Iw709au Fisher & Paykel intuitive washer Code 50 fault Can you help
  • hgrally Oct 16, 2010
    Just put new valve in
    Spent the money - fitted the new valve - no dfference - wet load of washing sitting here getting mouldy
    President:
  • 1,554 Answers
A fault is detected in the hot water valve. It's either the connection to it is broken or the valve solenoid is open circuit. Pop the console open and you'll see the water inlet chamber beneath console where the inlet valves are located. Check the connections and make sure it is properly connected then check the resistance of the hot water valve on the right. Replace the valve if it reads open. Double check the connections both at the valve and the motor controller module including the continuity of the harness. The motor controller is malfunctioning if the hot valve coil and the harness are all good and making the necessary connections. But if the fault code appeared when the machine is powered off while spinning, there is no actual fault at all.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. But accepting the solution will not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Oct 15, 2010
  • Jahn27
    Jahn27 Oct 16, 2010
    Update me then about the result of the repair.
  • Jahn27
    Jahn27 Oct 16, 2010
    Did you follow what is instructed in the first post? The valve must be replaced only when the resistance reads open. Please read and follow the instructions carefully.
Fisher and paykel intuitive washer what is a code 50 please
50. (00110010) Phase 2 to 5 - Hot Valve Fault
The Motor Controller has measured a voltage from the valve diagnostic circuit that indicates
that the hot valve is faulty. The most likely cause is that the valve harness has not been
connected correctly.
Primary Source - Wiring
Action - Check valve harnesses are correctly fastened to valves.
Secondary Source - Water Valves
Action - Check valve coils are not faulty ( open circuit ). If either of these valves are low
impedance it is likely that the Motor Control output has also failed, in which case replace Motor
Controller and valve(s).
NB. Phase 5 can give fault code 50 when Smartdrive powers off while spinning. In this case
there will be no fault.
Mar 18, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel Intuitive IW709AU washing machine
this is a reset ok 1 open the door 2 put the program on the off position 3 turn the machine on 4 if you have a start button press it and hold it in for 2 mins then let go ,,,if you don't have a start button just go to follow the rest 5 put the power button on 6 shut the door it should do nothing then open the door put on you spin then shut the door wait till it finish ok job done hope this helped
Oct 18, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
Fault code 00XX000X on GW612 washer
Hi just read your posting.This fault code indicates you have a COLD WATER VALVE FAULT.The lights you marked with --x-- are the ones that are lit.Is this correct?What you need to do is to test the valve coil for OHMS resistance.It should be around 60 to 63 ohms.The water valves are located under the top panel.Please reply to tell me how you got on or if you need further assistance.
Jun 26, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
What is error code 136 on a fisher & paykel IW709AU top load washer
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
May 20, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
May 18, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Our Fisher & Paykel Washing Machine is not spinning. It gets to the spin cycle and sits there counting down. The fault code eventually said Service fault 37. What does that mean?
Emptied washer, tipped it on its side, detached drainage pipes underneath, and pulled out old fabric/lint/blockage with tweezers. Plugged in, switched on, all good.
Sep 29, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & paykel intuitive Fault code 136
Sounds like a motor problem Check the motor harness,connectors and motor for discontinuity.This can be done by taking a resistance measurement between phases of the motor harness at the motor control mudule end.should be approx 32 ohms.You can also check at the motor,I have seen a few open circuit connections where the motor connections (spade clips) Push into the plastic motor housing,Hope this helps.
Sep 12, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel intuitive washer what is a code 43 please
HI, Go to this site is has all fault codes all you do is find your product click it and it will show you the fault codes and what they mean and suggest how to fix it. http://www.repairclinic.com/0078.asp
May 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
108 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
