Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
My TI-84 calculator says "Garbage Collecting" and won't work, how should I reset it?
  • 45 Answers
Found at www.epsstore.ti.com
What can be done if a TI-83 Plus family or TI-84 Plus family calculator displays Garbage Collecting... for more than 20 minutes?
The garbage collection allows the cleanup of unused archive memory. It deletes unarchived variables from the user data archive and it rearranges the remaining variables into consecutive blocks. When a variable is unarchived, the Archive free memory amount increases immediately, but the space is not actually available until after the next garbage collection.
If garbage collecting is more than 20 minutes, the calculator has possibly locked up and will need to be reset.
The reset procedure will delete all the items that are in the memory of the graphing calculator. Use the reset procedure below:
• Remove 1 AAA battery.
• Press and hold down the [DEL] key.
• While holding down the [DEL] key, replace the AAA battery, and press the [ON] Key.
The message Waiting... Please install calculator software should appear. At this point, it will be necessary to reinstall the calculator's operating system.
• Connect the calculator to the computer using the TI Connectivity Cable or DirectUSB Cable.
Please post if this was helpful...
• In Windows®, click on Start >> Programs >> TI Tools >> TI Connect >> TI OS Downloader.
• In MacOS® X, open Hard Drive >> Applications >> TI Connect >> TI OS Restore.
• Follow the directions on screen to reinstall the calculator's operating system.
Access the link following for detailed instructions on how to complete operating system installation.
Posted on Oct 15, 2010
My ti-84 calculator wont react to anything and it says garbage collecting. i think the bar on the side should move and its not moving and its been like this for several weeks. i did download a whole pile...
I remember this happening once to my TI-83. I know it's a different calculator. But it happened frequently. Without completely reconfiguring the calculator, you can remove the batteries whenever you see the message and when you start it up again, it should be okay. It may continue to display this message once in a while. I used to just remove the batteries. I don't know if it will work on your TI-84 the way it worked on my TI-83, but I hope this helped!
Please rate my solution!
- Frankie
May 05, 2011 | Texas Instruments TI-84 Plus Calculator
Locks up, or long delay after pressing a key
try garbage collecting
2nd+catalog, go down to Garbage Collect and run it
that usually makes your calculator run faster
Sep 24, 2009 | Texas Instruments TI-84 Plus Calculator
Frozen ti 84 plus silver edition
Ther is no reset button. You have to take the batteries out.
Take the AAA batteries out and take the back up battery out...located in a little door with a screw just above the AAA batteries. Leave the batteries out for about 8 hours. This is how you reset a TI graphing calculator.
Aug 18, 2009 | Texas Instruments TI-84 Plus Silver...
When I replaced the batteries in my TI-84 plus the screen now reads "garbage collecting" and nothing works. Any suggestions?
Whenever my calculator has said that, it usually takes a long time, especially if you haven't garbage collected in a while. I don't see why it wouldn't stop eventually, but if it seems like it never will, take out all the batteries and the back up battery behind the door with the screw. Leave them out for like a whole day. When you replace them it should reset your calculator.
Aug 09, 2009 | Texas Instruments TI-84 Plus Calculator
Err: bad address when unarchiving
Ti helper has a correct answer but you may want to try garbage collecting first. To do this press 2nd catalog and then g and then press enter when you find garbage collect. Then enter again and say yes. This should give you back the mem if not you need to reset the ram.
Apr 09, 2008 | Texas Instruments TI-84 Plus Calculator
Garbage Collecting
graphing calulators work much like computers. The have RAM space so they can remember what you have done recently and stuff like that. So when it's garbage collecting it means it's trying to find more space. This generally means that you don't have much much ARC or RAM space left. You can see this under your memerory manager. (2nd + enter) then you can reset your calculaor(2nd plus 7 1 2) or you can go to memory manager and unarchive your programs. Fur an example you have TI 84. Most new TI 84 have sientific tools. so if you don't you it take away the archive (*) by pressing enter and then hit DEL. the more RAM space and ARC space should make it so it doens't garababe collect. Hope this works. i can help you more if this doesn't work. GOOD LUCK
Jan 24, 2008 | Texas Instruments TI-84 Plus Calculator
Ti os restore problem
you shouldn't need a username and password. Download the OS from education,ti.com.and right click it, there should be an option to "Send To TI Device..." That should work.
Oct 21, 2007 | Texas Instruments TI-84 Plus Silver...
Garbage collecting
I had the same problem. Here's whutcha do: You know that USB cable that came with your calculator that hooks up to your computer? You're gonna need it. First, take out one battery from your calculator. Then hold down the DEL button. Whilst holding it down, re-insert the battery. Now turn the calculator on. Hooray! It doesn't say Garbage Collecting anymore! Now it says "Waiting... Please install operating system now." Now you hook up your calculator to your computer with that cable. Go into TI CONNECT (if you don't have it, download it at TI's official website), and transfer the newest OS (also available at TI website). Now your calculator is working again. Woohoo.
Sep 24, 2007 | Texas Instruments TI-84 Plus Silver...
Garbage collecting
Sep 07, 2007 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
454 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
