Question about Garden
Describe to me how to take a part a Kwikset deadbolt lock that has a key hole on both sides?
    Problem Solver:
  • 5 Answers
There should be two screws on the inner face of the lock. they may be phillips or one-way. remove screws and the lock should come apart. ( one-way screws may need to be drilled if you cant find a removing tool)
Posted on Oct 14, 2010
How do I tighten a deadbolt lock with no visible screw? It has key on both sides. Inside plate has 2 holes in it that I thought would rotate to expose screws. It does not. How do I proceed?
On the inside of the door, the lock has a trim ring around it. Look for a slot on the ring, place a flat screw driver into the slot and twist the screw driver to remove the trim ring.
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_843b43f7ebebd3f5
Jul 19, 2014 | Kwikset Locks & Locksmithing
I have a front door Kwikset "lever opening" front door key/deadbolt lock system which has come very loose, almost falling off. How do I tighten it up\?
on the inside of the door look on the bottom of the lock cover. There should be a hole with a screw or allen head screw. Remove the screw and you can access the the rest of the lock.
Feb 25, 2011 | Kwikset Professional Door Lock...
Exterior key for deadbolt just turns around and around.
It sounds like the exterior tumbler is bad, it is less expensive to just replace the whole deadbolt than to have the tumbler repaired.
Jun 15, 2010 | Kwikset Professional Door Lock...
Kwikset Smart Key Deadbolt Won't Unlock
Kwikset Smart Key locks are complete junk. I am a locksmith and I am constantly going from house to house replacing these "dumb key" locks with original kwikset pin tumbler locks. What happens is either your key or the wafers inside the lock wear slightly, slightly enough to cause your keys to not turn, and since these locks cannot be picked due to a side bar system, they must be drilled off and thrown away when this happens Unless you have another access point to get in the house. If you do remove lock from the inside, throw it in the trash, buy original kwikset and replace.
Dec 13, 2009 | Kwikset Locks & Locksmithing
Need to disassemble deadbolt with concealed screws
If it's like my deadbolt, pull the inside faceplate off. It's just pressed in place and the screws are behind it.
May 30, 2009 | Kwikset Powerbolt/Electronic Deadbolt-...
My key is stuck in my Kwikset deadbolt door lock
spray a little bit of oil where you insert the key turn it a couple of time to make sure it is lubricated then turn to correct location to pull out key hold cylinder in with finger key should pull out
Mar 26, 2009 | Kwikset Locks & Locksmithing
Loose Kwikset Chelsea Deadbolt
I just had the same problem as samrpetrich with a loose kwikset deadbolt. Here's how I fixed it - on the inside of the door, take off the latch that flips the deadbolt in and out using a very small allen key. There is a round plate cover that is snapped on top of the inside deadbolt mechanism. If you look on the bottom aspect of this round plate you'll see where it snaps on; once I saw where to apply pressure it came off easily - taking off this plate exposed the two screws beneath that were loose. Once I tightened these, I snapped the plate cover back on, but the dead bolt latch back and everything is tight again. Hope this helps.
Jan 23, 2009 | Kwikset Professional Door Lock...
Kwikset deadbolt
use the proper size alan wrench to tighten or loosen face plate . That is if you have not stripped that hole by putting the wrong tool to it. Under that plate is the 2 main screws to hold the hardware tight to the door.
Oct 27, 2008 | Kwikset Professional Door Lock...
Kwikset powerbolt 1000 keyless entry deadbolt lock with keypad
Make sure that the bolt hole on the jamb side is recessed enough so the bolt gets a full extension. Without this externsion the bolt will not engage the key release. So when you do your quarter turn you are actually turning more. Remove the strike plate and drill the hole deeper until the bolt can extend all the way. Also double check your key to make sure it is not spurred or worn.
Aug 13, 2008 | Kwikset Professional Door Lock...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
