Question about Electrolux Washing Machines
Simpson eziset 950 fills but won't start washing-- just gives a clicking sound. It will drain
5 Suggested Answers
hattonhall
  • 349 Answers
SOURCE: simpson eziset 800 clothes tangle when washing
If you can use a lollipop stick to operate the lid switch while you leave the lid open, you will be able to observe if the agitator is going smoothly back and forth EVENLY or not. If it is tending to turn just one way....this will tangle the clothing like mad!
If this is the problem it could be the switching module or capacitor that needs replacing.
Posted on Oct 25, 2009
Testimonial: "i will try it thanks "
  • 59 Answers
SOURCE: my simpson eziset 950 washing machine is leaking
OK the trasnsinssion will be full of water and the contents are being forced past the lower oil seal during agitation. You might enwuire about a new transmission or get a new machine....not the best news but if you went for a stronger make you could own it for twenty years......no joke. www.thewashingmachineman.webs.com ask tony
Posted on Sep 07, 2010
Daniel S
  • 4323 Answers
SOURCE: Can anyone please tell me
Hi
FL means flood and this error is caused to due to blocked drain pump or the drain pump itself going bad and should be replaced. It can also be the result of you turning the water level knob back to a level lower than the level of water already in the wash bowl, whilst the machine is in pause mode. Press START/PAUSE to continue the wash, or turn the water level knob to a high level to clear the fault, if the error returns then get the washer serviced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jun 04, 2011
  • 6277 Answers
SOURCE: Simpson eziset 950 washing machine
(no promises but it's worth carrying this out anyway!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 04, 2011
Hi, my simpson eziset 950 when filling with water doesn't stop filling when the cycle starts. Water overflows all through the washing cycle. When I turn the tap of it stops filling.
there is a small tube running from the bottom of the tub up to a pressure switch in the control panel that is set by what ever wash level you want
when the pressure in that tube exceeds the pressure set by the knob it does 2 things
it turns off the inlet water solenoid to stop water coming in and then starts the wash cycle
as it is starting the wash cycle , it indicates that the stop solenoid for the water inlet is either still getting power or the stop valve is faulty
try replacing that water control valve first
Jan 31, 2016 | Simpson Washing Machines
My Simpson eziset 950 keeps coming up with error HC.
No water flowing in to machine. Check taps are fully open & filters on end of hoses are clean & not blocked. If all good then you probably have a faulty inlet valve.
Dec 14, 2015 | Simpson Washing Machines
Simpson ezi 950 9.5 will not empty, rinse, spin dry.
That sounds like the pump is jammed. Have you checked for hair slides or similar? Once the pump is free to operate, your Simpson should resume normal service.
Feb 20, 2014 | Washing Machines
Eziset 950 wont spin and gives slight electric shock
Possible that the motor has failed and it has developed a leak to the body which seems to be felt over the machine, Isolate the motor and test the external voltage presence.. if absent it can be related to the motor.
Jan 12, 2013 | Simpson Washing Machines
My simpson eziset 7.5 washing maching does not hold water
Be sure that the drain line is above tub level.
Dec 04, 2012 | Simpson Washing Machines
Eziset 550 Drains as it fills
Replace the fuse inside the control panel make sure you turn if off.
depending on where you are the fuse is more than likly a "4amp slow blow" fuse
hope this helps
Dec 02, 2012 | Washing Machines
My Simpson eziset 650 won't complete a cycle it
The machine has detected that it's taking too long to fill, check the hose filters in the inlet solenoids (remove the hoses and you will see them) make sure your taps are turned up, If all seems ok then you have work inlet solenoid(s) and will need to replace 1 or both of them depending on if it does it on both hot and cold cycles.
Mar 05, 2012 | Samsung Washing Machines
Washing Machines Logo
67 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
