Question about LG RU52SZ30 52" Television
MY LG MODEL RU52SZ30 ( 2003), HAS A YELLOW LIGHT SHOWING BELOW THE LAMP ICON. IS THE LAMP BAD? IT STILL LOOKS PRETTY GOOD ON SCREEN EXCEPT FOR THE A BLUE TINT AREA ON THE RIGHT SIDE OF THE SCREEN
  • LG Master
  • 5,100 Answers
Yes, the lamp is nearing the end of life when the lamp light is a steady orange (yellow). Order a new one and replace it. (When other parts of the lamp system fail, you will see a blinking red light.)
I hope this helps.
Posted on Oct 14, 2010
Testimonial: "thanks for your help. i'll try what you suggested"
  • Cindy Wells Oct 15, 2010
    You're welcome.
REMAINING LAMP HOURS
Press MENU on the remote (with the projector running of course).
In the window that comes up on screen, there are a series of icons on the left side of the screen, and the currently selected one will be highlighted (yellow if memory serves me correctly) scroll down through the icons to the very last one - the Information icon.
Press ENTER
The Lamp Timer (lamp hours) will now be showing on the screen, below technical info about the current signal feeding the projector. The 'Lamp Timer' information is at about the centre of the screen :o)
Mar 25, 2014 | Sony VPL-ES2 LCD Projector
I have a mitsubishi wd 62530 08' model had blue showing through left side of tv working towords the middle, screen looks greenish yellow what is the problem
This is a known issue with these sets.
They use an OPTICAL LIGHT ENGINE which the lamp shines directly into: the blue section (it has blue,red and green sections with lens and baffles) is the first to get hit by the light and its heat.
Commonly it burns that area (blue) first.
This is permanent damage and either the display chip has to be replaced (over 200 part and not a do it yourself replacement) or the entire engine has to be replaced.
Sony and similar brands have the same problem--Sony is fixing a lot of them even if out of warranty for free (class action lawsuit!).
This is a 98% certainty in your case.
You may want to contact Mitsubishi to see what if anything they will do.
You might not get a straight answer from them so GOOGLE the model number and research this on the internet-------
Apr 01, 2012 | Televison & Video
Lamp light is yellow. Replaced bulb still not working1
CHECK AND MAKE SURE THAT THE LAMP DOOR IS SECURE ON THE BACK OF THE TV.
Dec 16, 2010 | Mitsubishi WD-57733 57" HDTV
What does a lamp bulb look like when it is no longer good or working? does it look burnt out? Mine looks like nothing it broken or burnt, but my projector isn't showing a picture on the screen. the fan...
look at the lamp head on. an obviously bad lamp will have cracks in the mirror, the stem can have frosty,veiny looking blisters or bubbles, the mirror can have lots of bubbles. And sometimes there are just no obvious signs.
Jun 14, 2010 | InFocus LS 110 Multimedia Projector
LG RU-44SZ63D turned off while watching, heard click and red light indicator went on, tried to turn the TV on but after the yellow light blinks for a few seconds, it turns red and shuts down again.
Locate and remove the lamp which should be behind a removable door on the right side as you look from the front of the set.
If it is shattered you have found your problem; if it looks undamaged you have either a possible bad ballast which powers it or a power problem.
This model can be difficult to work on as there are at least 3 different versions which use different circuit boards.
Let me know what you find as I am here to help.
SD TECH
May 13, 2010 | LG RU-44SZ51D 44" Rear Projection...
LG RU-44SZ63D turned off while watching, heard click noise
Problem is either you need to replace Lamp or your Lamp Fan is defective. For Lamp Call Mats 1-800-68-1118
Color Wheel
I'm pretty sure if the color wheel spins with no vibration that it's not the colorwheel. I would have to say that your cable is bad. If it has been bent repeatedly near the connection that the wires could be breaking down. Try a brand new cable.
May 06, 2010 | Panasonic PT-D4000U Projector
Audio is working, no picture
you have either a defcetive signal pwb, FMT pwb or light engine. Does the menus appear clear when you press menu?
May 20, 2009 | Mitsubishi WD-62725 62" Rear Projection...
LG dlp rear projection Tv model 56DC1D. When switching on the yellow light flashes for about 2 minutes then the red lamp light flashes twice before switching back to standby mode. The TV is approx 18...
First, check if any of the vents are clogged with dust. If not, try another lamp. They don't always look bad when they are bad. If you feel handy, by the lamp itself without the cage and swap in the new lamp. Make sure you do not touch the new lamp (finger oil is bad for the lamp. The oil creates a hot spot and early failure).
Nov 06, 2008 | Televison & Video
LG RU52SZ30 52" Television Logo
281 people viewed this question
Computer Repairing
Computer Repairing
