside and the connection and re-attach it back making sure the little leak will stop. same with the other one then, then replace the other smaller tube with a new tie wrap and make sure it's air tight. Basically you just check all the hose connections make sure it's air tight..
Jun 14, 2015 | Keurig B70 Coffee Maker
Water doesn't always want to pump through the machine. If I fiddle with the water level - it will go through, but then it drips for a while. Additionally, the machine says to descale, I have run...
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Jun 24, 2011 | Keurig Platinum B70 Coffee Maker
Coffee does not drip into cup...but you hear the pump working
heatman101
May 31, 2011 | Keurig Elite B40 Coffee Maker
Coffee drips so slow. coffee stops dripping
Have you tried descaling. Run white vinager through it. instructions for this procedure are in the manual
May 26, 2011 | Keurig B50 Coffee Maker
Keurig B60 is real slow , displays brewing for 30 sec.
mcdevito75 here, It may need to be cleaned, water used to brew coffee leaves deposits in the brewing holes and must be cleaned every once in a while. Refer to the owners manual on cleaning the coffee maker.
Jun 20, 2010 | Keurig B60 Coffee Maker
Coffee drips slowly and water doesn't drain completly from filling chamber. had machine for about 6 months and was happy until today.All I hear is a humming, a slow drip of half a cup and then it shuts off...
mcdevito75 here, Your coffee maker most likely needs cleaning, Water will leave deposits in the brewings ports over time and will have to be cleaned out, Follow your owners manual on cleaning your coffee maker.
Jun 17, 2010 | Keurig B100 Coffee Maker
Something is blocking coffee from coming out!!
run it without a k-cup... Keurig will tell you to check for blockage at the upper needle with a paperclip... someone tried blowing into it with a straw to free the obstruction... which Keurig assumes is coffee/Tea grounds... or caked up cocoa mix, if you use that product...
May 06, 2010 | Keurig Elite B40 Coffee Maker
How much water to vinager to de-scale
48 oz. of White Destilled Vinager. Not deluted with water just straight brew until resevior tank is empty. let sit for 4 hours. Fill resevior tank with water and brew until vinerger smell and taste is gone
Mar 16, 2010 | Keurig Platinum B70 Coffee Maker
Coffee maker is not pumping water fast enough. takes over a minute to brew a 8 oz. cup. pumps water real slow.
have you tried cleaning it? Minerals from the water build up inside the tubing and make it run slow. Take a pot full of white vinegar and run it through a brew cycle. follow this by a couple of pots of cold water and you should be good to go.
Nov 04, 2009 | Keurig B60 Coffee Maker
Keurig B50 Coffee Maker Logo
2,342 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
