Question about GM 9 T-harness Remote Starter Wiring
Where can I purchase a GM9 T Harness - GM 9 T-harness Remote Starter Wiring
Installation diagram to install new Leather Laramie seats in a 2013 Dodge Laramie truck
Then your going to have to spend the big money
at Helm.Com & purchase the factory manuals
I have done that for 50 years
Obviously the ONLY place for the harness is the dealers
parts dept
Aug 15, 2014 | Cars & Trucks
I need to know what the wiring harness wires do and go to by the colors of the wires. Example (yellow=12v constant/Red=12v acc/ Black=ground)
OK, I assume you are talking about the harness of wires from the radio itself. If you are going to install this, I recommend you purchase an install wiring harness. This way you can plug into the factory harness of the vehicle. If you are attempting to hardwire the radio, please don't. If you vehicle doesn't have the factory vehicle side of the harness, try visiting the scosche or PAC website to see if they have it first. If you purchase a wiring harness, it will have all the information for the right install. Hope this helps.
Sep 05, 2011 | Car Audio & Video
Wiring diagram for 74 type 1 VW bug
If you are planning to install a radio, I recommend you purchase a wiring harness. If you vehicle doesn't have a stock harness, visit the scosche or PAC website to purchase one. If you can find the harness, it will have the diagram you are looking for. Also, a wiring harness will make installing the radio extremely easy. Hope this helps.
Aug 23, 2011 | Car Audio & Video
I have this model of Head units. I have used crimp connects to connect the unit harness to the car harness. Hooked up my turn on wires and rca cables. Now my head unit when turned on shorts in and out and...
For starters, I want to make sure. You did purchase a wiring harness that "plugs" into your vehicle, right? If not and you are attempting to hardwire to your vehicle, STOP! You run the risk of frying your entire electrical system. If you purchased a harness you can crip the wires from your head unit to the harness and the harness plugs in. DO NOT crip wires directly. You are experiencing just a little of what can happen. However, if you did purchase the correct harness, you need to check all our crimps again. Hope this helps.
Aug 21, 2011 | Car Audio & Video
I have brought a second hand unit and was wondering if I can order the wiring harness from anywhere or make one???
So you purchased another radio, right? Then it came with the harness already(for the radio and not the car). If the current radio is the factory radio then you need to purchase a wiring harness for the model/year of your car that will be compatible with your car's harness. Wal mart carries some but if you can't find it there then you need to go to your local car audio installation shop and buy one from them(it might be pricey there). Now, if your current radio is aftermarket, look to see if it already has the wire harness in the back. If it does then your good to go, just cut the harness from the radio away from the harness that plugs to the car's wire harness and reconnect using your new radio's harness(just follow the wire's color code). but if it doesn't then you need to buy one.
Jul 06, 2011 | Car Audio & Video
I need color codes wiring diagram for car stero
The easiest thing to do would be to purchase a Metra wiring harness. It plugs right in to the plugs that you will remove from the factory stereo. This simplifies wiring, as you can crimp wires by matching colors on the harness instead of mixing and matching colors on the factor wires. You can purchase this harness at PepBoys or other places where they sell car stereos. The harness looks like this. I used this harness on my 94 SL2 the same model harness applies to yours
Mar 24, 2010 | Panasonic CA VDC300 - IPod to car...
Installation wiring diagram??
No need to guess what wires go where. Buy a wiring harness for your specific year, make and model.
You make connections from your pioneer harness which are all marked, to the Harness you will purchase for your car. They cost about $20 and can be purchased at most autopart stores, or major electronic retailers.
Once you make the connections from the pioneer harness to the harness specific for your car, simply unplug your factory radio and plug in your newly wired one.
Jan 25, 2010 | Pioneer DEH-2300 CD Player
I want to change my original cd player for a pioneer
This is because you need to purchase the aftermarket-oem harness plug.This harness plugs into your original equipment radio harness and allows you to plug any aftermarket radio into the stock deck wires.After you plug the harness in you can then connect the radio wires together.Your local autoparts store or circuit city or best buy or audio express will have these radio conversion plugs.I hope I could help
Dec 24, 2009 | 2003 Ford Explorer
I am having trouble trying to install a stereo to my 1994 lincoln town car because i dont now the color code to the radio harnes so i can install it
Best thing to do is purchase a Radio Wiring Harness. These can be purchased at a Store like Circuit City, Best Buy, WalMart (not sure of your location) or a 12 Volt Specialty shop.
This harness will connect to your new radio harness and plug directly into the vehicle harness without having to cut wires. The Radio Wiring Harness will come with color identification to match to your radio harness.
FYI http://www.installdr.com/QuickWiring.html
Jan 12, 2008 | Car Audio & Video
GM 9 T-harness Remote Starter Wiring Logo
57 people viewed this question
Top Buck Vehicle Parts & Accessories Experts
Craig Butler
Craig Butler
xxxxxx xxx
andy148814
Level 1 Expert
Are you a Buck Vehicle Part and Accessory Expert? Answer questions, earn points and help others
