Question about Kenmore Elite HE4 Electric Dryer
My Kenmore 500 series electric dryer seems to be heating, but just stopped running. I hit the start button, and the drum heated up, but did not start turning. I'm guessing that the start switch is not the problem, since the element is heating. Please tell me there is a simple solution. Thanks. Mark G
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 15, 2010
I have a Kenmore 70 series large capacity front load dryer. It will heat but the drum just stopped turning. I do not believe it is the belt. You can turn the drum with your hand very easily and...
heatman101
Aug 20, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore 500 series dryer blows cool air only
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 10, 2010 | Zanussi TC180W Electric Portable Dryer
I have a kenmore series 80 electric dryer. It will will run for around a minute and then cut off. seems to be over heating. when I turn the heat setting down to the lowest setting it will run longer. If I...
that sounds like the dryer motor going bad,most of the time they run alittle then stop,or when you push the start button it just buzzes-mike
Mar 02, 2010 | Kenmore Dryers
My Kenmore 90 series electric dryer not running
http://www.washerwizzards.com ,,,,check the thermofuse in the back,,it is a white fuse coverd in plastic with 2 wires attached ,,,,hook the 2 wires together and test it
Dec 23, 2009 | Kenmore 63942 Dryer
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
Kenmore 90 Plus Series Electric Dryer trip
It sounds like the motor switch which is actually inside the motor on the model. It is very expensive to replace motor so it may not be worth fixing......
Although I stick to the above statement; I have seen cases where a thermal fuse wire has come loose and perhaps sometimes touching(allowing heat) and sometimes not(hitting something blowing the breaker.... Check all wires on blower vent area... GOODLUCK!!!
Dec 17, 2007 | Dryers
Bosch nexxt 500 series dryer
I just had the same problem, motor runs but no heat. I had a fun time figuring out how take the front panel off, hint the rubber seal comes off easily. It looks like mine tripped the resettable over heat sensor. So far so good.
Jul 30, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
132 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
