Question about Sony VPL-VW100 (Ruby) Multimedia Projector
The screen gets darker with a red tint sometimes it only lasts a few minutes sometimes longer. Sometimes it doesn't happen at all
  • billbuffalo Oct 15, 2010
    thanks--have had it 5 years. I am on my second lamp. Last time I got a message saying lamp life was ending. As well I usually get a message to clean the filter. I am getting neither one now. I will try your suggestion and let you know how it works.
  • Sony Master
  • 13,433 Answers
Hello, and thanks for using FixYa.
Sounds like the lamp might have a problem, I would clean out the dust from the machine and see if it improves. Use canned air and a vacuum cleaner to such out the dust if you don't want to take it apart - and avoid warranty if it still has it.
Now how old, how long has the lamp been running?
If it is the first time this projector is being connected to the device it is connected on now, the signal selection might be set wrong. Check usermanual pages 47 for the signal settings and make sure they are correct.
Please get the user manual if you don't have it from here http://www.projectorcentral.com/pdf/projector_manual_3020.pdf
After you have checked the signal settings then on page 66 follow the instructions to clean the dust filters / air filters. You could also Take out the lamp from the unit, clean the machine from dust with vacuumcleaner and compressed air / canned air only. with better airflow the unit will last much longer.
If you have followed the instructions, the picture should have improved. If it has not, how old is the lamp, how many hours has it been used?
Posted on Oct 14, 2010
  • Ekse Oct 15, 2010
    okay, then most likely the lamp is nearing its end of life. you will have to replace the lamp soon.
I have a rca HDTV model R61WH76 after being on for about 15 mins or so I will lose the picture but will stell be able to hear the program. I cleaned out all the dust bunnies etc. to see if this would
I haven't found a video for a 61" model but if your tv is a rear projection tv I suspect that your problem may be similar to this 52" model..
There are other troubleshooting videos on youtube too.
Even if your problem isn't the same you should get some idea of what may be involved.
Sep 26, 2014 | RCA R61WH76 61" HDTV
I have a 52 in. Sony HD ready rear projection tv and recently sometimes and I say sometimes because this happens randomly but the screen begins to flicker a green tint and then it shuts itself off and the...
Some of the early sets had this issue--they had bad picture tubes and set will turn rather bright red, green or blue and shut off.
The tubes for those sets (what model do you have?) are no longer available.
There may be a simple way to resolve this at least for some time depending on the model number--it will require no parts replaced and only a screw driver to adjust something in the set.
Jun 13, 2012 | Televison & Video
Samsung LNT4661 FX/XAA when you turn tv on picture is ok after a few minutes bottom half of screen puts red tint horizontaly across screen it will sometimes go away after 15 or 20 min. What is the...
Hi there are two things that could be causing these this. Either your t-con board is bad or your screen is bad. Since screens are so expensive I would replace the T-con board to see if that fixes the problem.
You can get parts for this TV at www.interliquidparts.com
Feb 29, 2012 | Televison & Video
My tv no longer shows the color red. No idea what
I have sound but my tv screen is black. Sometimes when I turn on the tv I get a picture but after 15 minutes or so the screen goes black again.
It's a 4 year old LCD.
Nov 23, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Epson PowerLite 83+ goes completely green or red
make sure the signal matches. you could reset the settings to factory default.
Nov 10, 2009 | Epson PowerLite® 83c LCD Projector
2004 Corolla - A/C and heater problem!
the blower motor could be on its way out other possibility's is a loose connector.
Aug 12, 2009 | 2004 Toyota Corolla
Green tint
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem
thank u
rate me
May 29, 2009 | Sanyo DP42746 42 in. Plasma Television
Laptop screen keeps getting darker
Is it happening when u do not use the laptop for few minutes??
Or it could be something to do with the power on the battery which is reducing due to usage. Screen would get darker to make optimum usage of battery and give longer back ups.
Jan 26, 2009 | Computers & Internet
Red faces
You will need a qualified TV technician for this, as there are no user servicable parts in your set, but there are hazardous voltages present, even when the set is off & unplugged.
Oct 23, 2006 | Philips Magnavox 51MP392H Rear Projection...
Sony VPL-VW100 (Ruby) Multimedia Projector Logo
48 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
