Question about Nokia 6600
Frezing when ever i enter where the weather is too cold example like air condition my phone goes off.
  • 58 Answers
Make a wollen cover for your handset.
Supriyo DG
Posted on Jun 12, 2008
Home wired system with 8 units goes off in cold weather without any alarming conditions. Does cold weather effect their operation?
Check each of the sensors one has failed or it also alarms on low temperature and you are cold enough to trip it.
Jan 11, 2015 | Heating & Cooling
Runs rough in hot weather, why?
This could be the air flow sensor on the intake or egr valve.
Jun 01, 2013 | FSR Relay. air conditioning a/c ....
Gasoline door will not open when i pull the lever in cold weather! it worked fine with tempuature was above freezing. how can i fix it ?
It is a general problem. What you can do is to use anti frezing fluid/spray. Spray it into the gasoline door if you can. As soon as able to open - get everything dry using a kind of air blower and when dry use silicon spray. Problem solved.
Jan 15, 2011 | 2000 Suzuki Grand Vitara
In cold weather the inside of the windows are fogged prior to starting the vehicle.
sounds like you have a leak in your weather stripping arond your doors. and that will cause cool air to enter the vehicle where it is warmer than the air entering causing a fog
Jan 13, 2011 | 2004 Mazda 3
Why does the air conditioning switch it self on, even in the cold weather with the heating full on?
The A/C Compressor will kick on anytime you have the car on defrost This is normal and it keeps the A/C system from drying up during cold weather.
Dec 01, 2010 | 2009 Ford Focus
How to troubleshoot the electrical air conditioning system 2000 GMC Yukon Denali. I put in new resistor, relay and dealer blower motor and it still doesn't do anything. Air conditioning control switch...
The compressor on the air conditioner in my 2000 GMC Yukon XL went out last summer. Had it and the whole line replaced at a local air conditioning shop last fall. Used it little before cold weather. Warm weather this spring and no cold air. We could hear the compressor trying to kick in. The shop told us that the control console was bad and had to be replaced. They told us the part was on back order and did not know if they would be abel to get one any time soon. We took the Yukon into the local GM dealership. They told us that the high side fitting was bad and that the freon was very low and that they would have to deal with that first to check the system. Called back to the air conditioning shop and they said they had a console come in and they would put it in and check the high side fitting. I now have cold air and questions. Bought Yukon in 2005 used, had always had problem of not switching to cold air once the heater has been used. We were told changing the console should fix that. It has not changed. I feel like the console angle was a scam, that the system was just low on freon. Each shop was blaming the other for trying to scam me. And what can fix the heat to cold issue? If anyone has answers I would sure appreciate the knowledge.
Jul 02, 2010 | 2000 GMC Yukon Denali
Air condition do not blow hot air in cold weather
this problem is caused by a defective air temp control blend door motor, to replace this part the dash must be removed.
Mar 23, 2009 | 1996 Mercury Grand Marquis
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
FREZING?
you should rewrite this problem on the phone forum this is the air compressor forum that can get you to different experts
Nov 23, 2008 | Air Tools & Compressors
Nokia 6600 Logo
37 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
