Question about Miller 907068 MILLER TRAILBLAZER PRO 350D KUBOTA DH905
My Miller trailblazer 251 NT will welder for about ten or fifteen minutes and seems that once it gets warmed up good it doesn't want to strike an arc and when it does it the engine will begin to misfire and won't drop back to idle. Any suggestions as to what the problem may be?
CarlGehrke
  • 169 Answers
SOURCE: hook up
I think I can help you do this, let's start with the general and you can ask questions if we don't cover everything you need.
The HF251D connects to the welding machine using 3 cables, you connect the Electrode terminal on the welding machine (the Lincoln) to the Electrode In terminal inside the HF251. Connect the Work terminal on the Lincoln to the Work In/Out inside the HF251, also connect the work (ground) clamp of your torch to this terminal. Be careful to select the correct size cables for the maximum current you intend to weld with.
The 3rd cable is the gray 14 pin round control cable that comes out the back of the HF251, it needs to be plugged into your Lincolns RMT14 socket. You'll also need to make sure that the Lincoln is set for remote control, this is usually a switch on the front panel. I'm pretty sure that the remote control cables have a standard pin layout, but we can check this by comparing the specs in both owners manuals.
After that you connect the torch and gas bottle to the HF251, start the Lincoln, and TIG weld until you're happy.
I've got a manual for the HF251 and can get a shop manual for it if we need it. What I'm not sure about is your Lincoln - what model is it exactly?
regards,
Carl
Posted on Dec 12, 2008
keemo68
  • 1263 Answers
SOURCE: miller Syncrowave 250 / no tig arc start
seems that you have a ground issue. make sure the ground clap is on barte metela and secured tight. make sure your tungsten electrod is about 1/8 of an inch form the edge of the cone. you will find that you will get a faster arc this way.
Posted on Apr 19, 2009
mamicheddy
  • 79 Answers
SOURCE: miller bobcat 225g plus welding problem
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
Posted on May 08, 2009
  • 5603 Answers
SOURCE: I have a miller thunderbolt 225v AC arc welder
The blank should be the grouDING conductor (green) and they may have a green screw to further indicate it.
Since the welder runs on 220, either of the hot wires can go to either of the other terminals (X or Y).. Those wires might be black, red, blue, brown.
There is a slight chance it would be white even though it is hot on the portable cord because some portable cord is used that way.
VERIFY the receptacle you connect to is wired correctely before connecting your unit to it.
Posted on Jan 24, 2010
SOURCE: Tig welder wont strike up arc, power to welder ok,
www.millerwelds.com › ProductsTIG -
www.millerwelds.com › Service & Support
Posted on Mar 27, 2010
225Bobcat gen.runs but will not excite when trying to strike arc
#Tags bobcat 250 welder service manual
coop.bounceme.net/term/bobcat-250-welder-service-manual
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and ... Won't strike an arc,fuses ok brushes and slip.
Aug 11, 2015 | Electrical Supplies
Why does the welder quit arching after 30 minutes?
Motors and generators are the same in this sense. The winding of a field coil is defective. The winding heats up with use and the winding expands causing it to short out and quits doing it's intended purpose. An hour of cooling allows the winding to contract thus clearing the short circuit. A good motor rewinder person can find the defective winding with an oven or heat gun and can rewind it for a fraction of a new welder generator.
Oct 07, 2014 | Miller Trailblazer 301g Cc/cv, Ac/dc...
I have miller deltaweld 302 lead stays hot all time what is th problem
Hi:
The problem could reside on the contactor, this part due to the heat and constant contact (that is the noice you hear everytime you strike an arc) sometimes it remains close. Check your owners manual and it is the numbered 21 on the part list.
Good luck
Jul 12, 2011 | Miller Electric Manufacturing Electric...
Miller Trailblazer, welds great for about 30 minutes. Then I loose my arc. It will spark but not maintain the arc. I let it cool off for 15 to 30 minutes it will weld for another 15 to 30 minutes.
Sounds pretty normal. These units are not rated to weld continuously. They might only be rated at 5-10% for cheap welders and longer for better ones. They are never designed to run continuously. You need to get into the higher end ($$$) before you get that ability.
You can try to blow cool air into the unit to help it cool. Sometimes this can extend the work time.Basically you can try that or work to your temp cut off limit as you have been or upgrade to a better unit. That is about all you can do.
Apr 04, 2011 | Miller Trailblazer 302 Welder Generator...
My miller sychrowave tig welder is not blowing sheilding gas when it strikes an arc. The gas is on at the tank. I can hear what sounds like gas or a valve opening when I press the foot control, but my...
Remove the tig torch twist lock from the front of the machine. Step on the pedal as if you were striking an arc and gas should flow out of the twist lock port. If gas comes out of the port, your torch probably has a valve built in (many do) often this is a sleeve on the torch body which you rotate but may not be obvious.
If no gas out of port then its the solenoid or regulator.
You do have the machine in TIG mode and not stick?
May 28, 2010 | Miller Welding Tools
Miller 907068 MILLER TRAILBLAZER PRO 350D KUBOTA DH905 Logo
359 people viewed this question
Top Miller Electrical Supplies Experts
littlewheel
Level 1 Expert
Lawrence Oravetz
jeff5may32
Are you a Miller Electrical Supply Expert? Answer questions, earn points and help others
