My Samsung flat screen monitor has gone black. I've tested all connections and they are fine. I've turned the computer off and on again with no luck. Any suggestions?
  • 85 Answers
Chack ur monitor with another computer if it work well it is ok , but if it not work also another computer contect any repairer
Posted on Jun 04, 2008
Flat screen has gone black but sound is fine
Suggest that you borrow a monitor from someone and try it on your system. If it works , you may have a defective backlight on your monitor , which means that you may want to replace the monitor. If the replacement monitor also is black , you probably have a video output problem , which would require repair of your computer.
Dec 01, 2014 | Bush Televison & Video
Samsung syncmaster 245b lights up and then turns black...
more than likely your video card has gone bad .. try to get a new video card and install it or take computer to your computer shop and have them replace it for you
May 17, 2017 | Samsung SyncMaster 245BW Monitor
The monitor was working fine,but for one night the system was not shut down and when i cancel it then it shows only black.Samsung N940
theo_christo, Get into my FIXYA profile and see if anything interests you or your BLACK or BLACK/BLANK screen symptom. Learn about the "flashlight" test that every "CCFL backlit lcd" monitor owner should know how to do and interpret the results of. 12fixlouie READ, READ, READ!
Feb 01, 2010 | Samsung SyncMaster 940N Flat panel Monitor
My dell computer screen goes black after a while after windows xp second up grade went on. what should i do without taking upgradee off or changing screens?
Right click on your desktop go down list to properties and left click under the screensaver tab click the power tab and turn off the power saver in other words change settings to always on and no hibernation
Nov 06, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
My monitor 940n samsung syncmaster gone in black...
I have just had this same problem. The problem mostlikely is a blown fuse on the inverter board. Mine was blown on the board and also a Capacitor (470nF/25V) was bad beside the Fuse.
I replaced both and monitor is working now again. After install the picture was a little grainy with little artifacts. In another post i found that the Power Supply board needs to be cleaned for unwanted residue. After that picture was fine again.
BEWARE that you need a soldering iron and a steady hand to replace these parts. If you are unfamiliar with soldering at all have an expert take a look at this. The Power boards uses 220v so DO NOT connect it to the Power when opened.
Starworx
Aug 10, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Blank screen
Hi!
A simple test is to connect another working monitor, to figure out if the problem is at cable connection or at graphics card 's output, and replace properly.
good luck!
Dec 26, 2008 | Samsung Syncmaster 730B 17" Flat Panel LCD...
My monitor works fine for 0.5 sec every time I turn on my PC and then nothing
sound like the monitor is gone.
if it is still in Warranty, you can call Samsung.
if it is out of warranty, take it to any computer repair shop. (cost may be prohibitive.)
the last option is get a mew one.
Nov 10, 2008 | Samsung SyncMaster 920N 19" LCD Monitor
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
My screen has gone black
try to reseat the vga cable of the monitor,reseat at the back of the computer and on the monitor,if the cable is disconnected,make sure that you can see the power on self test with different colors in it,if you cant see it then your monitor went bad,try to connect another monitor to your computer,see what will happen,try using other cables as well
Jul 05, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Computers & Internet Logo
David Payne
David Payne
