Question about GE JE1340 1100 Watts Microwave Oven
GE JE1540AV Made a loud "pop" sound (not sure if this happened before or after breaker tripped - I'm trying to help an elderly friend). After re-setting the breaker and plugging it back in - it does not sound the same when running, the turntable does not turn, but it still heats. Any ideas where to start?
  • 5 Answers
SOURCE: microwave made loud popping noise
The magnetron is bad. Probably cost about $50 or $60 for the part. Not too easy to replace, but it can be done.
Posted on Dec 14, 2007
revamos
  • 16 Answers
SOURCE: GE spacemaker no longer heats
most common problem mag tube out
Posted on Apr 20, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Mircowave will not heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 08, 2008
sams_trix
  • 93 Answers
SOURCE: GE JVM1850CH06 microwave no heat with loud humming sound
With the details you described, the high voltage diode might be shorted( usually HVR 1X). It is connected from the Capacitor and the chassis, or else the capacitor is the one at fault,but not common .
Posted on Aug 29, 2009
SOURCE: oven made loud pop. Now does not heat and is loud.
Had the same problem. It was the high voltage rectifier. Bought replacement part at Sears online for about $16 (including shipping) and replaced myself. Not too difficult, but you need to be VERY CAREFUL to discharge the capaciter. You can even leave it mounted, while fixing it. Just remove upper plastic vent covering, which exposes the mounting screw for the control panel. Unscrew and slide the panel up to dismount. You will need to disconnect all the wire attachements to the control panel. I took a digital photograph to ensure I could reconnect exactly as it was originally arranged. The part is attached to the capacitor in the back of the unit - MAKE SURE THE CAPACITOR IS DISCHARGED FIRST.
A couple notes:
  • I had read other postings saying that other parts would probably need to be replaced, as their shorting likely caused the failure of this part. However, I traced the shorting to excess moisture - my wife was boiling a lot of pasta on the stove for an event. Once dried out, the short was gone.
  • The replacement piece is shaped a little differently and can obscure the internal fan. This can cause the unit to overheat and the circuit breaker to fail, which I found out the hard way (a much more difficult--yet still unexpensive--repair). I used some electrical tape to make sure it stayed out of the way.
It has been about two months since the repair and it is working well.
Posted on Dec 26, 2009
I need to know what is the first thing to look at when a mircowave trips a circuit breaker
First off you probably have too many appliances running off the same circuit as your microwave. Try using a different socket. This has happened to me many times at various houses I've lived. For example... My wife uses the hairdryer when I'm warming up some coffee...trips breaker. It basically breaks down to how many circuits your breaker box holds and how powerful it is. Imo Hope this
May 31, 2015 | GE Microwave Ovens
Opening the door tripped breaker a few times, now microwave will not power on.
Sounds like a bad switch should have three primary, secondary, and monitor switch after 5 years change all 3 they are not the same primary and secondary are NO ( normally open ) and the monitor NC ( normally closed ) unit will not come on the fuse on the filter board is blow this usually shorts out the filter board change the switches first and replace fuse may not have to replace filter board hopes this helps.
Apr 06, 2015 | GE Monogram ZE2160SF Convection /...
There is a loud buzzing sound and it trips the breaker after 10 seconds of operation. What is the problem?
Typically a bad magnetron. They draw a lot of power when they go bad and trip the breakers or fuses inside the micro. Very fixable
Oct 06, 2010 | Amana RFS12MPS Microwave Oven
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
Microwave Model WES1450DM1BB I boiled 4 cups of
Owners of a GE WES model might want to look at this blog post.
I'm sure the magnetron overheated and tripped the magnetron's thermal cutout.
I'd strongly suggest taking it back if you can.
Dec 24, 2009 | GE Microwave Ovens
Microwave oven blows breaker after 2-3 secs
make sure that your microwave is on its own circut breaker meaning nothing shares the plug
Mar 25, 2008 | GE JVM1650 1000 Watts Microwave Oven
Breaker tripping
Make sure it is plugged into a 20 amp circuit. If it is in a kitchen it should be a 20amp breaker if it trips a 20 amp breaker it needs to be replaced. If it is a new house and you plug it in in the kitchen and it trips a 15 amp breaker then the house does not meet code. ref Article 210.52(B)(1) NEC
Jan 18, 2008 | Emerson MW8107WA Microwave Oven
Microwave made loud popping noise
Dec 13, 2007 | Whirlpool MH7130XE Microwave Oven
GE Spacemaker JVM1850CH03
Chances are it is a bad magnetron, but it may be a bad high voltage rectifier diode.
Some models have a 9-year warranty on the magnetron, so you may want to check with GE Customer Service at http://www.geappliances.com/service_and_support/contact/
The pop and wierd noise makes me suspect the diode has shorted.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Plus there should be a very helpful "mini-manual" hidden inside the unit behind the control panel.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 07, 2007 | Microwave Ovens
Tripping of circuit breaker
Check what other appliances are on your circuit. What goes off when the breaker is tripped. You may need to relocate the microwave to a different circuit. Try to stay away from the refrigerator or AC circuits.
Nov 03, 2007 | GE JVM1440 Microwave Oven
GE JE1340 1100 Watts Microwave Oven Logo
106 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
