Try using FEATURE **2223772 2223772#. This is the access server admin. There might be a path there to reset passwords. On the MICS side use FEATURE **266344 266344# to access the system programming and password reset features. The best place to get free help from telco professionals (especially Nortel) visit Telephone Tech Talk - http://sundance-communications.com/forum/
You can remove or change the Window's User or administrator's password and privileges. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/http://67.20.82.163/
the first time you access http://192.168.0.50 it will ask you for username and password. Type the default username and password. If you don't know try one of these:
Username: admin Password: password
Username: admin Password: No password (just hit enter after you type the username)
There should be a small reset button on router which will reset to default,u will need. A pencil or similar to press it, the default username is usually admin and password is. Admin
try the user as admin and the password as admin.. If my memory serves, there is also a master reset switch.. Look for a small hole in the rear of the case, power the unit off, press and hold a small pin into the hole to hold the switch in and then switch the power back on.. I know ya need three hands to do this... If no hole is present, check inside the case on the board for the reset switch..
Here is a site that will help you most of the D-Link routers:
http://www.default-password.info/d-link/
Here is an extract:
D-Link DI-624 - all
admin
(none)
- Admin access (HTTP)
User
(none)
You need to buy a wireless router to connect to your laptop. For example the Linksys wifi router it's easy to setup just run the cdrom install in follow the instruction. and also you can setup or configure it by webase configuration of router. Just type to the internet browser IP 192.168.1.1 if the user name appears just type admin and password sometimes admin also or 1234
