Question about Acer TravelMate 529ATX Notebook
Wont boot says cmos battery bad - Acer TravelMate 529ATX Notebook
  • 1,557 Answers
Have not seen this problem for years the little silver battery in your motherboard has gone bad and needs to be replaced a computer company should charge around $80 to fix ;)
Posted on Oct 14, 2010
Testimonial: "cheers mate AAAA+++++"
Have an HP pavilion G7 wont boot, no power light , replaced mother board, still wont boot. Removed battery plugged in a/c cord still no boot? Help?
G7 what, it has full model number not just G7,
that means near zero. in fact.
what does boot mean? its a long serial process.
sure no windows (no windows stated, XP?)
the power must turn on and first.
hear that fan run? feel it blow? vents clean first.
The G7 Pavilion is both a desktop PC and a Laptop,
silly no, but HP did that, google G7 , SEE?
I guess the BATTERY thing is not the CMOS battery but the huge , Laptop battery. smart act taking it out first. they do short.
but what about sound, and the fan blowing. it must blow
or the Power pack is dead.
i bet the old mother board was ok. and you didnt do the strip down test to prove that.
ever heard of these?
1: CMOS RTC BIOS NVRAM COIN cell, replace it first.
if not the BIOS can not load configs. ever. again. bad bad bad.
2: power pack dead if fan is dead. replace it its only $8
or use a voltmeter is it enters the mobo 19vdc, is ok, less that 18v not.
3: then if the fan is still dead, power dead, BIOS dead.
and external VGA port dead to external monitors, then
we pull modules off the MOBO, up to 6 or more
they all can short and when they do, power goes to ZERO
the regulators do that by DESIGN.
(the no catch fire deal)
sure wish you said (lap or desk top sure did)
after all the Desktop PSU may be bad, if its fan is dead.
Nov 12, 2017 | HP Computers & Internet
My IBM ThinkPad 600e wont finish booting it brings up the 00173 00301 and 00163 code after pressing okay it brings some error box and gets stuck...anything I could do?
Most errors of this kind with a Thinkpad involve a bad CMOS battery. Try installing a new battery. If there is a BatteriesPlus store nearby, they can usually supply you with a battery and may be able to install it for you. It is my understanding that the CMOS battery in these units has soldered/welded battery leads instead of just being a coin cell that slips into a holder.
Feb 08, 2017 | IBM Computers & Internet
Compaq presario sr2150nx battery failed
When the cmos battery goes bad, you can simply replace it, but a dead cmos battery will not stop your computer from booting.
Jan 06, 2014 | Computers & Internet
Laptop wont start
This issue is often caused by either an incorrect setting in CMOS Setup or a bad boot device, such as a bad hard disk drive.
  1. Verify your boot options are properly set in CMOS setup. I recommend having the CD or disc drive as your first boot device and then hard drive as the second boot device.
  2. If your CMOS Setup has an option to boot from the LAN disable this option.
  3. If you have changed any CMOS settings, make sure to save and reboot the computer.
If this does not resolve the issue, try resetting the CMOS values to the default settings, save and exit.
If this fixes the problem but it reoccurs again later you main need a new cmos battery. Or keep your battery always slightly charged.
Nov 16, 2011 | Toshiba Computers & Internet
My Asus Eee pc 900 is very slow booting. I disconceted the cmos battery and this helped for a few weeks but am now back to taking a good 20 mins to boot, Now the cmos trick wont work. Anyone got any ideas...
Sounds like you disconnecting the cmos and it helping was just coincidence.The hard drive may be bad or your OS needs to be repaired or reinstalled.Alot of times when it does as you indicated the boot sector maybe corrupt or your hard drive has bad sectors where the boot info was written on the hard disk
Jan 21, 2011 | ASUS Eee PC 900 PC Notebook
Asus Z83V will not start when Power-on pressed, only power-light for 2 sec, then nothing, but ventilator is running. This is independent of line- or batterie-operation. The problem came after correct...
A bad cmos battery will not affect startup - its role is to main settings such as clock, boot up preferences, etc. If that battery goes bad computer will still boot. Settings are lost and unit has to be reset.
Issue can be caused by corrupted cmos, bad hard drive, corrupted OS, bad memory, bad peripheral. Does the cmos post? If it does post and you see the initial gobbly g--k on screen, chances are it is good and the issue lies else where. Using other computer do diagnostics on hard drive. If it checks out ok, it may be a corrupted OS or the master boot up record of the hard drive. If memory is bad there is a usual 2 beep signal at posting time. And if you think it is the OS use the restore disks that you have for the computer. If none
you will have to get an OS disk for software that is compatible with your unit. Good luck.
Sep 06, 2017 | ASUS Z83V Notebook
Wont boot without password
Unplug the laptop and remove the main battery. Remove the cover for the memory modules and you will also see the CMOS backup battery located there. Unplug it for 10-15 mins, then plug it back in, insert your main battery, ac adapter and boot the system. You will need to reset the system date again once the CMOS is cleared.
Jan 10, 2010 | IBM Computers & Internet
Wont start...
Well first of all when you say "my cou wont start up" I assume that you're talking about your "computer". Secondly if it is your computer that is having the problem, and it's not booting up, it could be a couple of things. First I would try checking to see if the CMOS battery is dead, the CMOS battery is a silver, flat, round like object usually looks like a watch battery, you may want to replace that. If problem still persists, then you could have a bad power-supply. Take it to a reputable PC repair shop, and have them test the power-supply. My ultimate guess is that it's the power supply that is bad.
Jan 21, 2009 | Compaq D51C PC Desktop
While booting error " bios shadowed " & 0175: bad crc1, stop post task
sounds like cmos battery flat small battery inside pc to retain cmos setting when pc switched off
Oct 02, 2008 | IBM ThinkPad T20 2647 Notebook
CMOS/GPNU Checksum Bad 0085
You may have a bad CMOS battery. Does it do this on restarts as well as cold boots.....if you only receive this message on cold boots, then you have a dead battery.
Nov 26, 2007 | Intel Motherboard
Acer TravelMate 529ATX Notebook Logo
183 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
