Question about Samsung RS2556 Side by Side Refrigerator
MY SAMSUNG side-by-side refridgerator was making several different noises from the back of it after my water was cut off for a couple of days,but now the noises have stopped,and I'm noticing the middle separation from the freezer to the fridge is extremely warm at times.Should I be worried?What might of caused this to happen,or is this normal after the water is off and back on for a two days?
  • 1,557 Answers
There could be air in the lines and i would have the cooling fan looked at
Posted on Oct 14, 2010
Ge monogram refridgerator water on floor
Is the water filter located behind the grille under the doors?. I had the same problem and found the O ring on the filter cartridge was leaking.
Dec 17, 2015 | GE Refrigerators
How big is the reservoir for the water dispenser? Also, what is the normal temperature of the water being dispensed?
??? You never gave make or model and your mouth is that accurate to tell a 17 degree difference in water temp?
Jul 02, 2015 | Refrigerators
I have a GE PROFILE side by side refridgerator model # PS123MGPCWW. my water and ice dispenser stop working periodically (for days at a time) and then come back on. it doesn't appear that the water...
Sounds like the water pump is bad .This is located at the back of the refrigerator. It's is a small pump and if you trace your water line you should be able to find it .Just replaced it and you should be fine
May 22, 2017 | Frigidaire Refrigerators
Refridgerator freezer is making noises
Hello, your refridgerator in most likely in defrost cycle. the noise your hearing is the water dripping on the hot heater and ice dropping off the evaporator. should only last 15 minutes and then your all set. Mike
Sep 15, 2009 | Freezers
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Hot high side assembly and at the front door section
Replaced the GE fan motor which seems to have solved the problem.
Dec 28, 2008 | Kenmore Refrigerators
Refridgerator
IF THE BUZZING SOUND IS ONLY THERE WHEN THE MOTOR IS RUNNING THAT COULD MEAN ONLY ONE THING.YOUR PISTON IN SIDE THE COMPRESSOR IS NOISEY THE ONLY WAY TO SOLVE THAT IS TO REPLACE THE COMPRESSOR.BEST YOU HAVE A TECH TO ADVICE YOU FUTHER.GOODLUCK.MOHAMED
Jul 21, 2008 | Whirlpool ED2FHEXN Side by Side...
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Tempature on fridge won't stay @ 38
might be freezing on the evaporator faulty defrost timer or drain is blocked water should run down back bottom tray
May 10, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2556 Side by Side Refrigerator Logo
78 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
