Question about Moen Monticello Single-Handle Kitchen Faucet with Cathedral Spout ....
I have a Moen 7730 single lever kitchen faucet. The lever is leaking. I was able to remove the set screw, but I still cannot pull the lever handle off. Any ideas?
    New Friend:
    Problem Solver:
Parts for that model can be found at amazon, take a look: Were doing more than just throwing away the key. Have a nice day
Posted on Dec 27, 2014
SOURCE: Moen single lever kitchen faucet leaking at base
check underneath spout ... if is plastic then is a "less expensive" model and the base and some internal parts may be also made of plastic. Is it a model 7100,7400 or 7600? this appears on stem on opposite side of spout... The base may be "out of round" (or "eccentric") from many yearsand may continue to leak even after replacing bottom o-ring. I have learned that if the faucet is older and plastic, advise the person to invest the money in a new Moen faucet: if you are paying someone to do the work, save time & money by having them make the switch instead of tryting to fix w/ a new o-ring, if you want to try to dis-assemble faucet and replace o-ring:
While you are changing o-ring might as well replace cartridge, get cartridge form same place you get o-ring, cartridges are supposed to be free (depending on hardware store) ...someone there should be able to help w/ dissasembly .. i hope ..
Plug drain(s) add some warm water to sink to be able to wash and rinse parts if needed, shut water off, relieve pressure by turning tap on ... plug drains!!! (tiny screws love drains...)
Most MOEN single handles: just pull top off straight up, most are just press fit on. This exposes screw. Before taking screw out make sure you have a clear area to set parts in order of removal taking care to remember alignment and order. Remove screw ...
Internal parts are usually threaded plastic so go easy on things ... unscrew retainers, remove lever control making note on how it engages the cartridge etc... this helps you figure out re-assembly
pull entire spout housing straight up (might resist a bit if crudded up) hold up to light and see if out of round.. you'll now see the brass interior...pinch out o-ring and replace. Silicone lubricant may help (get from same place as o-ring, cart. they should have little free packs..) slide spout housing back over ... re-assemble all in reverse, do not over-tighten plastic retainers, hand-tight ok .. if still leaks
might want a new one ... hope this helps
Posted on May 17, 2009
  • 58 Answers
SOURCE: how do I take apart a moen 8710 single handle
The top pops off and there is a crew under it. It's all pretty easy but when you put it back together you have to do a tricky angle kick with the handle. Watch carefully as you take the handle off and put it on and off several times to see what is needed. If you do it wrong the handle sets on top of the black thing and doesn't work right, The cartridge in the faucet pulls out with difficulty if you have hard water. There is a little clip near the the top that holds the cartridge in. You should be able to get a repair kit that has the cartridge and new O-rings for the spout.
Posted on Jun 09, 2009
SOURCE: need to fix a broken moen kitchen faucet
I had the same problem with my Aberdeen single lever with a pull-out sprayer a few months back. If you are the original owner of the faucet, it's under warranty; you shouldn't have to pay for any parts. Call: 1-800-BUY-MOEN (1-800-289-6636) and tell Customer Service what the problem is. They will send you the Handle Mechanism Kit at no charge. (Mine was part #93980 for my Aberdeen faucet, but yours may be a different part number.) It's tricky to take apart and get back together but my husband and I have zero plumbing experience and got it all fixed in about 20 minutes. The Moen.com website also has exploded parts diagrams of all their faucets so you can identify exactly what part you need, and they have some little videos and slideshows to show how to replace parts. If you can't reach Customer Service on the phone, you can go to "Contact Us" on their website and email them a description of your problem.
Posted on Jun 18, 2009
  • 44 Answers
SOURCE: I cant stop my Moen single lever kitchen faucet
1. If it's "leaking" from the body then, the O-Rings between the body of the faucet got gunked up with minerals from your water. This interferes with the seal.
The answer is to take some grit cloth/very fine sandpaper and clean the inside of the spout body. Wipe clean. I would also suggest replacing the O-Rings on the faucet body, but at the very least wipe the O-rings and faucet body clean.
THEN: lubricate the inside of the spout body AND the O-Rings with silicone grease. It's translucent and readily available and the only thing I would ever use for a faucet repair. NOT plumber's grease, NOT WD-40.
Reassemble and enjoy.
