Question about Jenn-Air JCD2389G Side by Side Refrigerator
Jenn Air side by side
I wasn't intending to template a solution. It wasn't answered at the time and just passed along information I had picked up. As I stated in the post, someone would be along to help out. And, you did come along. Had you been in a Live Chat session with this person? I've noticed this as a weakness in the programming here and this has happened to me if the Chat goes on long enough. If you were in a Live Chat or Premium Question I think we can both contact Staff to point out this falicy and hopefully get it resolved eventually.
Sorry, if you were offended. I don't consider myself an expert on refrigerators, however, after being around for 57 years and having a mr fixit for a Dad, I've tackled my problems with refrigerators by using a simple enough theory. I gave the user a hint of where to begin if what I stated for a scenario was true. Its impossible to pay attention to what's going on on this site without gleaning new knowledge from time to time.
Again, sorry to have offended your sensibilities. Please accept my apologies.
Worldvet
  • Glenn Rogers
    Glenn Rogers Jun 02, 2008
    Okay, what a mixup. Well, nice to meet you. See you on the boards.
    Worldvet
    Brigadier General:
  • 6,966 Answers
Hi worldvet,
Actually, I was the one who apologized "...sorry worldvet, was templating again...." referring to my templated opening "...Hi, With the indulgence of XX..."
The XX should have been worldvet, it has been a habit (template) of mine to ask the indulgence of any expert who has posted ahead of me if I will be posting in the same problem. This is to acknowledge that someone was there first and I would be offering likewise a solution.
And yes she was or should I say still is on Chat. She has not closed it since I asked her to do a reset/unplug for a couple of hours.
As you can see, the window has been on for more than 12 hours. It is both an experiment (see if Chat auto closes for inactivity) and in case the user comes back.
On the other hand, perhaps not, since she posted a rejoiner/comment here and likewise an "Ask Me" post here.
Nonetheless, I thank you for the consideration and of course no offense was take.
It is me who was asking that you be not offended........
Cheers.
Posted on Jun 02, 2008
Our Jenn Air Pro model 48" side by side with ice maker is running warm. I have cleaned the condensing unit coils faithfully every two - three months. freezer runs 19 - 28 degrees frig runs 38- 43...
I just did a service call on a Jenn air side by side that had similar symptoms, It was about 9 years old. after checking to see if the evaporator coil was iced(defrost problem) and it wasn't . I had to conclude that the compressor was losing capacity(reed valves leaking). The unit I was working on had an embraco compressor made in Brazil. You could have it checked by a tech to be sure. I assume the unit is running most of the time if its cycling off then you mat just have a thermostat malfunctioning
Jun 24, 2011 | Refrigerators
I need the wall template for a jenn air micro wave oven model no.jmv8208ds
That is part number W10188240 and you can order it here.
You can download the installation instructions free here.
The owner's manual is here.
Dec 18, 2010 | Jenn-Air Microwave Ovens
I have a Jenn-Aire side-by-side refrigerator Model #JCB2280HES, Serial #10024253EP. The warranty expired in February 2010. The food in the bottom half of both the freezer and refrigerator is frozen and...
Hi!!
Check to see if the evaporator fan behind the freezer wall (remove wall) is running. If it isnt the air will not flow properly in the unit. Replace the fan motor and it will fix it.
Good Luck!!
Jul 29, 2010 | Jenn-Air JCB2280HES Side by Side...
Jenn air downdraft cooktop. We had a new Jenn Air
This is normal, Jenn Air along with many manufactures use one ignition module for all the burners. So when you turn one knob on all the ignitors on top will spark but gas will only flow to the burner with the knob on.
Here is a copy paste from a Jenn Air Owners Manual, I do not have your model number so I cannot be sure this is the exact phrase in your book.
I hope this helps!
To Set:
1. Push in and turn knob counterclockwise to light the burner.
All surface burners will click. Only the burner that has been
turned on will produce a flame.
2. Turn knob to anywhere between HIGH and LOW. Use the
following chart as a guide when setting heat levels.
May 02, 2010 | Jenn-Air Freezers
I have an old Jenn Air microwave above the range I need to remove
If you only need to remove the oven from the housing, there will be (should be!) 2 small screws at each side of the trim, 2 top and 2 bottom. Remove these and the oven should slide straight out. These screws will be into the side panels of the housing, but there may only be two fitted! Depending what you are intending to do next, you may have to disconnect the supply cable and/or dismantle the oven to replace parts. You will need two people to lower it to the floor, have a stool or similar handy in case the cable length is too short to allow this.
Good Luck
Thanks
Jun 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing Jenn-air down draft with new unit
Since Jenn-Air has been acquired by Whirlpool, there have been an explosion of problems with their appliances.
Please research your intended purchase before deciding on a replacement:
Jenn-Air info
Considering the array of early failures everyone seems to be having with appliances (US made and foreign) bought in the last few years, I couldn't even recommend a manufacturer any more.
Jan 25, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air Microwave Bulb and Filters Inaccessible - Design Flaw - Help!
It's not a design flaw. The microwave was incorrectly mounted.
The installation instructions (installation kit) included a template for proper alignment of the microwave on the cabinetry.
If it had been aligned with the template, the two top grill screws would be easily accessible.
The grille must be removed to access the lights and the charcoal filters, which should be changed every 6-12 months if they are used.
If they are in place and not changed regularly, critical ventilation and cooling can be affected.
Your owner's manual can be downloaded free here, and it shows you how to change the bulbs and filter.
It will have to be remounted properly.
Nov 06, 2008 | Jenn-Air Microwave Ovens
Jenn Air Oven Repair
HI thanks for the question. you can by pass the clock so the oven will work without the timer. call a tech near you, and ask them to by pass the timer. if i could get the wiring diagram, i could tell you how . its a simple thing to do. thanks the appliance doc. please rate my answer.thanks
Oct 08, 2008 | Jenn-Air Ovens
Jenn-Air side by side won't give water
hi thanks for the question yes the small tube that enters the ice maker can freeze up stopping the water flow check this thanks the appliance doc
Sep 16, 2008 | Jenn-Air JCB2280HES Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
82 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
