I forgot my WEP code on my wireless router. Can I re-set
  • JERRY MCCLOUD Oct 14, 2010
    what is the make and model of the router?
  • 707 Answers
Yes, but it would help if I knew the make and model of the router
Posted on Oct 15, 2010
  • JERRY MCCLOUD Oct 15, 2010
    Well there should be a "hard reset" button on the router. It will be a small hole approx. the size of a headphone jack for an ipod. you need to stick something (non-metallic) into the hole and depress the button inside for at least 30 seconds. This will reset your routers default settings. You will still possibly have to know the factory default password and username for your particular router. username possibly blank...pass admin. or vice versa. Good luck
Forgot the wep key code.
If you forgot the wep key to your internet your best solution would be to reset your router and restore all of your settings to their default value. There should be a rest hole on the back of the router. simply hold down the reset button and then log back into the router using the default ip address (try either 192.168.1.1 or 192.168.0.1) and the default username and password. Once you do that you will have to go and set all of your values again such as your network name and your new wep password.
Hope this helps!!
Apr 27, 2011 | D-Link Wireless N 150 Home Router 4Port...
I forgot my password
If you forgot your user and password of router then press RESET button of router for 10 seconds it is in back side of router. Then all settings defaults. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . If you forgott WEP password in wireless security note down the WEP code it is your password to connect wifi.Then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Sep 08, 2010 | Linksys WRT120N Router
Forgot my password
Sep 06, 2010 | Linksys Wireless-G Broadband Router
Forgot my wep key. How do I get it?
You can sometimes retrieve it from the router settings, but barring that, there really is no easy way to get it.
Note that I said easy. If your router is indeed using WEP, you can sniff the packets coming off it with sniffers and once you have enough packets, then you *might* be able to decode the WEP key code. This usually doesn't work out very well though.
Jun 13, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
I am connected to d-link and wants to set up the secure wireless router. I forgot the password... How can I get that reset?
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Apr 04, 2010 | D-Link AirPlus DI-524 Wireless Router
I forgot the password of my dwl-900ap+ and can not connect additional pc to the wlan. Help
You can secure your wireless network wit WEP or WAP code.
http://192.168.0.1
or
http://192.168.1.1
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Jan 10, 2010 | D-Link Air DWL 900AP (DWL-900AP) 802.11b...
Need wep key code
The wep key is set by the system admin when the router is installed, contact the systen admin to get the wep key.
If you forgot it you have to reset it but logging into the router's setup through a browser by typing its IP address, then going to Wireless Network Security and changing the WEP key.
Hope this helps,
Cheers,
Jan 06, 2010 | D-Link AirPlus DI-524 Wireless Router
I forgot the password I set up for the wireless
Connect to the router typing 192.168.1.1 in the browser window with ID admin and password as admin. Go to Wireless->Security. And there you will find WEP key. The WEO key has to be seen. If it is **** format then just below it you will fing a box saying WEP key in clear. Tick this box and your WEP key will appear in clear. Note it down as it is generally 10 digits long.
Dec 19, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
Reset router and add a new netkey . I have a Router G MIMO Plus. Model F5D9230-4. I move my office and I lost manuals and CD installation. We also change computer so we forgot the netkey. How can we reset...
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
Dec 10, 2009 | Belkin (F5D9230-4) Wireless Router...
I have a t-mobile linksys router. old computers and phone work fine. new laptop doesn't because i forgot or don't know the password for the router. is there a way to find this?
Connect your router to computer with ethernet cable.
Then you can access it with following defaults link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password".
Then you can see configuration of router.
Click on wireless and then wep security there is wep code it is your password to connect wifi.If it in * or # format then you need to set new add new WEP code then save settings it is your new password for connect internet.
Let me know if you need further assistance.Thanks for uisng FixYa.
Dec 07, 2009 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
