Question about Verbatim 160GB USB FireLite: The "drive for perfection" is built into our line of FireLite portable external ... 160 GB Hard Drive
Hey there not sure if both usbs on this dual cable are to be plugged into my PC. The drive keeps flashing a blue light but my computer is not recognising it.
    Genius:
  • 1,016 Answers
In most case's only one USB needs to be connected, but you need to load the driver for it from the disks which you would have received for it.
Hope this helps.
Thanks
Jason
Posted on Oct 14, 2010
The blue light keeps flashing on and off on my Seagate 4Tb XHD. It won't show up on the finder as connected. What causes that?
follow these steps:
  1. Make sure the computer and external hard drive are powered on.
  2. Safely remove the drive from the computer (if possible).
  3. Disconnect the external drive's USB or FireWire cable.
  4. Disconnect the power supply plug from the external drive.
  5. Power off the computer.
  6. Disconnect the computer's power supply cord for 60 seconds.
  7. Reconnect the computer.
  8. Power on the computer.
  9. Connect the power supply to the external drive.
  10. Connect the drive's USB or FireWire cable and check for detection.
If that does not correct the behavior, and if the drive is also not detected by your computer, the blinking light is probably a symptom of a larger problem. If those steps do not return the drive to correct function, it is very possible, even probable, that the drive has failed and needs to be replaced
Dec 22, 2014 | Seagate Computers & Internet
A blue and red flashing light and won't connect to computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | NexxTech new 3.5-inch hard drive enclosure...
My simpledrive has a flashing blue light and does not show on pc
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Apr 22, 2012 | SimpleTech Computers & Internet
Red and blue light keeps flashing come up with unknown device
is this an external usb drive or just a usb drive??
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Sep 23, 2011 | Trekstor Computers & Internet
My computer will not reconize the external hard drive. The red light is on and the blue light is blinking. Help!
Listen closely to the drive, if it sounds like it is clicking then it is probably not getting enough power through the usb. You should have received a cable with a split dual USB plug for extra power. Make sure that both large USB plugs are in the computer while the smaller one is attached to the drive, this will give it enough power to start working. If it is not clicking and has plenty of power then it could be that it is mapped to a drive letter that is already in use. Under device manager, (right click my computer and select manage then click on disk management) If you see the device in there then you can right click on the bar graph representation of the disk and select to change drive letter and paths. This will allow you to remove the conflict and have it show up again.
Jul 06, 2011 | SimpleTech 250GB USB2.0 7200 RPM External...
Fantom titanium external light turns red on connecting
Red is a failure warning but if it only hasppens with the usb plugged in it's mostly likey a failure in the IDE/SATA to USB conversion board.
Take the drive to your local PC shop, ask the techs there to pull the hard drive out of your phantom and test it in a new enclosure. If it works there, buy the enclosure, if it doesn't reply back and let me kow your Country, State and City and I can recommend a pro to look at the actual harddrive if you need files recovered from it.
Hope this helps FixYa
Sep 03, 2009 | Fantom Titanium Hard Drive
Can't detect my drive
It could need a power adapter if it cannot draw enough from your usb port. I would try another port on the back of your PC.
Aug 02, 2008 | SimpleTech STORAGE, SIMPLETECH 500GB PIN...
Light doesn't turn blue at all
Plug it into another computer if possible, clear ALL files on it.
You must of been sending something to it when you flicked the switch, they would normally go off straight away.
(Backup on the other computer first)
If this does not work then you may want to see if you can see a usb stick in your USB ports. If you can it's a fault with the harddrive, nothing else you can do.
Mar 31, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Verbatim 160GB USB FireLite: The "drive for perfection" is built into our line of FireLite portable external ... 160 GB Hard Drive Logo
149 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