2. If it's dripping, the you need a new cartridge. You can get them for FREE from the hardware store if you have the old cartridge to trade them. The problem is that Moen cartridges are water-sealed into place and you need a special tool to break that water seal. The special tool (just a tiny piece of specifically shaped plastic, really) comes, you guessed it - with the new cartridge.
Two possible solutions: a) bite the bullet and just buy the cartridge (~$25) or buy a Moen cartridge puller, usually available from the hardware store as well for about the same price. Ask, they might even lend you one.
The point of whichever tool you end up with is to rotate the cartridge itself inside the faucet body to break the water seal so that you can pull it out with a set of pliers. There will be a retaining clip to pull out as well.
www.plumbingpartsdepot.com/moen7300.gif
http://img2.timeinc.net/toh/i/a/plumbing/faucets-toilets-07.jpg
Good Luck.
Posted on Sep 09, 2009
Testimonial: "this will give me something to work on. thanks"
1stBSP
  • 52 Answers
SOURCE: I have a Moen Single Handle kitchen faucet, it's
Replace the "O" rings that are behind the spout portion. You will have to remove the top of the faucet and pull up on the spout section. There will be a couple of "O" rings there. It is best to have Moen send the parts to you as locating the proper size "O" rings can be difficult.
Posted on Apr 06, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Hi, I have a faucet similar to this one and it is leaking from the top. I do not know how to remove the lever to replace whatever it is that may be needed. pls advise
    I believe there is a set screw behind the hot and cold symbol on handle. remove symbol to remove set screw for handle. shut off water supply to faucet. after handle is off, then you can remove inside parts. use a pair of pliers to remove retaining ring under handle. then remove faucet spout by pulling it up. replace all bad O rings then put back together. have a good day !!
    Jan 24, 2011 | Moen F7425 Chateau Single-Handle Kitchen...
    I have a single lever Moen faucet where the handle is very loose and there is no button on the back side that would reveal an allen key, so I cannot tell how to tighten it back up. What should I do?
    On almost all moen single handle faucets there is no allen set screw to hold handle on. They are secured by a screw located under Moen emblem in the center of the faucet on the top. You usually can get to the handle screw by prying cover off with small blade screwdriver or point of knife blade.. Tighten screw and hopefully this will fix your problem. Thank you.
    Nov 19, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
    Loose lever
    pop cap off and remove screw,pull handle,now lift up on cartridge ,then position handle assembly on,make sure you hook around groove and set down.tighten up if it's a newer model,it will be a hex screw , but similar process
    Apr 25, 2010 | Moen & One Handle Tub & Shower Faucet
    I have a kitchen single lever moen faucet and the cartridge wont come out. I have removed the retaining clip and all screws
    you may need to get the moen cartridge puller,either moen brand, or brass craft, they can be tough to pull some time's
    Feb 14, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    The handle is loose. It's a single lever control. The mechanism the level connects to still works fine. No leaks, but the handle is now quite wobbly, and I don't know how to tighten it. Do I pry out that...
    Remove the plastic red and blue insert or what ever color yours is under the handle in the front. Tighten the set screw with an allen wrench. Be careful not to over tighten or the screw will break off.
    Dec 27, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Water leaks from around the stem when I lift the water handle. What to do? It doesn't drip from the tap, but from around the stem part - sometimes quite a lot of water. Can I repair this myself? It's a...
    ur cartridge needs service or replacement u can turn off water supply remove lever and retaining nuts pull up cartridge and inspect the o rings for debris and or damage if good inspect cartridge for damage if looks check gaskets/o-rings in stem for same add a little vasline around o-rings and reinstall test for leak if leaking still replace all o-rings or if cartridge order and replace
    Nov 03, 2009 | Moen 87530 Touch Control Single Handle...
    Moen 7065 leaking at base of lever control in kitchen faucet
    Yes, a cartridge will probably solve it. There are two different Moen cartridges so be sure to take the old one with you so you get the correct one.
    Apr 05, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Single lever moen shower valve -can't remove handle
    if you have taken out screw then pull off if you have a handle puller use it
    Feb 23, 2009 | Moen 3175 Legend One Handle Shower Faucet...
    Moen Monticello Single-Handle Kitchen Faucet with Cathedral Spout .... Logo
    1,607 people viewed this question
    Top Moen Plumbing Experts
    john h
    Don Numinen
    Don Numinen
    Mike
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
