Question about Car Audio & Video
Nitro 2,000 watt amp
My amp went into protect mode what does that mean?
    Genius:
  • 1,550 Answers
Maybe the audio amplifiers IC's are in bad conditions you need to replace them.Good luck.
Posted on Jun 02, 2008
How do you reset nitro amp that is in protect mode?
If the amp is in protect mode, then there may be a speaker wire that is shorting out or you may have a bad speaker...you can test this by completely unhooking the speakers on the amplifier and then turning the amplifier on...if it comes out of protect mode then you will need to find out which speaker is bad...if the amplifier does not come out of protect mode when you turn it back on then there is a problem inside the amplifier and you will need to take it to a service shop for further diagnoses
May 15, 2011 | Nitro BMW-482 Car Audio Amplifier
I have a nitro 1200 watt amp that was working great until it a red light that read " protection mode" turned on
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty
Definitely is worth .A thumbs up would be greatly appreciated if this answer is helpful to you. nitro-1200-watt-amp-working-lv2kkrmxrai4iihdvw4m3np2-1-0.jpg
Aug 25, 2010 | Nitro BMW-482 Car Audio Amplifier
My nitro bmw-486 amp is in protect mode how can I
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty De .A thumbs up would be greatly appreciated if this answer is helpful to you. nitro-bmw-486-amp-in-protect-mode-lv2kkrmxrai4iihdvw4m3np2-1-0.jpg
Feb 24, 2010 | Nitro BMW-486 Car Audio Amplifier
I have a nitro 1200 watt amp earlier today it was workin with no problems we parked then came back in the car 3 hours later and it wasnt workin wont come on or anything just red light which is protecting...
Check your speaker wires, make sure everythings connected right with no short circuits, and check all of the fuses in the amp, and make sure none of them are blown. If all this checks out just check the battery wire, grnd, and remote wires. It has to be a wiring issue unless you busted your amp, but if was working when you tuned it off it should be alright... hop this helps...
Sep 10, 2009 | Nitro BMW-484 Car Amp
What makes a nitro 1200 watt amp go to protect mode
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. D .A thumbs up would be greatly appreciated if this answer is helpful to you. makes-nitro-1200-watt-amp-go-protect-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg http://www.nitrobmw.com/
Aug 02, 2009 | Nitro BMW-482 Car Audio Amplifier
Lanzar 800 watt amp protect mode stays on
protect mode usaully means that something has disrupted the power of feed lines to the subwoofer/speakers possibly fuse is blown in amp or amp is blown in which we hope not. see if you have a warrenty if blown and send back or bring it to where you purchased it from.
Aug 01, 2009 | Lanzar VIBE266 Car Audio Amplifier
Jbl am in protect mode
if it goes in protect mode means ur amp is turn up to high or it is over heating so it protectn it from fryn ur amp try to adjust it down
Jul 12, 2009 | JBL BP1200.1 Car Audio Amplifier
Red protection light
If the amp is going into protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
Sep 12, 2008 | Nitro BMW-482 Car Audio Amplifier
Amp not working correctly goes into protection
Disconnect the speaker wires from the amplifier and see if it still goes into protection mode. If it still goes into protect with the speakers disconnected, there's a problem with the amp; if not, you may have a blown speaker or a shorted speaker wire.
Feb 22, 2007 | Legacy LA2098 Car Audio Amplifier
Car Audio & Video Logo
157 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
