Question about Black & Decker 7448 1/3 Sheet Orbital Finishing Sander
Have a black &decker finishing sander no.7404 type1,how do you load sandpaper?
SOURCE: how do you change paper
At both ends of the bottom pad, there are metal fittings that have a rectangular hole in the middle of them. Take a regular head screwdriver and put the tip in the hole and carefully but firmly lift up and hold while at the same time pushing the narrow edge of the 1/3 sheet sandpaper up under the metal piece which kind of looks like a C on its edge. Then let down the metal piece with the screwdriver and that edge of the sand paper should be held in place. Do the same thing for the other end of the sandpaper, making sure to pull the sandpaper sheet tight against the rubber pad.
Posted on Dec 04, 2010
miket756
  • 2702 Answers
SOURCE: How do I change the sandpaper in my
there are many types of sizes for this sander check you have the right size first,,, after that check that the return springs in the belt tenshioner are poping out fully
Posted on Nov 15, 2009
  • 302 Answers
SOURCE: Black & Decker 3X21
I have one of those and I just smack the front roller ahead with a brass or plastic hammer. I hit the movable bracket that the roller is attached to. It takes a pretty stout whack to do it though. hope this helps you
Posted on Jan 14, 2010
Testimonial: "Thanks for the help, I wasn't sure if there was some magic button I was missing. Tks, jw "
  • 8 Answers
SOURCE: Black & Decker Cyclone won't power on
If the sander was on for a long period of time maybe 20 mins or so then the switch has probably stuck in the off position when you turned off. Try a new switch or test the old one. Try Solent Tools on 023 80578057 for spares or further advice.
Posted on Mar 11, 2010
  • 8 Answers
SOURCE: Describe your Black & Decker BR318
This is a good sander but no portable belt sander is really a floor sander.
How do I oil my black and decker 7404 finishing sander
You don't. this has always been a disposable tool. replacement on internet about $10.00
Jan 29, 2018 | Sander Tools & Hardware - Others
Yes, I am on my 3rd one. Your machine has destroyed itself, and must be replaced. Sorry about that. If you choose to do so, you can take it apart and see what I mean. ( I fix these).
Be blessed..
May 14, 2013 | Black & Decker 7448 1/3 Sheet Orbital...
Could you please tell me what sandpaper goes on the Mouse sander/polisher model # MS500
ok this easy go to the hardware store and ask for the sandpaper to fit your sander, black & decker make sandpaper specifically for that sander. now depending what job you want to do will determin what grade you want sand paper works like this the higher the number on the paper the finer it is so for example 80 is very coarse you would use that for eg stripping thick paint on a door but 2000 is very fine and is used for eg sanding varnish between coats. ok hope that helps let me know how you go.
Mar 11, 2011 | Black & Decker Mouse Sander/Polisher
How do you change paper on a black & decker finishing sander 7404-04
Aug 14, 2010 | Tools & Hardware - Others
Dec 10, 2009 | Black & Decker Black And Decker Cyclone 4...
Replacing the sand paper
Ok on the front and rear of the sander you will see metal wire holders. These extend each side of the sander and form a loop to which you can release them from their holder. Release each side ring and then that will lift the wire holders up at the front and back of the sander. This releases the sandpaper sheet. Now cut or add a new sheet that is long enough to fit over the sander base and fold up under the wire holders. Then clip the rings from the wire holder back in place while holding the sandpaper under the wire holder to hold the sandpaper in... same process for each holder (one front and back). That's it!
Jun 13, 2009 | Black & Decker QS800 2.0 Amp 1/4 Sheet...
Black and decker model 7404 1/3 sheet sander - not orbiting
wear inhibitor part number 86355 has broken on you. When this part brakes it brakes into tiny pieces which then leave the case so it hard to tell whats wrong. They don't make this part any more as the 7404 was discontinued in October 1975. I hoped this helped. I have the same problem.
Feb 07, 2009 | Black & Decker 7448 1/3 Sheet Orbital...
Black & Decker 7448 1/3 Sheet Orbital Finishing Sander Logo
388 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
