Question about HP f2105 21" LCD Monitor
Monitor works ok for a short while (10-20) minutes then screen goes black. Restart and the same results.
  • 11,361 Answers
You will have to open up and take the voltage readins before and after the problem occurs. It may be as simple as cold solder joints.
http://s807.photobucket.com/albums/yy352/budm/HP%20F2105/
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 15, 2010
Hyundai monitor on for 5 minutes and screen goes black
Have you ever opened up the monitor to clean the dust out,it could be your heating up and then letting it sit will bring it back.If your unsure how to do this ask a tech.
Apr 21, 2017 | Hyundai X224W
Unit starts ok then any where from 30 sec to 1 minute the screen goes black.power light good. opened unit capacitors good .if u put a flashlight by it u see the image. Is it hard to cnange the backlight...
hi,
Before going to replace CCFL check the inverter of the CCFL. Normally the inverter get faulty. There is possibility that the winding of the high voltage transformer get shorted or its driver transistor may get faulty. check the same
ok
Apr 15, 2011 | Acer P191WBD LCD Monitor
Toshiba satellite l300d, i am having this issue and have been up all night working on it, the toshiba satellite l300d with amd cpu was showing a black screen while responding otherwise, (lights fans etc)...
There's a good possibility it's the video card or motherboard. Have you tried pluging it in to a monitor? Some times the bord is more expensive and time consuming meany people I know that have had this problem just cut there losses. Sorry hate to be the bearer of bad news.
I feel your pain
Best of luck
Mar 01, 2011 | Toshiba Satellite Pro L300 Notebook
After on for 5 minute tha screen go blank with blinking amber light
isa_cpu, Hi there, have you done the flashlight test after screen goes to BLACK? How old is E228WFP ?? Is it under warranty? Did it work "perfectly" the day before? Did you try it at another pc and get same result? If you shine a bright flashlight close to the screen after it goes BLACK, look very closely to see if Win-Desktop is still being displayed on lcd screen. In any case, if you don't own a DMM and soldering iron you still have these options! Call DELL and see if they have a swapout program. You send your's+$40-$90 and they send you a REFURBISHED same model in return with new cold-cathode-fluorescent-tubes w/inverter&smps installed. or Check for local TV/Monitor guy that knows forward&backwards all there is to know about fixing lcd monitors. It may also be informative to search web for Bad Capacitors in LCD Monitors or Repair of LCD monitors and also check YOUTUBE for short vids on LCD repair or disassembly. I'm louie12fix on fixya or lmistyrel@ aol.com Bye for now.
Apr 25, 2009 | Dell E228WFP LCD Monitor
The monitor get on for a second, then it goes black
sounds like a blown backlight (the TFT screen is lit from behind by thin white flourescenet type tubes,
if these become faulty then you cannot see the display output as it is no longer lit from behind
Mar 27, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Monitor Randomly Turns Black
I have exactly the same problem with my Benq FP71E+ ..
What i found is a temp fix is this :
When monitor dims and goes black i turn it off , hit the bottom left side (near the BENQ logo) turn it on again and it works ..
This works every time for me . But after a while it switches off again , could be 5 minutes could be 5 hours . Its random
May 02, 2008 | BenQ FP71E 17" LCD Monitor
Monitor blacks out after running for about 25 mins
Ok based on just the monitor turning off Lets try this,,
FOR WINDOWS XP
1.) Right click on your desktop
2.) Choose properties
3.) Click on the screen saver tab
4.) Click power
5.) Set The POWER SCHEME to Home/Office Desk
6.) Set the Turn Off monitor to Never
7.) Set the Turn Off hard disk and system Stand By to never
8.) Click apply then ok
9.) Repeat steps 1 - 3
10.) Set the wait time to 30 minutes
11.) Click Ok
12. Shut down and restart your system and wait 30 minutes to see if the monitor will shut off if it doesnt then Your good to go
If it does Then disable the screen saver.. and wait half hour to see what happens
POST BACK HERE AND TELL ME YOUR RESULTS OF THE ABOVE SO WE CAN TRY SOMETHING ELSE
Jan 16, 2008 | Computers & Internet
FPD 1760 Flat screen monitor
Take a flashlight and shine it at the LCD screen while after it goes black. If you can see the screen images still then your backlight is the problem. Let us know what the results are and please don't forget to rate this post.
Feb 05, 2007 | Gateway FPD1760 17" LCD Monitor
HP f2105 21" LCD Monitor Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
