Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Hotpoint ultima extra washer dryer WDM73
I have the e15 report on the machine. I know its probably the fiter blocked, Can you give me more detailed instructions on how to clear he blckage. Do you reckon I could do it myself? I'm average at these things but willing to give anything a go once.
  • Anonymous Aug 02, 2008
    machine will not pump out showing E15, pump is clear of obstruction.
I found this manual,if you know what your problem is this might show how to change the faulty bit. I dont know what machine this is but they all seem pretty simular, i used this to change my door lock.
Posted on Jun 16, 2008
What is error message e15
What brand dishwasher? Model number might help too.
If it is a Bosch this might be the answer.
The E15 fault code means that the dishwasher is not receiving water through the water supply hose, or at least that what the machine thinks anyway.
E15= Check Water Inlet supply*
This can be caused by several reasons.
1. The filters in your inlet hose or inlet valve are blocked and need cleaning.
2. The inlet water supply valve is faulty and worn out, not allowing water in fast enough in relation to the set amount of time it takes to fill the machine for washing etc..
3. The water supply isnt turned on fully underneath the sink?
You will need to undo the water inlet hose from under the sink and check to see if there is a filter in that end of the hose and check to see if it needs cleaning. It will be of the wire Gauss type.
If not, then you will need to uninstall the dishwasher and pull it out from the cabinet to check the inlet valve where the inlet hose connects to at the bottom rear of the machine.
The valve itself will have a filter, where the hose attaches to. Undo the hose and visually check the filter in the valve for blockage/restrictions.
If the above brings no results, then you probably need a new inlet valve for the dishwasher.
Sep 04, 2014 | Dishwashers
Washing powder compartment fills up with water
It's probably just caked with powder or conditioner and needs cleaned. Your handbook gives instructions on how to remove the drawer. Alternatively the dispenser to drum inlet hose may be blocked and some hot water may clear that.
Jul 13, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
Where is the filter? And how do I remove front panel?
It's probably behind a panel at the front of the machine at the bottom nearest the floor. The panel will clip or pull off. You haven't specified what model your machine is!!
here's an example video How to clear blocked pump on your Hotpoint Washing Machine
May 18, 2014 | Washing Machines
Showing fault E15
I'm going to assume this is an SMS GV640 bosch, E15 indicates there is water in the base under the tank and therefore a leak. Pull the front of the machine onto a towel and pivot the whole machine forward (ie lift the back off the floor at about 45 degrees). If you see water flow from under the machine, you have a leak. You may find the the machine will now seem to work, but you will have to trace the leak or it will activate the flood device and give you E15 again.
Mar 23, 2013 | Bosch Dishwashers
Dishwasher won't drain
Either drain motor is blocked with product, or motor is actually faulty. Remove front kick panel to locate drain motor. Normally small white motor attached to the frame by 3 screws. Once off, remove obstruction (careful not to lose or dislodge the o ring. major leak otherwise.).If obstruction not found, check pipe for blckage. If all clear, possibly motor is defective.Need to check motor manually. Reinstall then test.
Jun 04, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
E15 eeror message
If Hotpoint or Creda check for:
E15: Water not pumping out, or pumping out too slowly. Check pump for obstruction or foreign objects jamming pump, or kinked drain hose, or blocked outlet/U-BEND.
Feb 24, 2010 | Hotpoint Washing Machines
Hoptopint wd72 - E15 and wont take water in
Hi, - fixed this myself. Problem was a blocked pipe from front of drum to pressure switch. - The machine was fooled in to thinking it had water in when it hadnt! - hence the error 15. that was also why it would not fill. - im guessing the heater blew because it was on with no water to keep it cool!
Jan 09, 2010 | Hotpoint Ultima WD72 Front Load...
E15 code on display of Hotpoint ultima extra WD72.
E15 means that it is not draining fast enough. As well as checking the outlet pipes, check the filter leading to the pump. Disconnect the power and pipe. If possible take outside because there will be a residual amount of water. Remove the back panel, then disconnect the locking rings holding the tubes on. Your main target should be the big downflow rubber tube from the drum, in here is a plastic filter. In mine I found a child's sock... plus slime. Problem solved.
Dec 20, 2009 | Hotpoint Washing Machines
E15 water is draining but clothes still sodden,
The problem is your pump or filter is blocked.
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me plz……………………….
Mar 21, 2009 | Hotpoint Aquarius WD640 Front Load...
Pana fax uf 8000
I'm not sure which key is used on that model but look for a key that says one of these: menu/user settings/reports/program.
what you are really trying to do is get to your reports programming section, then select tx report, then choose print tx report and will fix your problem, you may want to change you fax number if that number changed also.
Mar 14, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
420 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
