Question about Maytag Neptune MAH5500B Front Load Washer
Hi I have a Maytag Neptune model MAH5500BWW Serial B4585662GA. When I turn the drum, I can still hear water inside/behind the drum. Thank you
  • 375 Answers
This is normal. There is a balance ring filled with water attached to the inner drum. The balance ring is sealed and is not supposed to be empty. When you turn the inner drum by hand, you're hearing the water settling down from the now upper chambers of the balance ring.
Posted on Nov 02, 2010
My Maytag Neptune Washer Model MAH3000AWW, Serial 35269627WB drains the visible water that can be seen inside the drum, but then does not drain the rest of the water that remains between the drum and its...
Hello, The earlier Maytag Neptune front loaders have a balance ring on the inner tub that has liquid in it and that causes the sloshing sound when you turn the tub by hand. That is normal.
I noticed that you have a MAH3000... Have you replaced your door latch wax motor yet? If not, it will fail and damage your control board located behind the timer. See NeptuneHelpSong for a video that explains the failure.
I hope this helps...
Apr 25, 2011 | Maytag Neptune Washer
Model MAH5500BWW Why after I am all done with the wash and have everything unloaded can I hear water below the tub when I turn the tub manually? This is at all times.
This is not water that you hear. It is a form of liquid ballast that stabilizes the drum and counterbalances the weight of the clothes when the machine spins the clothes dry.
Aug 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washer is leaking water from under the washer. what could the problem be
my washer is leaking water from under the washer
model #: MAH5500BWW SERIAL #10760798YY
Mar 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
I was wanting to know the year of the maytag neptune washer? model # MAH5500BWW
Try and get the serial number then contact a Maytag agent. The serial number in most cases is a date code.
Jun 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune front end washer. model #
hi..
First clean out your outlet filter. If this does not work, open up behind and tighten all points where wires are joined; due to vibrations these might have come loose. Plug off the wall first!!..
thank u
May 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Tub fills with water
replace water valve in the washer. Serial number is needed to find the correct part number. It's likely 22003834, but call any parts supplier with model/serial numbers to verify.
Good luck,
Vlad
First Choice Appliance
Jan 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dear rxpert. I have washer Maytag Neptune Model MAH5500BWW Model 67787785ZH. After, The washer completed the Work, that still have water inside of washer (I hand to turned the basket inside the washer I...
This is actually normal. It is normal to have water between the wash basket (stainless steel tub) and the outer wash tub (plastic). There shouldn't be a problem unless the water is excessive enough to pool inside the wash tub itself or overflow onto the floor. You will always find a small amount of residual water between the tubs. Don't waste your money on a service call unless you absolutely have to.
Apr 10, 2008 | Washing Machines
Maytag neptune
   This can be a bad inlet water valve.  Does it stop filling when you unplug unit?  If it does,  your valve is probably ok.  If it doesn't,  replace inlet valve assembly.
   If water does stop,  you may have problem where the air dome has become dislodged.  You need to remove a inner drum vane and then turn this spot to the bottom.  There should be a black ruuber unit there.  This is the air dome.  It mist be seated.
Oct 21, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
1,161 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
